Need in-wall LCRs for new basement theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-01-2012, 02:51 PM - Thread Starter
patrcarl's Avatar
I am finishing my basement, and building a multi-functional theater in the basement family room. I'm very budget conscious as the basement cost is going to be about double what we originally expected. I'm doing a front projector with a 92" screen, so the center will be below the screen. The wall behind the speakers is 20" thick brick, and the wall is fully insulated, so I'm not sure how necessary back-boxes will be.
I bought 4 of the Snell in-ceiling speakers for the surrounds which were recommended by zieglj01 and were a phenomenal deal - HERE.
I'd like to stay below $500 for the fronts, and have been recommended the following three:
- Atlantic Technology IWTS-7LCR
- Ethereal SPLCR1 Dual 6.5"
- MORDAUNT SHORT Aw153 Dual 5¼"
I'd greatly appreciate comments on these three options, as well as other budget recommendations to add to the list.
patrcarl is offline
post #2 of 7 Old 10-01-2012, 03:05 PM
smasher50's Avatar
Quoted: 379 Post(s)
Liked: 19205
fwiw, just another suggestion to look at hsu hiw-1 horn loaded speakers highly efficent great for home theater
i'm so laid back,i'm laid out
smasher50 is offline
post #3 of 7 Old 10-02-2012, 01:29 PM - Thread Starter
patrcarl's Avatar
Thanks Smasher.
Any other comments on the three options I threw out, or any other budget recommendations from anyone??
patrcarl is offline
post #4 of 7 Old 10-02-2012, 02:30 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 695
Out of the three I would go with Atlantic Technology on your budget. Hard to beat for your budget.
ack_bk is offline
post #5 of 7 Old 10-02-2012, 04:26 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
This might be your lucky day. I have a pair of C4-IW8P new in box $175. They are made by Atlantic Technology. You coud use IWTS 7 as center. Ship in US only...
Also have pair of C4-IC8P New $175...
PM if interested...
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
post #6 of 7 Old 10-05-2012, 12:18 PM - Thread Starter
patrcarl's Avatar
Audioholics also has this pair of Klipsch Open-Box for $250. Would these be better than the Atlantics?
Klipsch R-2650-W II ($250 for Open Box pair)
Atlantic Technology IWTS-7LCR ($156 each on Clearance)
Or, anything else I should consider?
patrcarl is offline
post #7 of 7 Old 12-04-2012, 01:10 PM - Thread Starter
patrcarl's Avatar
Need to order these LCRs by the end of the week - does anyone have any further feedback on which of these might be best, or suggest any others?
patrcarl is offline
Reply Speakers
