Need Recommendations (Klipsch RF-82 II , KEF Q900, Polk Audio RTI A7) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-24-2012, 10:12 AM - Thread Starter
DaveOrZach's Avatar
I'm in the process of building a 7.1 system with a Denon AVR-2112CI. I currently have some low end Yamaha speakers and a KW-100 from my college years. I'm starting out with just the front two speakers because of budget constraints and I really don't watch movies that much. I'll probably buy refurbs speakers to keep cost down. I'm trying to keep the first speaker purchase under $800, but I'm okay with going up to $1200. Is it a good idea if I buy KEF Q700 initially and move them to my back speakers next spring when I make my next purchase?
My Listening Behaviors
  • 70% music (iTunes AAC/FLAC)
  • 10% Vinyl
  • 10% Movies (Amazon, Netflix, and an old HD-DVD player)
  • 10% TV (almost all NFL)
  • In the future I'll buy a game console
Room Specs
  • Apartment build in the late 1800s, high ceilings
  • Hardwood floors
  • 16'x12'x11'
  • If you are looking at the TV, the left 16' wall and back wall are all windows
  • There is no wall on the right, it is open to the dinning room 16'x30'
DaveOrZach is offline
post #2 of 4 Old 09-24-2012, 10:41 AM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
Perfectly fine to build your setup as times moves forward. If you're set on KEF, I would suggest picking up the Q300's + a sub instead of the Q700's only for now. I would think Q300's would be just fine for surrounds and not take up much space in your smaller space.
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
Selling 1 e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
post #3 of 4 Old 09-24-2012, 12:11 PM
Alec88's Avatar
Quoted: 27 Post(s)
Yeah, there's a possibility that anything higher than the Q300 will sound underpowered.
Sony DA5700ES
PSB Image T5, PSB Image B5, PSB Image B4, PSB Image C4
Alec88 is offline
post #4 of 4 Old 09-26-2012, 05:38 AM - Thread Starter
DaveOrZach's Avatar
Thanks for the feedback. I went with the KEF Q300
Reply Speakers
Klipsch Reference Series Rf 82
