Best "ON WALL" speakers available? Take a gander and appreciate comments - AVS Forum | Home Theater Discussions And Reviews
post #1 of 54 Old 09-25-2012, 09:00 PM - Thread Starter
Shad0wz's Avatar
As topic says, what are the current best "ON WALL" speakers available?
Need to set up new system around 65 panny.
They need to be wall mounted.
Was looking at the following:
front speakers - 3 Paradigm Millenia LP's
Rear speakers - 2 Paradigm Millenia LP's
Sub - Paradigm 12" powered sub
This all hooked to an ARCAM AVR400
What else should I consider for speakers? Im not totally sold on the millenias yet, though Ive yet to hear them.
Shad0wz is offline
post #2 of 54 Old 09-25-2012, 09:01 PM - Thread Starter
Shad0wz's Avatar
budget is not a concern
Shad0wz is offline
post #3 of 54 Old 09-25-2012, 09:56 PM
NewHTbuyer's Avatar
Liked: 41
I have not heard any of these personally, but brands I see recommended are Totem Tribe, Wisdom Audio, and RBH
NewHTbuyer is offline
post #4 of 54 Old 09-26-2012, 06:39 AM
Wrager's Avatar
Quoted: 192 Post(s)
Liked: 114
http://www.artisonusa.com/loudspeakers/
Haven't herad them, but the reviews are pretty solid.
Wrager is offline
post #5 of 54 Old 09-26-2012, 07:43 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I would look into Triad:
http://www.triadspeakers.com/products/owblcr.html
They offer custom paint to match your room as well if you want them to disappear and can make custom speakers if you need a certain dimension or configuration.
James is another well reviewed loudspeaker company:
http://www.jamesloudspeaker.com/index.cfm?page=by_series&id=31&sr=1
As far as subwoofers, I would look at companies such as SVS, Hsu, Funk Audio, etc. You will get a much better subwoofer for the money.
ack_bk is offline
post #6 of 54 Old 09-26-2012, 05:29 PM - Thread Starter
Shad0wz's Avatar
Any other opinions?
Shad0wz is offline
post #7 of 54 Old 09-26-2012, 05:57 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
BG Radia..............
Triad is another excellent choice for multi-purpose.......ie theater/music.
doublewing11 is offline
post #8 of 54 Old 09-26-2012, 06:03 PM
Hookedonc4's Avatar
Quoted: 25 Post(s)
We use James Loudspeakers.
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is online now
post #9 of 54 Old 09-26-2012, 09:48 PM
BobL's Avatar
Liked: 56
Probably a little big for your application. But if you can fit it it is a great on wall speaker:D
http://www.genelecusa.com/ht/products/architectural/aow312b/
BobL is offline
post #10 of 54 Old 09-27-2012, 10:59 AM
mgrotel's Avatar
Quoted: 57 Post(s)
Liked: 32
Mirage Omnisats
mgrotel is offline
post #11 of 54 Old 09-27-2012, 06:53 PM - Thread Starter
Shad0wz's Avatar
Shad0wz is offline
post #12 of 54 Old 09-27-2012, 06:59 PM - Thread Starter
Shad0wz's Avatar
So now Im leaning towards the
KEF T305 system: http://kefstore.ca/t305-tseries-system.html
OR:
Monitor Audio Shadow series: http://www.monitoraudiousa.com/products/shadow/
Thoughts?
Shad0wz is offline
post #13 of 54 Old 09-27-2012, 07:43 PM - Thread Starter
Shad0wz's Avatar
for the life of me I cannot find any reviews etc of the shadow series from monitor audio.... plenty for the KEF system. frown.gif The monitor audio set looks nicer tho.
Shad0wz is offline
post #14 of 54 Old 09-27-2012, 08:28 PM
jugger's Avatar
Liked: 55
http://www.klipsch.com/gallery-g-28-home-theater
RC-64 Center, RF-7 Fronts, RF-82 Sides, RW-12D, QTY=2, RSW-15, RS-52ii Rears, Pioneer SC-1522-K, Panasonic 65VT60, 65"
jugger is offline
post #15 of 54 Old 09-27-2012, 08:39 PM
realjetavenger's Avatar
Budget of no concern? Totem Tribe V. These are incredible speakers.
http://www.totemacoustic.com/en/hi-fi/on-wall/tribe-v/
realjetavenger is offline
post #16 of 54 Old 09-27-2012, 09:01 PM - Thread Starter
Shad0wz's Avatar
Budget is no concern, I did look at the tribes but they seem huge compared to the alternatives mentioned. Size and the "WIFE" factor are a concern biggrin.gif
Shad0wz is offline
post #17 of 54 Old 09-28-2012, 07:00 AM - Thread Starter
Shad0wz's Avatar
So far taking a look at the selection of true SLIM speakers, here are my thoughts:
1. Paradigm millenia LP's - they have a limited range 120Hz to 17kHz, now they do have something called low frequency extension 78Hz but do not think that means they go down that low. As well, max power input at 70 watts, - not too keen on the fact they are wider than they needed to be.
2. KEF's T305 system - they have a much better range of 80Hz - 30kHz. Maximum output of 110dB. Their overall dimensions are better than paradigm.
