Left, Right & Sub for $600 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-02-2012, 12:07 PM - Thread Starter
Widman's Avatar
As it says in the title, I'm seeking recommendations for a left, right and subwoofer for $600 or less. I've got an Onkyo TX-NR414 and the room is about 21' x 18'. The setup will have the TV on a short wall with a couch about 10' away.
I'd like to start with the LR and add a center and surround when the budget allows. The usage is probably 70/30 ht/music. $600 is really the absolute max I'd like to spend to get the LR and sub in my house.
thanks,
pete
Widman is offline
post #2 of 10 Old 10-02-2012, 08:31 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3077
I'd check out the budget subwoofer thread in the subwoofers forum for ideas on a decent budget subwoofer. The Energy S10.3 is one possible option. Newegg has the KEF iQ70s on sale for $400 for the pair. These towers are a steal at this price. If I were you I would spend that entire $600 on the best pair of front speakers you can get however.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 10 Old 10-02-2012, 10:37 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
Energy s10.3 is sold out on Newegg right now. BIC F12 is a good entry level sub for $200 (check Amazon).
iQ70s are an excellent deal, only you may have problems buying the matching center later on. The series was discontinued, and the center is getting more and more difficult to find.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 10 Old 10-03-2012, 07:05 AM - Thread Starter
Widman's Avatar
Thanks for the feedback.
I don't think the iQ70s are on sale anymore because I'm seeing them for $600 each. Also, I'd really like to get a matching center but that might not happen for 6 - 12 months.
I found the $300 subwoofer thread after I posted this. The BIC F12 looks pretty nice for $200 I can also get the Energy S10.3 from a dealer on Amazon for $270 shipped. Is the S10.3 worth the price difference? Any opinions on the Polk Audio PSW505 for $250?
Going with the F12 leaves me with $400 for the LR. Any suggestions at that price point?
pete
Widman is offline
post #5 of 10 Old 10-03-2012, 07:59 AM
cel4145's Avatar
Liked: 2985
Yep. Looks like they are no longer on sale.
The black Polk Monitor70s are $199 ea at Newegg. The Polk RTi8s are about the same shipped from Frys.
If the PSW505 or S10.3 were close in price to the BIC F12, then going with one of them could be a good choice. But given your budget and the difference in price, better to put it toward the speakers.
cel4145 is offline
post #6 of 10 Old 10-03-2012, 08:25 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
You can get the Infinity P363 towers for $199 ea and the Bic F12 subwoofer for the same price. Then you can add the PC351 center whenever you get the chance.
http://www.amazon.com/Infinity-Primus-P363-Three-way-Floorstanding/dp/B0046A8R3M/ref=sr_1_1?ie=UTF8&qid=1349273777&sr=8-1&keywords=infinity+p363
Or the Polk Monitor 70 for $199 and add the CS2 center when you get the chance
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290208
If you want a horn tweeter the Bic FT6T towers are at a very good price, $153 each
http://www.amazon.com/America-FT-6T-400-Watt-2-Way-Speaker/dp/B002ISZEV2/ref=sr_1_2?s=electronics&ie=UTF8&qid=1349274111&sr=1-2&keywords=bic+tower+speakers
The center is only $110
http://www.amazon.com/BIC-America-FH6-LCR-6-5-Inch-Frequency/dp/B0015A8Y3E/ref=pd_bxgy_e_img_y
And Bic F12 sub is $200
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=pd_bxgy_e_img_y
All that for $617 and you'd have your center speaker now. If you can squeeze the extra $17 out your budget that might be the way to go!
Another Bic option are the DV64 towers and DV62CLR center, $124 each and $100 for the center.
http://www.meijer.com/s/bic-america-dv64-6-5-inch-tower-speaker-black/_/R-124787
http://www.meijer.com/s/bic-america-dv62clr-s-center-channel-speaker/_/R-124785
HTD has some towers that might interest you. $399/pr
http://www.htd.com/Products/tower-speakers/Level-TWO-Tower-Speakers#
The matching center is only $129 which you can get later.
http://www.htd.com/Products/center-channel-speakers/Level-TWO-Center-Channel-Speaker
If you don't want tower speakers then consider the Energy RC LCR which is on sale for $199 each. Then add a 3rd one when you get the chance.
http://www.meijer.com/s/energy-speaker-systems-rc-lcr-center-speaker/_/R-224354
Afro GT
afrogt is offline
post #7 of 10 Old 10-03-2012, 11:03 AM
neverfinished94's Avatar
Quoted: 44 Post(s)
Liked: 26
I just picked up a pair of the Infinity p363's from Fry's for $200 & a Klipsch RW12D from newegg for $300. I cant imagine anything beating this $500 setup. I am beyond satisfied & even my wife cant believe how good it sounds. Now I'm just waiting for a good deal on the pc351.
Check out my just over $5K theater build thread
neverfinished's neverfinished theater
neverfinished94 is offline
post #8 of 10 Old 10-03-2012, 09:40 PM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
To throw another speaker choice into the mix check out the Pioneer SP-FS52.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #9 of 10 Old 10-03-2012, 09:45 PM
afrogt's Avatar
Liked: 755
A good deal on the PC351 is $179.
http://www.amazon.com/Infinity-Primus-PC351-Three-way-Center-Channel/dp/B0044D1788/ref=sr_1_1?ie=UTF8&qid=1349322107&sr=8-1&keywords=infinity+pc351
I don't think Fry's carries that center so it's about as good as you'll get.
you can get the older PC350 for $129 if the silver baffle doesn't bother you.
http://www.amazon.com/Infinity-Primus-PC350-Center-Individually/dp/B000M687JI/ref=sr_1_2?ie=UTF8&qid=1349322107&sr=8-2&keywords=infinity+pc351
Afro GT
afrogt is offline
post #10 of 10 Old 10-04-2012, 05:42 AM - Thread Starter
Widman's Avatar
Thanks for all the replies. I guess I need to get out and listen to some of these options.
Pete
Widman is offline
Reply Speakers
