Sealed in-wall/ceiling rear surround suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-19-2012, 06:34 AM - Thread Starter
tome's Avatar
I am looking for a nice sealed speaker for an in-ceiling application. I have a pair of Linn bookshelf speakers that I bought 12 years ago that I still like for music, so I am considering the Linn Sekrit (http://www.linn.co.uk/systems/all-products/loudspeakers/sekrit-iw10-in-wall-loudspeakers). They are about $1050/pr and I would like to find something less expensive if possible. Searching around (in this forum and google) I seem to find quite a few that are more expensive (more like $1000+ each) but haven't had much like finding less expensive alternatives that seem decent. Any suggestions?
Tom
tome is offline
post #2 of 10 Old 09-19-2012, 11:32 AM
Scout's staff's Avatar
I think Speaker Craft makes an enclosed in-ceiling line of speakers in the $300 range (each I think).
Def Tech also make a large enclosed in-ceiling, but I think it is designed for surround sound, not as a main. It does does not look like the traditional in-ceiling is enclosed.
B&W may also make an enclosed in-ceiling as well if I recall correctly (most likely in the $700 range - each)
I had the same issue when trying to set-up my challenging room and placement of a center speaker. Since I could not get timber matched enclosed in-ceiling speakers, I added a back-box called Dynabox (from Dynamat I think - off Amazon). They run around $150 ea. I am very satisfied with this solution and have received several compliments on the sound quality and clarity of voice. My set-up consists of Atlantic Technology in-walls plus dual center in-ceiling speakers with the dynaboxes as enclosures.
I also liked the in-ceiling for it's directional capabilities - the woofer was angled, but the tweeter was directional allowing me to point the tweeter right at the listening position. Most angled in-ceiling speakers are limited to a set 15 degrees, which equates to approx. 2 - 3 linear feet from the speaker to the listening position off an 8' ceiling.
Scout's staff is offline
post #3 of 10 Old 09-19-2012, 11:54 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Triad makes sealed inwall and inceiling speakers. I would highly recomend them.
BllDo is offline
post #4 of 10 Old 09-19-2012, 12:35 PM - Thread Starter
tome's Avatar
Triad is more expensive, not less.
Tom
tome is offline
post #5 of 10 Old 09-19-2012, 12:49 PM - Thread Starter
tome's Avatar
Thanks, the Speakercraft Accufit series looks like it may fit the bill....in terms of price anyway.
Tom
tome is offline
post #6 of 10 Old 09-19-2012, 01:51 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Tom
The InCeiling Mini/8 LCR can be had for less than $500/piece and the Bronze/8 Satellites are about $450/piece. I'm not sure how that's greater than $1050/pair.
BllDo is offline
post #7 of 10 Old 09-19-2012, 02:06 PM - Thread Starter
tome's Avatar
I didn't see the mini/8 as I was looking for rear surrounds but it might work. $1000 is indeed less than $1050, though even more less than less than $1050 would be nice smile.gif
I don't see the bronze/8 for sale anywhere, do you have a link?
Tom
tome is offline
post #8 of 10 Old 09-20-2012, 07:22 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Sorry no link. I used a dealer that has now gone out of business. I still have one of their price pages.
Here is another pair that might fit the bill. Much more less than less than $1000.
http://www.ebay.com/itm/Triad-OmniRound5-Main-Stereo-Speakers-Pair-/251112982690?pt=Speakers_Subwoofers&hash=item3a778008a2
BllDo is offline
post #9 of 10 Old 11-21-2012, 10:14 AM
vivatech's Avatar
The Triad InWall Bronze/4 Surround speakers are $500ea MSRP and can be used InCeiling.
What model did you choose?
vivatech is offline
post #10 of 10 Old 11-22-2012, 05:05 AM
Dawn Gordon's Avatar
Quoted: 186 Post(s)
Liked: 142
List price on the InCeiling Mini LCR is $600.
Dawn Gordon is offline
Reply Speakers