3. Monitor Audio's shadow series - To me these are the most visually attractive out of the bunch, using a black anodized aluminum, they dont have that black glossy appearance. Their 60 series weighs in at 8 lbs, where the others from paradigm and kef were in the 3 - 4 pound range. I believe this is because the shadow series uses a solid all aluminum chassis, where the others are plastic. Specs are great - Range is 70Hz – 30kHz. Maximum SPD 108.6 dBA, Max power handling 120 watts
So looking at all this, I would choose the Monitor Audio shadow series, thing is, I cannot find a damn single review. I have no experience with Monitor Audio's products. Would appreciate peoples comments regarding monitor audio etc. smile.gif What would you do? smile.gif Again, budget is not a concern. Size and decent performance is! smile.gif
Shad0wz is offline
post #18 of 54 Old 09-28-2012, 09:08 AM - Thread Starter
Shad0wz's Avatar
So talking with Monitor Audio support... Think Im going to go with them.
They seem to be built solid, with the best look, being anodized aluminum matte black.
This is what Ill get:
2 x shadow 60's for L/R
1 x shadow center
2x shadow 50's for rears
1x RXw12 sub
All powered by an Arcam AVR600
Shad0wz is offline
post #19 of 54 Old 09-28-2012, 11:24 AM
azarby's Avatar
1 x shadow center
1x RXw12 sub
I have also decided on the Monitor Shadow speakers. For now I'm going with the S60 fronts and center. When the budget allows I will try to get the S25s to replace my Boston Acoustic surronds.
azarby is offline
post #20 of 54 Old 09-28-2012, 02:51 PM - Thread Starter
Shad0wz's Avatar
Have you had the chance to hear them yet?
Shad0wz is offline
post #21 of 54 Old 09-29-2012, 04:33 AM
Bazzy's Avatar
Quoted: 57 Post(s)
Liked: 37
Hi,
Congrats on your selection! The Shadow series do look very cool & MA are a very well respected company! Over here in the UK, a quite a few have opted to go for another subwoofer as the MA Sub is quite expensive compared to other options - especially as you are the in US - Jim Wilson has extensive & up to date knowledge on Subs - might be an idea to get his thoughts - there are companies like SVS, HSU etc..
Bazzy!
Bazzy is offline
post #22 of 54 Old 09-29-2012, 10:27 PM
azarby's Avatar
None of the local brick and mortars have them available to demo. This is usually against my normal method of try before buy. In this case I'm going to have to rely on the experience of my local installer. I currently have B&W CM4s and a CMC. My other choice was to get some B&W FPM 6s. The speakers should be here in less than 2 weeks and they said they would do the install as soon as they came in.
Also having them mount the 65" Panasonic plasma at the same time. I figure with a bad back, to let them have a go at it and keep the wife happy with a neater looking install. These guy were working on a custom rack set up with 3 five foot tall comm racks and and add on of 3 more three foot comm racks full of Integra amps, and oher equipment for a new build. The house supposedly has 25K sq feet under one roof. I figure if they could handle that, they could handle my puny little upgrade.
azarby is offline
post #23 of 54 Old 09-30-2012, 06:23 AM - Thread Starter
Shad0wz's Avatar
I talked to monitor audio canada and they found me a couple stores demo'ing the shadows on the floor. Saw / heard them yesterday and they were FANTASTIC, both looks and sound wise. Going to place my order tommorow. They had them mounted around a 65" panny VT50, same setup as mine so was more than pleased with the overall look smile.gif
Shad0wz is offline
post #24 of 54 Old 09-30-2012, 07:08 AM - Thread Starter
Shad0wz's Avatar
I am considering going with the GXw15 over the RXw12 sub. I really like that the GX has auto EQ where as I dont think the RX does. Just nervous that the 15" sub on the GX may not be "punchy" enough / ie slower than the 12" in the RX. Thoughts?
OR if the GXw15 is not going to fit the bill, what about GSw12, the older ver of the gold subby
Shad0wz is offline
post #25 of 54 Old 09-30-2012, 09:42 AM
azarby's Avatar
My Plasma is a VT50 also. Looks like we have good taste:). My speakers are being shipped in from Canada. Not sure what the process is to get them through customs down to Phoenix. Been waiting one week with two more to go.
azarby is offline
post #26 of 54 Old 09-30-2012, 12:37 PM - Thread Starter
Shad0wz's Avatar
Indeed, VT50 is a fantastic set!!!
What are you using as a sub for your set?
Shad0wz is offline
post #27 of 54 Old 09-30-2012, 04:58 PM
azarby's Avatar
Right now I am keeping the Boston Micro 120xs When the budget allows I will upgrade them to Shadow S25s
azarby is offline
post #28 of 54 Old 09-30-2012, 05:16 PM - Thread Starter
Shad0wz's Avatar
Shad0wz is offline
post #29 of 54 Old 09-30-2012, 09:11 PM
azarby's Avatar
OOps Sorry. My sub is a Boston PV700 200W
azarby is offline
post #30 of 54 Old 10-01-2012, 02:12 PM - Thread Starter
Shad0wz's Avatar
Placed my order today.
This is what finally came together:
1 x shadow center
2x shadow 60's for rears
1x GXw15 sub
Should have all the gear later this week!
Shad0wz is offline
Reply Speakers
