Definitive Technology BP7006 Second Thoughts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-09-2012, 11:48 PM - Thread Starter
dmeech10's Avatar
Need some help guys making a decision.
I picked up a pair of DefTech BP7006s on ebay without hearing them first. Went to Best Buy Magnolia to check out what the next gen 8040STs sounded like to get an idea of how the BP7006s will sound - was not 100% satisfied with what I heard.
The def tech were set up about a 12inch away from the wall, were flanked by speakers on both sides and had a shelf behind them. They threw a big soundstage, but the accuracy, especially with music was poor. The voices and instruments seemed to blend in together and it was hard to distinguish where in space the instruments were. The sound was also not as "crips" as I had hoped, very fine details seemed to be omitted. The bass was stellar after I tuned it down where I like (about 1/4 of the way up). The sweetspot was very wide which is good as my and the SOs seating position are about 11 ft from the TV, usually just inside the L and R speaker (not dead center)
Is the poor accuracy and imaging attributed to the improper placements of these speakers at BB Magnolia Theater???? Do you think better placement will improve imaging and clarity?
My room is about 11'x14' with one of the 14' sides being open to the kitchen and dinning room. The speakers would be against the 11' wall about 9-10 inchs away from the wall and about 5.5 -6ft apart.
I compared the 8040ST to the B&W 685 as that is another speaker I am considering. All details were present. I could tell each instrument and voice apart and where in space each was located. Voices were very clear and pronounced, the bass was obviously less compared to 8040STs but I was surprised how much of it there was coming from a bookshelf. Only downside, these had a narrow sweet spot.
These speakers would be used 85% for TV/Movies and about 15% for music.
dmeech10 is offline
post #2 of 6 Old 09-10-2012, 12:20 AM
Matt34's Avatar
Liked: 25
Wait until you get them home. Best Buy is not an ideal enviroment to audition speakers.
Matt34 is offline
post #3 of 6 Old 09-10-2012, 12:30 AM - Thread Starter
dmeech10's Avatar
That's what I'm thinking. Ever since I heard the 8040s I've been reading around forums and reviews with people mentioning the mild lack of imaging and clarity. I didn't think it would be THAT noticeable when compared to B&W 685s
dmeech10 is offline
post #4 of 6 Old 09-10-2012, 12:33 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
That is probably a fair assessment of DefTech Bi-pole speakers; although, the projection can be tightened up by pointing the speakers towards the " sweet spot " a little bit -- which DefTech recommends. I'm fine with my DefTechs since I only do about 20% music and THAT is mostly multi-channel classical concerts. BestBuy / Magnolia is not the best place to audition these speakers as they are clearly not positioned correctly. Mine ( BP7000SC ) sound quite good to me with music, but again, I'm not that critical when it comes to music. They absolutely ROCK for movies though.
Others that actually own the BP7006's or 8040's can chime in with a better assessment than I can.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #5 of 6 Old 09-10-2012, 12:44 AM - Thread Starter
dmeech10's Avatar
Gotcha. Clearly for music the B&W 685s sound better to me. From what I see on forums people seem to prefer the DefTechs to B&W (at least the 600 line) for HT. What I don't get is wouldn't accurate imaging and clarity of the B&W be better at reproducing HT effects?
dmeech10 is offline
post #6 of 6 Old 09-10-2012, 12:44 AM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
Positioning will play a part since they were probably too close to other speakers/the wall, but Definitive bipolar speakers are more known for their performance with movies than music.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
Reply Speakers
