Surround sound.... Need help. Someone to keep it simple. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-12-2012, 03:13 PM - Thread Starter
rubin215's Avatar
I'm moving into a new apartment and want to set up high quality surround sound in my living room (average size). I've done some basic research and feel overwhelmed.
My budget is $700-1200. Looking for highest quality sound without a ton of installation required. Using it for music and watching movies.
From what I heard, I should avoid the home theatre system packages at Best Buy.
Can anyone please advise with simple solutions?
rubin215 is offline
post #2 of 7 Old 09-12-2012, 03:18 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Is this budget for just speakers and sub, or for a receiver as well? Do you share adjoining walls with neighbors (beside, above, and below)?
How large is the room (dimensions)?
ack_bk is online now
post #3 of 7 Old 09-12-2012, 03:24 PM - Thread Starter
rubin215's Avatar
That's my budget for the entire package.
Living room is 18' 8' x 12' 0 which is connected to Dining room that's 9'6 x 9'2.
There are neighbors to consider, but I'm not necessarily focused on high volume listening. Just want to maximize the listening experience at normal levels.
rubin215 is offline
post #4 of 7 Old 09-12-2012, 03:43 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Well then, I would get the most bang for the buck receiver you can buy:
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
This is an authorized reseller who sells refurbished with a full manufacturers warranty. This receiver gives you everything you should need including Audyssey MultiEQ (which is room EQ software built into the receiver and is worth every penny) along with Audyssey Dynamic EQ, which is great when you have neighbors or family members who don't like loud noises at night smile.gif
This leaves you roughly $1K for speakers. I really like these:
http://www.svsound.com/systems/scs-02m-5#.UFECDlL12Ik
This one is $497 on a great sale and would leave you plenty of money for s subwoofer like this one:
http://www.hsuresearch.com/products/stf-2.html
Some other options would be these speakers:
Pair of these for left and right mains:
http://www.amazon.com/Infinity-Primus-Two-way-Bookshelf-Satellite/dp/B0045NCB32/ref=sr_1_2?ie=UTF8&qid=1347485781&sr=8-2&keywords=primus+speaker
This center:
http://www.amazon.com/Infinity-Primus-PC351-Three-way-Center-Channel/dp/B0044D1788/ref=sr_1_1?ie=UTF8&qid=1347485831&sr=8-1&keywords=primus+speaker
These surrounds:
http://www.amazon.com/Infinity-Primus-P143-Bookshelf-Satellite/dp/B0044D3R7M/ref=sr_1_3?ie=UTF8&qid=1347485852&sr=8-3&keywords=primus+speaker
And this subwoofer:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026
The Primus speakers will play louder and cleaner for home theater, but I actually prefer the SVS for music and they should be more than fine for an apartment where you cannot exactly blast them too loud.
One more option, two sets of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059
This center:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325046
And then the subwoofer referenced above from Newegg.
For me, the Deftech would give you the best balance between home theater and music and are on a great sale.
post #5 of 7 Old 09-12-2012, 03:51 PM
hernanu's Avatar
Quoted: 592 Post(s)
Liked: 1070
Fronts: Energy RC-10 (pair) - $218 @vanns
Center: Energy RL-LCR (one) - $199 @ meijer
Surrounds: Energy V mini (two) - 2X $119 @ Vanns
Sub: Energy S10.3 - (one) $199 @ Newegg
So the speakers will be $854 for a very good 5.1 system.
Leaves $ 346 for a good receiver.
Denon AVR 1612.1 AVR - $189 @ Accesories for less
Leaves you $157 for a bluray player,
I'd recommend a Sony S590 - $108 @ amazon
Puts you $49 under your limit, for cables and such - use Monoprice.
The Energy speakers are really cut down in price now, since they have been discontinued, but are MRP'ed much higher - I'd jump on the center at $199, since its normal price is $300 to $600. The sale price ends 9/14.
I own or have owned all of the speakers, they are very good for that kind of space, the receiver and bluray I've heard great things about.
hernanu is online now
post #6 of 7 Old 09-12-2012, 04:34 PM - Thread Starter
rubin215's Avatar
Thanks for the suggestions guys. Looks I like I still have some homework! ; )
Appreciate your help!
rubin215 is offline
post #7 of 7 Old 09-12-2012, 05:24 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Those are all great recommendations above. I own the Energy RC series, but I don't think you could go wrong with any of them smile.gif
One thing about that Energy S10.3. It tends to fluctuate in price on Newegg between $200 and $230. Still a very good deal at the higher price, but I would encourage you to grab it while it's $200. You cannot do better for a sub at that price.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Reply Speakers
