bookshelf speakers for on the bookshelf - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-28-2012, 10:20 AM - Thread Starter
ncumming's Avatar
Alright...so I know ideal placement for bookshelf speakers in a home theater setup isn't on a bookshelf - it's on a proper speaker stand spaced out from the wall. However in my setup this isn't going to be possible - they really need to go on the bookshelf.
So the question is...are any of the lines of bookshelf speakers particularly well designed for placement on a bookshelf - where they will need good isolation and be able to handle being a little "crowded" - at least from the back and perhaps on one side.
I've always been a paradigm fan and my existing setup is Monitor 7's and a CC-370 center channel. However I'm afraid the mini monitor's rear-ported design won't work well with the back of a shelf a few inches away.
I'm considering Definitive's Pro Monitor line. They seem better suited by design for actually placing on a bookshelf. And they have the added bonus that they come in white, which my wife will love (or not hate to be more accurate).
So...let's hear it...in a "real world" situation, what speakers/features should i be looking for?
ncumming is offline
post #2 of 8 Old 09-28-2012, 10:59 AM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Yep. If your speakers will be pushed back up against the back of the bookcase, best to get front ported or sealed speakers. But if you can buy the Mini Monitors locally, maybe you can bring em home for a demo. Maybe there will be enough room. If the bass doesn't sound bloated or muddy, you are good to go.
NHT makes nice sealed speakers that would work fine for bookshelf placement.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 8 Old 09-28-2012, 12:02 PM - Thread Starter
ncumming's Avatar
Any experience with the definatives? Looks like the nht absolute zero is the same price point as the def 100's.
ncumming is offline
post #4 of 8 Old 09-28-2012, 01:14 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would look at Focal 705V - some good sounding speakers
http://www.dedicatedaudio.com/inc/sdetail/34398
http://www.dedicatedaudio.com/inc/sdetail/34397
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 8 Old 09-29-2012, 08:10 AM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15625
fwiw,don't know what your budget is but have a look at the boston acoustics bt1 lcr's at accessories4less $380 ea. great speaker company with quality drivers, these where made for in cabinet use and are very efficent at 93db great for ht
i'm so laid back,i'm laid out
smasher50 is online now
post #6 of 8 Old 09-29-2012, 10:16 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
You definitely need to get some front-ported speakers for your situation.
I suggest that you look at the KEF Direct webite; they make excellent speakers that are almost all front-ported.
The iQ30 would be a good choice, or the C3.
commsysman is offline
post #7 of 8 Old 09-29-2012, 01:39 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
I have some Monitor Audio RX2’s, which are rear ported with the option to plug the port or not. I do have mine on a shelf with the port plugged.
My only problem is when I decide to listen to some 2chaneel music without a sub, I do unplug the ports.
HAMP568 is offline
post #8 of 8 Old 09-29-2012, 01:51 PM
darkpoet25's Avatar
Liked: 40
Home Theater Direct has some front ported speakers, the Level 2 and the Level 3. The Level 2's have a silk dome tweeter. The Level 3's have a horn loaded ribbon tweeter. www.htd.com
Cliff
darkpoet25 is offline
Reply Speakers
