Budget In Wall Speakers for home Gym - AVS Forum | Home Theater Discussions And Reviews
Old 09-28-2012, 09:40 PM - Thread Starter
practal's Avatar
I have a 12x12x11 home gym and I am looking at changing out the speakers. I am currently using a pc for an audio source, Marzant SR5600 for the Amp, and a super cheap set of speakers from an Onkyo HTIB. I switched from ipod/headphones to the stereo about a month a go and I cannot take it any longer. The Onkyos offer poor sound and they get in the way, this space is very small for the amount of equipment I currently have in it.
Main music choice is heavy metal and there will be obvious room noise from lifting equipment. I do not need loud volumes, I just want something that sounds decent. I am looking to do 2 channel audio only and I am not looking for anything high end. I will be building a dedicated gym, and home theater, in my basement next summer. These are just going to be a hold me over and my current home gym will end up becoming a guest bedroom. I don't see a point in investing a ton of money when we may not even have audio equipment in the room after the move.
I was originally looking at the Axiom M22 v3 in-wall's but decided they were probably to much to be abandoned in 6-8 months. I am currently eyeballing the Emotiva UAW 8.2 in-walls but also thinking about the Aperion's as well. Anything else I should be considering in the sub-$500 price range?
practal is offline
Old 09-28-2012, 09:46 PM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
I would take a look at the Atlantic Technology speakers here >
A real good deal - The IWTS-7 LCR
http://store.audioholics.com/clearance/atlantic-technology-iwts-7lcr-s.html
I do not know if the AV Science store, has this one or not.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 09-28-2012, 10:00 PM
realred2's Avatar
I am going to recommend Monoprice.com for speakers (and a bunch of other stuff) at great prices. I put in 2 pairs of their outdoors this summer and have been very happy with them. Will be installing some in ceilings when the attic cools soon.
My "Route 66 Basement Theater" Build Thread
realred2 is offline
Old 09-28-2012, 10:56 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
I would consider the Hsu in-walls as well.
http://www.hsuresearch.com/products/hiw-1.html
ack_bk is offline
