Honest opinions wanted - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-30-2012, 07:43 PM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 107
I'm looking for your opinions on Yamaha's NS-F/B/C-310 speakers.
Proud owner of an Axiom Audio home theatre, powered by Axiom Audio.
brwsaw is offline
post #2 of 6 Old 10-01-2012, 08:51 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
You can do better for the money, unless WAF requires a 4" wide speaker.
The rears don't even have tweeters
40w 87db towers are not going to be capable of much volume
The center had 4 mid drivers making it very wide and killing any chance of off axis dispersion
nograveconcern is offline
post #3 of 6 Old 10-01-2012, 10:18 AM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 107
The center is pretty good. I've got no issues with it.
I would be using 4 NS-F310's and 4 NS-B310's. F310's for front and rears, B310s for front and rear presence.
I've been looking for better for less but haven't found any.
I would like to have all 9 speakers from the same series so this limits my selection.
I'm not against replacing the center...
brwsaw is offline
post #4 of 6 Old 10-01-2012, 10:23 PM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 107
What 8 speaker combo would you go with for under $2000(assuming I keep the center) $2300 if I don't?
brwsaw is offline
post #5 of 6 Old 10-02-2012, 06:21 AM
Quoted: 91 Post(s)
Liked: 128
If you already have the center and it makes you happy then I would stick with what you have. cool.gif I like Yamaha stuff. My main beef w/ these--going purely off specs and since you asked for opinions-- is this spec: 40w 87db. It indicates to me that they will be strained at higher volumes, due to the small drivers.
I've found the Andrew Jones Pioneers sound exceptionally good for the money. I've put together a 7 pc setup for $525 with 2 floor stinging 52's, a c22 center, 2 BS22 highs and Fluance bipolar rears. They have a different aesthetic than what you are going for here, but way under $2k.
post #6 of 6 Old 10-02-2012, 11:41 AM - Thread Starter
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 107
The center will go louder than it needs too and sounds good doing it, shouldn't the towers be roughly the same overall?
brwsaw is offline
Reply Speakers
