Surround speaker question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-29-2012, 10:04 AM - Thread Starter
biglen's Avatar
Quoted: 109 Post(s)
I'm looking to upgrade my Boston Acoustics Micro VRS surrounds.I'm trying to stay around $200, but I have a question. I have the Denon AVR 890 and an HSU VTF-2 MK4 sub. After running Audyssey, I set all my speakers to small so the sub handles all the bass. Is it really necessary to get a set of surrounds that have a nice size driver if the sub is going to handle all the bass? I was always under the impression that surrounds were meant to just "fill" the rear space. I'm seeing some really expensive surrounds with 5" drivers and it seems like they wouldn't get used to their potential.
biglen is offline
post #2 of 8 Old 09-30-2012, 05:42 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Mid-bass is just as important as the bass. As such, all my speakers have 8" mid-bass drivers.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 8 Old 09-30-2012, 07:45 AM - Thread Starter
biglen's Avatar
Quoted: 109 Post(s)
So the mid bass will still go to the surrounds when all speakers are set to small?
biglen is offline
post #4 of 8 Old 09-30-2012, 03:41 PM
bradymartin's Avatar
Quoted: 33 Post(s)
there is midbass and midrange and your question i still dont know the answer to after months of reading here. i set my 5.0 speakers to small and crossover 80, sub 120. it sounds great and i dont even bother to try and understand frequencies etc. it makes my head spin.
bradymartin is offline
post #5 of 8 Old 10-01-2012, 09:57 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
Most satellite speakers w/ 4" and smaller main drivers tend to roll off around 150 -200 Hz (enormous overgeneralization here) even though they may list an 80 Hz frequency. That's why they tend to sound small compared to larger models.
So, a typical setup will have a hole between the crossover frequency (probably 80-120 Hz) and natural roll off of the surrounds. However, Audyssey and the like will eq each channel to fill in some of that hole. This does work pretty well, but the cost is greater power demands on the receiver and greater excursion and thermal power handling demands on the satellite speaker.
Is it worth it to have a large main driver in the surround? That's kind of up to you.
nograveconcern is offline
post #6 of 8 Old 10-02-2012, 09:54 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Typically, 80 is standard XO to the sub. But with really small speakers, 100~150 htz maybe required.
BUT, mid-bass normally goes to 650~800 hz, typically. So the range of the mid-bass is covering 80~650 or even to 800. And even if the sub XO is @ 150, that is still a 500~650 htz range for the mid-bass driver to cover.
You would be surprised at the amount of bass you hear is in the mid-bass range, instead of the sub.
4DHD is offline
post #7 of 8 Old 10-02-2012, 10:05 AM - Thread Starter
biglen's Avatar
Quoted: 109 Post(s)
biglen is offline
post #8 of 8 Old 10-04-2012, 05:24 AM
Quoted: 91 Post(s)
Liked: 128
Well, those have a published freq plot:
http://www.atlantictechnology.com/Upload/PDFs/reviews/current/2200review_ht.pdf
The bipolar surrounds look like they roll off around 130 Hz and would be down about 7db at 80 Hz. Audyssey should be able to correct for that roll off.
Reply Speakers
