NHT Superzero 2.0's or Cambridge S30/S50? Keep going back and forth. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 10-02-2012, 01:08 PM - Thread Starter
border411's Avatar
I have been reading WAAAY too much about these speakers, and when I think I want one of them I start to look at the other brand. My room is 15'x15' with 9' ceilings. Hard wood floors. Sub will be a BIC F12. Receiver will be a Yamaha V765. I can afford both of these sets for a 5.1 system. Fronts will be in bookcases 18" deep, and the rear surrounds will be mounted from the ceiling in the back corners of the room. The front speakers will be 15' from the listening position (couch against the back wall). Has anyone heard both and can give a good comparison? Is there a dedicated center channel that will work better with the SZ's than just using a fifth one on its side? If there is a better center channel, I need to keep it smaller than the S50 and around the same price. Anyone have any inside secrets about where to get the Cambridges for the lowest price? One Call will discount the SZ's a little, but they only have 1 in stock and dont know when they will get more. Thanks.
~Shaun
Yamaha RX-V765 / PSB B5's Fronts / PSB C4 Center / Micca R-65 In-Ceiling Rears / BIC F12 Sub
border411 is offline
post #2 of 21 Old 10-02-2012, 09:43 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
The SuperZeros are nice mini monitors. However, the S30s have the advantage of some good mid-bass response because of the bigger drivers. I'd choose them over the SuperZeros, especially given the distance of your seating position from the front soundstage.
However, for the price of the S30/S50 set, I'd recommend the Energy RC-10s and RC-LCR. I own both the RC-10s and the Cambridge S30, and prefer the RC series. I realize these are little bit bigger and may not fit your needs, but check them out just in case.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #3 of 21 Old 10-02-2012, 09:48 PM
zieglj01's Avatar
Quoted: 1672 Post(s)
Liked: 1567
Hands down, the Cambridge S30 > and they do have bass.
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 21 Old 10-03-2012, 03:21 AM
smasher50's Avatar
Quoted: 379 Post(s)
Liked: 18961
fwiw, i own a pair of the cambridge audio s30's and also a few pair of more costly speakers and they do a great job in comparison of reproducing music. great bass and mids for such a small speaker. i very rearly see them on sale but sometimes audioadvisor has some open box at discount prices. the nht sz are also nice but lacking in the lower and mids. with your size room the s-30 is more the choice imo. you can save a few bucks by buying the s-20's for the surrounds
i'm so laid back,i'm laid out
smasher50 is online now
post #5 of 21 Old 10-03-2012, 03:48 AM
youngaudiolover's Avatar
Im in the market for a pair of cambridge audio s30's.
Theyre definately worth the money. They also look great.
Excellent speakers destroying many competitors at nearly double the price
youngaudiolover is offline
post #6 of 21 Old 10-03-2012, 12:02 PM
Dayton10's Avatar
Both speakers have the same size drivers.The cambridge have more bass because they are rear ported.May be a problem using in a bookcase as the OP wants.
Dayton10 is offline
post #7 of 21 Old 10-03-2012, 12:10 PM
cel4145's Avatar
Liked: 3002
I think it was zieglj01 that pointed out one time that the S30 drivers are actually more the size of a 5" driver when you examine them closely. But you are right about the porting making a difference in overall bass response.
cel4145 is offline
post #8 of 21 Old 10-03-2012, 01:31 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
No, they don't. Yes, on paper, they're both listed as 4.5" drivers...But if you actually measure the woofer diameter, the S30 is larger... It's close in size to the 5.25" woofers in the NHT Absolute Zero and Energy RC-10 (yes, I measured all three at one point).
The S30 have more bass because they have a slightly larger, more capable woofers, and it's in a larger, ported cabinet.
I agree though, bookcase placement would not be ideal for the S30.
alphaiii is offline
post #9 of 21 Old 10-03-2012, 01:32 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Oops, you already covered it... Didn't even see this before I posted.
alphaiii is offline
post #10 of 21 Old 10-03-2012, 03:54 PM
cel4145's Avatar
Liked: 3002
No. Don't apologize. You've measured them. I couldn't remember who measured the driver. I was guessing Jim since he's Mr. S30 (lol)
cel4145 is offline
post #11 of 21 Old 10-03-2012, 05:24 PM - Thread Starter
border411's Avatar
But I can always pull the S30's out from against the back of the bookcase.....they will be 18" deep so as not to block the porting.
~Shaun
post #12 of 21 Old 10-03-2012, 05:42 PM
zieglj01's Avatar
Liked: 1567
Yes, pull them to the front edge when listening to them - put some bumper feet
under them - keep the top, sides and bottom of the speaker, from touching the
other parts of the cabinet.
Who AM I
post #13 of 21 Old 10-04-2012, 04:26 AM - Thread Starter
border411's Avatar
Got ya Jim. Thanks! Do you have anyplace that you know of where I can get them cheaper? Also, would the S20's be ok for surrounds, or should I just go with (4) S30's and (1) S50?
~Shaun
post #14 of 21 Old 10-04-2012, 07:27 AM
Radio81's Avatar
Quoted: 215 Post(s)
Liked: 81
I was about to pull the trigger on the S30/S50 combo a couple of weeks ago, but crutchfield is out of stock on the S50 centers, and it seems on amazon I can't find a seller with both the S30 & S50. I would prefer to order both from the same place.
Seems not many places carry these online. I would think the S20s would be ok for surround use.
Radio81 is offline
post #15 of 21 Old 10-04-2012, 07:55 AM - Thread Starter
border411's Avatar
Audio advisors has them in stock.
~Shaun
post #16 of 21 Old 10-05-2012, 10:32 AM - Thread Starter
border411's Avatar
Hey Jim.....would you say that the S20's are a good pairing with the S30's? Am I buying myself anything using the S30's for rear surrounds as well?
~Shaun
post #17 of 21 Old 10-05-2012, 10:59 AM
zieglj01's Avatar
Liked: 1567
I answered your PM > the S20 can work for you as surrounds.
Who AM I
post #18 of 21 Old 10-05-2012, 12:12 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 968
The S30 have more bass because they have a slightly larger, more capable woofers, and it's in a ported cabinet.
The S30 is also in a deeper cabinet. 8" deep vs 5.75" for the NHT. So that actually contributes to the deeper bass too.
Afro GT
afrogt is online now
post #19 of 21 Old 10-05-2012, 02:02 PM
zieglj01's Avatar
Liked: 1567
They are 9" deep - their marketing department can not get the dimensions right.
Who AM I
post #20 of 21 Old 10-07-2012, 04:14 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
True... My post is missing the word "larger" before ported... I suppose I should add that.
alphaiii is offline
post #21 of 21 Old 10-07-2012, 04:15 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
I think Jim did as well.
alphaiii is offline
Reply Speakers
Cambridge Speakers S30 N , Cambridge Audio Bookshelf Speakers S30
