**The Official Chane M&C 'Arx' owner's thread (A1, A1b, A2, A2b, A3, A5, etc.)** - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 1766Likes
Old 02-02-2016, 03:46 PM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
Correct, I am running a 12" sub to pick up the lows. However, I pulled them from the wall and set the crossover to 50Hz without the plug for testing. I think I am liking this set up much better. Its still not 2' from the wall, but they sound more full than before. I am still breaking them in so only time will tell. I will post my opinion & post review as I get more time on them.
dago52 is offline
Old 02-03-2016, 06:31 AM
crbaldwin's Avatar
Quoted: 77 Post(s)
Liked: 24
I'm probably in the minority but I'm not a big fan of the black ash look. Have you considered a solid black finish (dull, not shiny piano black)?
crbaldwin is offline
Old 02-03-2016, 08:31 AM
Jon Lane's Avatar
Quoted: 110 Post(s)
Liked: 411
Affirmative. (And for an example, the bases on the tower models are semigloss black paint.)
The problem with paint, however, is cost. Simulated black ash is literally the only way to make the line as affordable as it is.
Paint is not an insignificant increase, but we are likely to add it as a step-up around mid year.
christoofar and A-rab like this.
Jon Lane is offline
Old 02-03-2016, 08:38 AM
christoofar's Avatar
Quoted: 252 Post(s)
Liked: 159
Decided to follow your lead, after work yesterday I popped the plugs & reran Audessey, since I have enough space behind my 3 fronts to let them breathe. Came up setting them to full range, so I set them at 60hz x-over point, the surrounds to 80hz & will be doing some serious listening in the coming days. So far they seemed to sound a bit better in my short test .
Heart in SoCal - Soul from the Motor City
AFTV2+ KODI 17=>SR6010=>Integra DTA-70.1=>Chane A1.4 x 3 + DCM OW-1s x 2 + 1 x RSL Speedwoofer10 S+ 1 x Klipsch 12-HQ
christoofar is offline
Old 02-03-2016, 12:44 PM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
Nice, my auto calibration also set the A5's to large and 120hz, so I changed them to small. I have been back in forth with the plugs and 60hz on the A5's and set the A2 to 80hz. I have approximately 20 hours on them and I can tell they are starting to open up a bit.
So you are not using the plugs?
dago52 is offline
Old 02-03-2016, 12:51 PM
Quoted: 252 Post(s)
Liked: 159
I love having Audessey for my odd ball room layout, but it *never* seems to get speaker size & x-over points right. For my 3 centers, it set them as full range ( large and 120hz makes no sense either.)Yes, I took out the plugs last night, but like I mentioned above have not had much time listening yet to see if doing this makes a difference in SQ. I set them as small @ 60hz, all the rest to 80hz x-over.
BufordTJustice likes this.
Old 02-03-2016, 01:49 PM
Quoted: 725 Post(s)
Liked: 378
Look what arrived today!!!
Dago; what's holding your shelf up?? Looks like it's hanging with no support brackets.
Let me know please
Primary set-up 5.1.4; Yamaha A2050 w/Emotiva XPA-2
Revel F206 fronts & M16 rears; Outlaw X12 Sub & RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polks LSiM703/704C, Polk RC80i in-ceiling rears, RSL Sub10
yanks1 is online now
Old 02-03-2016, 02:14 PM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
Let me know please
Correct, it is a floating shelf. I built it about 2 years ago and it works great. I screwed a 2x4 to the wall and it inserts into the shelf. The bottom shelf helps support everything because it is against the wall. Now I have to build another shelf because the A2 is much deeper than my last center and I want a bigger TV. Here are a couple of pics that may help.
ID:	1228393   Click image for larger version
dago52 is offline
Old 02-03-2016, 02:34 PM
Quoted: 725 Post(s)
Liked: 378
thx! In near future for one of my set-ups I have to build shelf or mantle to hold my new Polk LSiM 704c center that weighs 29 lbs.
