Monitor60 vs RTI-A5 for my setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-02-2012, 12:14 PM - Thread Starter
Rexxar15's Avatar
Good afternoon,
I'm hoping to get an opinion on which of the two models would fit better in my setup.
I was planning on doing this for a budget build:
Receiver: Onkyo HT-RC160
Front: Monitor60
Center: CS1
Surround: Monitor50
Rear: SP-BS21-LR
Sub: Philips SW-090(replacing asap)
I bought everything except the fronts on sale for $290.00
So now I'm wondering if I should wait for the M60's to drop to around $120 or purchase the RTI-A5's for $200 each. I've read that the latter is better for home theater use, but I'm just worried that they would overpower everything that I've bought.
---Current
http://www.amazon.com/Onkyo-HT-RC160-7-2-Channel-Surround-Receiver/dp/B0028AD7BE
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290204
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290210
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
---Choices
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290156
Rexxar15 is offline
post #2 of 6 Old 10-02-2012, 01:40 PM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 768
They RTiA5 wont over power your other speakers if you setup and calibrate them correctly. However you should probably get the matching CSi14 or A6 center if you're going to go with RTiA series speakers.
Afro GT
afrogt is offline
post #3 of 6 Old 10-02-2012, 08:36 PM - Thread Starter
Rexxar15's Avatar
I ended up ordering the RTiA5's; now to find a good deal on a CSiA6 and sub!
Any ideas on where to look for a sub? I've seen the Klipsch RW-12d on newegg for $300. I've read some good reviews on this forum for it.. Would it fill up a 400 sq ft room well? The ceiling is around 10 feet up. Any other recommendations in that price range?
Rexxar15 is offline
post #4 of 6 Old 10-03-2012, 12:16 AM
afrogt's Avatar
Liked: 768
You need to provide a budget before getting recommendations. How much are you willing to spend on a sub?
Afro GT
afrogt is offline
post #5 of 6 Old 10-03-2012, 12:38 AM
Toksook Bay's Avatar
I have a CsI A6 center in black I'd sell you. I bought it first then ended up going with a Cherry CSI a6 and RTI A5. If your interested in a black one make me an offer. smile.gif. its about 8 months old and used lightly in a HT set up. I have the m60's also and I like them both.
Toksook Bay is offline
post #6 of 6 Old 10-03-2012, 01:40 PM - Thread Starter
Rexxar15's Avatar
I'd like to stay around $300 but I want something that will last me a few years so I'm willing to go higher. I appreciate any recommendations that you can give me.
@Toksook ill send ya a pm, thank you
Rexxar15 is offline
Reply Speakers
