Speakers - Confused - AVS Forum | Home Theater Discussions And Reviews
Old 09-22-2012, 09:44 PM - Thread Starter
e485926's Avatar
Please delete this post - its been duplicated. Thanks in advance.
Tim
e485926 is offline
Old 09-22-2012, 10:04 PM
Audiophile2k's Avatar
Liked: 46
I'll give you two options on the opposite ends of both price and ability to play reference level, but both will sound very good for the price.
Extreme Budget Pioneer System (Max SPL around 95 - 97db)
Front http://www.newegg.com/Product/Product.aspx?Item=N82E16882117403 $119
Center http://www.newegg.com/Product/Product.aspx?Item=N82E16882117404 $49
Rear http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405 $49
Sub (x2) http://www.newegg.com/Product/Product.aspx?Item=N82E16882269026 $400
total system cost $620 shipped.
Mid Budget BIC system (Max SPL around 116db)
5x http://www.amazon.com/BIC-America-FH6-LCR-6-5-Inch-Frequency/dp/B0015A8Y3E/ref=sr_1_2?ie=UTF8&qid=1348372527&sr=8-2&keywords=bic+speakers $550
Sub (x2) http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078 $600
Total System $1150 shipped
Audiophile2k is offline
Old 09-22-2012, 10:11 PM - Thread Starter
e485926's Avatar
Thank you for your post. The front two speakers, i need it to be hanging on the wall. Do you have any recommendations for such type?
e485926 is offline
Old 09-22-2012, 11:24 PM
Liked: 46
The BICs come with mounting brackets attached for wall mounting. They are also a sealed design, so no port concerns.