Shelf will be below 60" TV and right above wall mounted electric fireplace. Could be a bit tricky, thx for the additional pix also
Old 02-03-2016, 02:45 PM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
No problem. When I build my next shelf I will try to take more pics of the process.
dago52 is offline
Old 02-03-2016, 02:52 PM
Quoted: 366 Post(s)
Liked: 109
I put the blame on the owner, the VP, the general. It's JJ.
tinhvo is offline
Old 02-04-2016, 11:26 AM
Maverick0984's Avatar
Quoted: 307 Post(s)
Liked: 133
So, I guess I have no clue what to set mine then for a crossover freq. I haven't been able to run Audessey yet but was assuming it'd set it all for me. I don't have a sub yet either, but will down the road.
I just got 2xA3's and an A2 installed and plugged in a couple nights ago and that's all the time I've had. Before the weekend I'll run Audessey but if it comes back full and 120hz for all 3, what's the logic behind changing it? Perhaps a crossover freq for dummies thread/link?
Maverick0984 is offline
Old 02-04-2016, 12:44 PM
Bandg's Avatar
I believe the rule of thumb is setting the speaker size to small and crossover to 80 when running with a sub. That usually gets you close to optimal and one can adjust from there for best sound. If you aren't running a sub the speakers should be set to full and the crossover should not be activated, or set so low, that it wouldn't matter.Let your ears help you make adjustments from the initial settings. Hope this helps.Those that with more knowledge feel free to correct the record.
Bandg is offline
Old 02-04-2016, 05:44 PM - Thread Starter
BufordTJustice's Avatar
Quoted: 201 Post(s)
Liked: 337
Agreed. Don't be afraid to deviate between 90 and 60hz for the front three to find what works for you and your setup.
Arcam AVR300, Adcom GFA-5500 (Main L+R), Panny BDT-500 Media Transport, Toshiba SD-9200 CD Transport, MiniDSP 2x4 HD, Vizio XVT 55" LED/LCD (full direct-backlit w/ local dimming), Darbee DVP-5000S, Chane A2.4 mains, Chane A3rx-c surrounds, Center TBD, Subwoofer exceeding 120dB at 2m groundplane @ 20hz (custom build), BJC ten-white w/ ultrasonically welded WBT locking banana connectors.
BufordTJustice is offline
Old 02-05-2016, 09:51 AM
Quoted: 307 Post(s)
Liked: 133
After running Audyssey, it wants the 2xA3's at large, the A2 at small, with crossovers of 40hz.
Seems like that is a solid starting point before I add a sub and surrounds?
Old 02-05-2016, 01:18 PM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
Are you running a sub?
dago52 is offline
Old 02-05-2016, 08:56 PM
Quoted: 307 Post(s)
Liked: 133
Not currently, no. Eventually, yes.
Old 02-17-2016, 07:13 PM
Husker41082's Avatar
I have a pretty big multipurpose room/theater area about 15' wide and 28' deep. MLP is around 14' from my projector screen. Would I be better off going with the A3's or A5's for left and right duties. Probably about 75% Movies/TV, 25% Music/Games. This will be paired with a SVS PB-1000 and Denon X2200 that have already been purchased. My wife is opposed to anything requiring stands as am I with a 2 and 5 year old. Most listening will also be nowhere near reference level so looking for a speaker that can play well at lower levels.
Husker41082 is offline
Old 02-17-2016, 08:14 PM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
Just an update on my A5's & A2 experience. So far I am loving the speakers and they keep getting better. They sound so clear and the details are phenomenal. As mentioned in previous threads, I can hear instruments in music that I have never heard before. I was able to spread out the A5's giving me a wider front stage. I have been running them without the plugs, but I am still testing. I plan to upgrade my receiver soon so hopefully they will open up even more with some additional power. I am seriously thinking about adding some small risers for the A5's to get them off the floor. They came with spikes but I am not using them because of my wood floors. I am looking forward to the advancement of the Chane speaker company and hope they release some smaller speakers for my front heights.
dago52 is offline
Old 02-17-2016, 08:43 PM
Quoted: 307 Post(s)
Liked: 133
How far from the wall are your A5's?
My A3's are about 4" or so from the wall for WAF related reasons which warrants plugs I feel.
