Travel / Airplane Headphones.... Small enough to fit in a Maxpedition - AVS Forum
post #1 of 2 Old 09-25-2012, 08:25 PM - Thread Starter
wacki's Avatar
Looking for headphones for airplane travel. Good sound quality. I was thinking about "sound isolating" to keep airplane noise out but this might be good because it folds up:
http://www.sennheiserusa.com/on-ear-headphones-stereo-headphones-502816
I want something that can fit in my maxpedition (which already has a micro 4/3 camera in it)
http://www.maxpedition.com/store/pc/JUMBO-VERSIPACK-65p6.htm
wacki is offline
post #2 of 2 Old 09-26-2012, 10:16 AM
fsrenduro's Avatar
The best bang for the size is universal fit in-ear monitors from someone like Westone, Ultimate Ears, Shure, and many many others. You'll get great sound reduction, since they are essentially ear plugs. If you have the funds and don't mind things in your ears then you can go with custom in-ear monitors. These will reduce outside noise better than sound canceling headphones but many people don't like in-ears.
Sadly Bose makes probably the best noise canceling over the ear headphones. They are spendy though.
You might get better results searching the forums over at head-fi.org
don't insult my intelligents
fsrenduro is offline
Reply Speakers
User Tag List
