**The Official Chane M&C 'Arx' owner's thread (A1, A1b, A2, A2b, A3, A5, etc.)** - Page 38 - AVS Forum | Home Theater Discussions And Reviews
 159Likes
post #1111 of 1118 Old 06-30-2015, 08:39 AM
Squirrel!'s Avatar
Quoted: 136 Post(s)
Liked: 57
Originally Posted by BufordTJustice View Post
You may have heard something change. Every amp designer creates a slightly different product. But, without any sarcasm, I doubt it was a net positive change.
EDIT: And, if it was a positive change, this indicates a flaw in the design of the amplifier.
Agreed. Going from 8 ohm to 6 ohm is only limiting the power the speakers get. I'm sure he heard a difference, but as you said, unlikely a positive difference. Example:
My MartinLogans are 4 ohm. Recently however, the highs just weren't as definitive as they once were and the mids seemed to be muddied. I thought (and was worried/scared to death) that my tinnitus (which happened about the same time frame) was screwing with my audio perception. Thankfully, I didn't just 'let it go' and I dug into my AVR menu and...yup, sho 'nuff, the ohm setting was on 4 ohm instead of 8 ohm. Not sure how that happened, but as soon as it was switched back to 8 ohm, the clarity was back and the power returned, making for a positive experience!
I just am wondering how it got switched, even inadvertently by myself. But I digress.
So yes, by all means, leave your ohm switch on 8 ohms. In fact, Audioholics just put out a video on this very subject:
BufordTJustice likes this.
Main: Mitsubishi 73734 DLP|Amazon Fire TV|Toshiba HD DVD-A35|Panasonic BD65|Denon AVR-4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|2 DIY Class 'G' 540w 12" Subs|APC H15|Harmony 720 Remote|Linksys E3000 Dual Band N-Router|Linksys SE2500 Ethernet Switch
MBR: Vizio VF550M|Roku 2XS|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton Audio SAT-BK|MartinLogan Dynamo 300|Belkin PureAV PF30|Harmony 550 Remote
Squirrel! is offline
post #1112 of 1118 Old 06-30-2015, 08:43 AM
GusGus748s's Avatar
Quoted: 266 Post(s)
Liked: 632
Originally Posted by creimes View Post
Pics...well of course haha
My DIY Flexy Rack is behind the wall that my TV is mounted on, I recently sold the XPA-100's as I really didn't need 7 channels of power and I purchased a second Mach 5 IXL-18 sub that isn't complete yet :P
Also my DIY acoustic panels
Nice set up. I need to build one of those racks, but I barely have time to do anything around the house. It sucks having 3 kids lol. What speakers are you using for surround back? I notice they are in-ceiling. I currently do not have any surround or surround back speakers. I've been looking to which one I will be going with. I was thinking of going with in-ceiling, but I don't know if this would be the best thing due to the attic insulation. So, I've been looking at the Polk Audio TL1's.
GusGus748s is offline
post #1113 of 1118 Old 06-30-2015, 09:44 AM
creimes's Avatar
Quoted: 14 Post(s)
I use the Emotiva UAC 8.2 for my rears
creimes is offline
post #1114 of 1118 Old 06-30-2015, 09:53 AM
TornadoTJ's Avatar
Quoted: 345 Post(s)
Liked: 126
I would like to know what in-ceiling speakers would match up with the A3's too. I considered the HSU model, but I'm afraid (probably justified) the horn tweeter is going to sound vastly different than the A3's tweeter.
TornadoTJ is online now
post #1115 of 1118 Old 07-02-2015, 11:29 PM
GusGus748s's Avatar
Quoted: 266 Post(s)
Liked: 632
Another question would be, what's your budget? I believe Martin Logan makes in-wall / in-ceiling speakers with planar / ribbon tweeters, but they are expensive.
creimes likes this.
post #1116 of 1118 Old 07-03-2015, 12:02 AM
creimes's Avatar
Quoted: 14 Post(s)
Well I really don't notice any issues with my Emotiva UAC 8.2 ceilings matching up with the Chane speakers, and to boot they are a fantastic price, I bought the UAC 8.2 when I was still using Monitor Audio speakers up front as I just couldn't pull the trigger on the expensive Monitor Audio ceilings back then and like I said I have no regrets using the Emotiva ones, hope that helps.
Processor - Sherbourn PT-7030, Speakers - Chane A5rx-c, A2rx-c, UAC-8.2 rears, Subs - Mach 5 IXL-18's, Amps - Emotiva XPA-5, Behringer EP4000 Sub amp, Sources - Mac Mini, Oppo 103, Display - Panasonic PCP60UT50
creimes is offline
post #1117 of 1118 Old 07-03-2015, 07:03 AM
TornadoTJ's Avatar
Quoted: 345 Post(s)
Liked: 126
I'm OK with the price of the Chane 3's, I don't want to spend thousands on my in-walls for surrounds. I may just go with the 1's and mount them and call it a day. I think it might be the best solution for me.
creimes likes this.
post #1118 of 1118 Unread Today, 12:54 PM
RochRx7's Avatar
Quoted: 17 Post(s)
As long as you don't mind a little bit of wait time for the deal to drop.. this should be perfect timing for you.
I want to jump on this desperately, but I need to recoup from A5rx-c+X4100W and unexpected ticket+car repair thanks to the wifey. Ugh.
https://www.massdrop.com/buy/chane-a1rx-c-speakers
RochRx7 is online now
Reply Speakers