Old 02-17-2016, 08:46 PM
Quoted: 725 Post(s)
Liked: 378
Husker: I am a big music fan and recently chose the A3 over the A5. Reason is I don't blast music or movies and these sound very clear w/tight mid-bass at any volume.
Plus I have them crossed over at 60 Hz to an Outlaw X12 subwoofer I bought on sale in Nov. Its a good combo and has lots of punch if & when I do crank it. Due to using a good sub, I don't think the A5 is worth the extra $$. But that said, most speak very highly of them. Good luck! Also, I got an A2 as center speaker which is awesome value & sounds great.
Old 02-17-2016, 08:51 PM
Quoted: 307 Post(s)
Liked: 133
Do you have any rears? I am looking for a good sub and rears to pair with my A3's and A2. I feel even the A1's are a bit overkill for the space.
Old 02-18-2016, 06:59 AM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
Mav, I am approximately 6" from the wall, but I am still testing. FYI, I run the EMP Bipole surrounds and they seem to blend pretty good with my front stage. I would also like any recommendations for front heights?? The front heights I am using now are part of my ELT set which I would like to sell. I am considering a couple of EMP bookshelves or some cheaper Dayton speakers to hold me over.
Any thoughts?
dago52 is offline
Old 02-18-2016, 07:54 AM
Quoted: 725 Post(s)
Liked: 378
Good question... For now just using older set of small Celestion bookshelfs on rear wall. At one point, I'll perhaps upgrade them. But this set up is at our out of state residence/vacation home so no immediate rush. Good luck!
Old 02-18-2016, 11:10 AM
Quoted: 307 Post(s)
Liked: 133
Does anyone have any suggestions for mounting A1's on a back wall to serve as rears?
Old 02-18-2016, 05:46 PM
supercell's Avatar
Interesting discussion about spacing from the wall. Is there a set distance from the wall for the A3/A5's where the plug would be more optimal or is it just a matter of preference?
supercell is offline
Old 02-18-2016, 05:57 PM
Quoted: 307 Post(s)
Liked: 133
Yeah, I don't really know. I have a feeling it is more like 12-18" though to be plugless. Something I am not close to at all.
Old 02-18-2016, 07:13 PM
dago52's Avatar
Quoted: 108 Post(s)
Liked: 68
The manual recommends I think 2' from the wall without plugs. I think it is due to the rear port so they can breathe.
yanks1 likes this.
dago52 is offline
Old 02-19-2016, 04:39 AM
Jon Lane's Avatar
Quoted: 110 Post(s)
Liked: 411
Since both the cabinet and base have threaded metal inserts, you have a lot of options. Try Brass & Granite Audio for a variety of options ranging from simple thread-in feet to adjustable metal outrigger bases. They also have metal discs to protect hardwood floors and tile. Maybe a user will organize a group and get some A3/A5 bases made.
I plan to upgrade my receiver soon so hopefully they will open up even more with some additional power. They sound so clear and the details are phenomenal. As mentioned in previous threads, I can hear instruments in music that I have never heard before. I was able to spread out the A5's giving me a wider front stage...
Thanks for the kind words. Your findings are consistent with other users who enjoy their setups: Many find they can upgrade their amplification and even their sources. Soundstaging returns and most users report more time spent listening to music and less to gear.
We also look forward to expanding the range. Thanks again!
Jon Lane is offline
Old 02-23-2016, 09:30 PM
jocanton's Avatar
Quoted: 44 Post(s)
Is there a certain volume level you should run the speakers at in order to break them in? Can I just turn them on a looped sound track and let them run all day for a few weeks without too much risk of damage (of course there is always some risk of damage no matter what you do, but is this a reasonable approach with out an unwise amount of risk I would damage equipment - dont' worry, I am not going to try to sue anybody if they say "yeah, go for it..." and then my equipment gets damaged...I just want an honest answer - I take full responsibility for what I chose to do with the information)? I have a1rx-c, a2rx-c, a3rx-c, and svs pb-1000 speakers powered by a yahmaha rx-v677 receiver.
jocanton is offline
