Should I upgrade? Check out the options....(Velodyne vs Energy Take 5 Classic) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-23-2012, 02:14 AM - Thread Starter
JaredSD's Avatar
Quoted: 49 Post(s)
There is a decent deal on woot.com for today, and it has me questioning whether I should upgrade or not. I am not so up to date on specs etc on speakers and that is why I wanted your opinion. From a spec standpoint should I upgrade or is this a lateral move at best? The Velodynes I have now sound just fine.....just don't want to miss a good deal:) Any thoughts would rock!
I have these now: (had them 7 years now)
http://www.hometheaterhifi.com/volume_7_3/velodyne-cht-speakers-8-2000.html
Looking at these:
http://www.amazon.com/Energy-Take-Classic-Pack-Theater/dp/B0021L9BME/ref=sr_1_1?ie=UTF8&qid=1348383334&sr=8-1&keywords=energy+take+classic+5.0
JaredSD is offline
post #2 of 2 Old 09-23-2012, 04:22 AM
afrogt's Avatar
Quoted: 1061 Post(s)
Liked: 765
it might be a downgrade actually. The CHT's have larger 4.5" woofer and can play lower than the Take Classics which only have a 3" woofer with a frequency response of 115-20,000 Hz
I wouldn't make that move.
if you're looking for an upgrade in sound quality, get some larger bookshelf speakers.
Afro GT
afrogt is offline
Reply Speakers
