Dynaudio x16 vs Kef R300 / Onkyo 609 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-23-2012, 06:04 AM - Thread Starter
roman_gp's Avatar
Hello,
I'm looking for new bookshelf front speakers for Onkyo 609. I've listened to many speakers and made my choice - Excite X16. A friend of mine advised Kef R300, but I don't have time to listen to them. My room is about 35m2. I watch movies and listen to all kinds of music. Which of the speakers do you think are better? Are there other speakers I should consider, they must be not higher than 450cm?
roman_gp is offline
post #2 of 8 Old 09-23-2012, 10:34 AM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Dynaudio makes great speakers! Both the R300 and X16 are rear ported so they need open space behind them so don't try to put either on a bookshelf or closed cabinet. I have not heard the R300s but based on reviews they would be my choice if they will work for your space. They are a 3 way speaker and not small but they are less than 45 cm tall (38.5?).
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #3 of 8 Old 10-04-2012, 01:29 PM
bthrb4u's Avatar
Quoted: 69 Post(s)
Liked: 52
r300's open up ALOT with good equipment. I would suggest getting a $1000 pair of bookshelfs using the extra to get a good dac
bthrb4u is offline
post #4 of 8 Old 10-04-2012, 02:44 PM
Paraneer's Avatar
Quoted: 23 Post(s)
Liked: 72
It sounds like you have made a choice but are now second guessing yourself. Therefore you have not made a choice.
I think you were right the first time. Get the Dyns and don't look back. Fantastic speakers! Enjoy them.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
post #5 of 8 Old 10-05-2012, 12:30 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Dynaudio, KEF, Revel, B&W, Focal, ATC.
AcuDefTechGuy is offline
post #6 of 8 Old 01-04-2013, 07:48 AM - Thread Starter
roman_gp's Avatar
Thank you all for your input. Finally I got X-16, really enjoy them smile.gif
roman_gp is offline
post #7 of 8 Old 01-05-2013, 07:10 PM
justindo's Avatar
Congratulations! I heard the X16 yesterday and it's a nice speaker.
justindo is offline
post #8 of 8 Old 01-05-2013, 11:52 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 461
congrats on getting the speakers and glad to hear you are enjoying them. I havent heard the new kefs, but heard the previous XQs and iQs, both good speakers Im sure.
I used to have the X16s, and while the receiver you have will power them well, if you can at some point get a receiver with pre-outs and an external amp they will really come alive in the bass department. like all dynaudios they will soak up the power.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
Reply Speakers
