polk bookshelf with paradigm center - AVS Forum | Home Theater Discussions And Reviews
Old 09-22-2012, 11:54 AM - Thread Starter
jiggyk4's Avatar
I was wondering what people thought would be a good match to a paradigm cc-290 center channel. I am going to place it in my living room and need book shelf speakers to match but found a good deal on polk tsi-100"s. the set up is basically going to be used for everyday tv watching because I cant stand tv speakers and will only be a 3 channel setup since most of the movie watching will be in the theater room in the basement. I know paradigm atoms would be ideal but would there really be a noticable sound diff with just 3 channel listening?
jiggyk4 is offline
Old 09-22-2012, 12:11 PM
Audiophile2k's Avatar
Liked: 46
You would ideally want to stick to the same product line for the front 3 channels. Using speakers with a different sound signature will cause sounds and voices to change as they move from speaker to speaker, and cause other psychoacoustic problems.
Audiophile2k is offline
Old 09-22-2012, 01:37 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
Since you are interested in the Polk TSI series, know that those are basically the same as the Polk Monitor series that Newegg carries (TSIs are mostly a cosmetic change upgrade). Get the Polk Monitor40s and the CS2 center, and you'll have a nice front soundstage.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 09-22-2012, 01:49 PM
Ives's Avatar
I was told years ago at some highend audio/visual store that when matching different name brands for different channels, use the sensitivity dB number as a guide. I've never heard that advice again so I don't know how good that advice is. But that's what I've done. I have Audiofile 830L's for my main speakers 91dB ,400 watt 3 way's floor standing. With an Onkyo receiver, they sound great! Had them(speakers) for about 10 yrs. Never thought I would need more. They're out of business now. So recently I actually found a center channel that is close in sensitivity as well as design. They look like the same brand. That is important to me, I'm not a purist but I want them to look good as well. They're MTX monitor6c. Redoing my whole setup so haven't heard them yet. But if anyone has any advice or opinion on this I would like to hear it. May use some Boston Acostics for back channels or some small wall mountable speakers. I did notice MTX matches the sensitivity with their main & center channel setup, but not with their back channel's. Just sayin'. I've always liked Polk Audio, they always sound better in a side by side comparison to others in their price range.
Ives is offline
Old 09-22-2012, 01:50 PM
Ives's Avatar
Ives is offline
Old 09-22-2012, 01:54 PM
cel4145's Avatar
Liked: 2991
It's the timbre match that's very important, and you can't compare the timbre match of speakers with specifications.
cel4145 is offline
Old 09-22-2012, 04:57 PM
Ives's Avatar
Thanks, but Im looking for good enough not can't. Surely companies use some sort of audio principles in order to achieve timbre matching.I don't need sonic perfection just a hint, in case MTX doesn't work for me.
Ives is offline
Old 09-22-2012, 04:58 PM
Ives's Avatar
Ives is offline
Old 09-23-2012, 03:18 PM - Thread Starter
jiggyk4's Avatar
Thanks i believe i will try to find a pair of used paradigm atoms or just get new series for 400
jiggyk4 is offline
