KEF LS50 Owners - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 171Likes
Old 06-26-2014, 08:26 AM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 242
My room is similar to yours. 13x27 with 14 foot vaulted ceilings.
With 2 subs in the room to even out the bass.
I sit 9 feet from the Ls50's.
In 2 channel mode with subs on volume is never an issue.
My Sherwood Newcastle 972 at -10 is extremely loud.
During the 15 months with my Ls50's I have considered a larger
amplifier but have yet to see the need.
In 7 channel mode the the room is perfect with movies.
The Trinnov is mostly responsible for correcting this odd room but
the Ls50's really are exceptional.
Steve
tr4a is online now
Old 06-26-2014, 10:37 AM
KEFAmerica's Avatar
Originally Posted by TownsendAvalnch View Post
Thank you for the replies and the links to those blog entries. The problem I am running into is that there are so many subtly different numbers, but those differences are extremely important. Example: blog entry 3 lists power out, minimum power out, and maximum power out as three important numbers to know. Max is peak-to-peak. Minimum is continuous rating. Which is all fine.
However, looking at actual amplifier or receiver specs, they generally only list one number (like "power output") and do not specify how that measurement is taken or what the range is. Then I have the problem of matching "speaker power rating" to amplifier specs, when the numbers for BOTH components could be measured in slightly different (but important) ways. Example: KEF LS50 "amplifier requirements" are 25 to 100 Watts. Are those continuous or peak to peak numbers? Is that the power rating of the speakers as well, or just the amplifier (or are these the same)? I'll fry the speakers if I pick an amp that has a continuous rating ~100 Watts (I think). But I don't want to go too low either. Then I also need to multiply the numbers by a factor to find the right power "range". Etc. It's incredibly confusing. Mainly because there are different ways to measure power and there is no consistency between reported specs.
Other problem is that I live in an apartment that has thick concrete between the units, but I'm not sure how thick or how well it absorbs sound. Maybe a sound system that reaches 105 dB will be completely unnecessary as I won't ever play it that loud? Because of this I am mostly interested in sound clarity, so I'm guessing a mini-monitor like the LS50 makes sense even if the SPL at my listening position doesn't reach 105 dB, but I'm not 100% sure on that.
Hi,
The KEF LS50 is rated for 25w - 100w of continuous power. If you are unsure of the specified rating of an amplifier, it would be best to contact the amp manufacturer.
Sincerely,
KEF America
KEFAmerica is offline
Old 06-26-2014, 12:08 PM - Thread Starter
wse
wse's Avatar
Quoted: 2146 Post(s)
Liked: 785
Originally Posted by KEFAmerica View Post
Hi,The KEF LS50 is rated for 25w - 100w of continuous power. If you are unsure of the specified rating of an amplifier, it would be best to contact the amp manufacturer.
Sincerely, KEF America
So I would assume that this amp should be good enought, yes?
- Parasound A23 http://www.parasound.com/halo/a23.php
wse is online now
Old 06-26-2014, 01:06 PM
KEFAmerica's Avatar
Hi,
The Parasound A23 is rated at 125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven,so it will have no problem powering the KEF LS50. Whether you like the combination of a Parasound Amp with the KEF LS50 is your subjectivity.
Sincerely,
KEF America
Old 06-26-2014, 06:26 PM - Thread Starter
wse
wse's Avatar
Liked: 785
Hi,
The Parasound A23 is rated at 125 watts RMS x 2, 20 Hz - 20 kHz, 8 Ω, both channels driven,so it will have no problem powering the KEF LS50. Whether you like the combination of a Parasound Amp with the KEF LS50 is your subjectivity. Sincerely, KEF America
Any recommendations?
wse is online now
Old 06-26-2014, 08:01 PM
jima4a's Avatar
Quoted: 276 Post(s)
Liked: 147
I would think Parasound Halo would match up quite well.
jima4a is online now
Old 06-26-2014, 10:57 PM
steveting99's Avatar
Quoted: 1835 Post(s)
Liked: 631
Using the worked example on KEF blog, here is the continuous power range for LS50 per speaker basis.
Minimum continuous power = Min power rating of speaker x 2 x 1.25 = 25 x 2 x 1.25 = 62.5W
Maximum instantaneous power = Max power rating of speaker x 2 x 1.25 = 100 x 2 x 1.25 = 250W
So you would look for an amp that has a continuous rating per channel in the above range. The Parasound Halo A23 2-channel amp fits into this range (125W per channel at the LS50 nominal impedance of 8 ohms). Some members have reported a good match between the LS50 and Parasound amps.
Rating by KEF is for continuous power. See worked example above on the amp power range. The amps are nominally rated for maximum continuous power. Look for amps that have low THD (<1%) at the speaker nominal impedance rating of 8 ohms. Better yet, check with the amp supplier if 4 ohms is supported as the LS50 goes down to 3 ohms. Using the Parasound Halo A23 as an example, it has a THD of <0.06% at full power. This is very good. It also supports both 8 ohm and 4 ohm loads, so no problem with the LS50.
105 dB is extremely loud at the Main Listening Position, but it's a transient condition (think of an explosion scene in a movie). The reference level is nominally set at 85dB (movie theater reference) and most people find this to be too loud. People would generally turn it down by some amount. By how much is a preference thing.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
Old 06-27-2014, 06:39 AM
Bill_B4's Avatar
Quoted: 14 Post(s)
I've seen KEF demoing the LS50s with Parasound Halo gear and Arcam FMJ gear. I didn't care for the A23 paired with them and a Benchmark DAC2 HGC but you might.
I'm swapping out my 30" Sanus NF30 stands for a set of NHT P6 pedestals, they match the LS50s pretty well (not my setup as I don't have the pedestals yet):
Bill
ID:	137873   Click image for larger version
ID:	137881   Click image for larger version
schowtyme likes this.
Bill_B4 is offline
Old 06-27-2014, 07:49 AM
KEFAmerica's Avatar
Hi,
KEF doesn't recommend any specific accompanying equipment (amps, stands, cables, DACs...etc.) since everyone's needs and preference are different.
Sincerely,
KEF America
Old 06-27-2014, 12:17 PM
drewTT's Avatar
Quoted: 575 Post(s)
Liked: 606
Hi,
Sincerely,
KEF America
This amp is perfect for the LS50s in my nearfield setup. It has all the transparency you could ever ask for. I did add a tube pre-amp to take the slight edge off my system due to my DAC. The system sounds sublime with this setup.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
Old 06-27-2014, 01:27 PM
Ximori's Avatar
Quoted: 174 Post(s)
Liked: 78
Early this year I visited a local dealer, listened to an Anthem Integrated 225 and was awestruck by the detail and clarity coming from the speakers. It was driving a Triton 7 so I knew this amp will easily drive the LS50s as well...for an even better output.
Ximori is offline
Old 06-27-2014, 05:42 PM
Bill_B4's Avatar
Quoted: 14 Post(s)
I think the DAC was the issue with the sound I was getting with my A23 as well.
Bill_B4 is offline
Old 07-02-2014, 06:53 AM
jkhome's Avatar
Quoted: 93 Post(s)
Liked: 60
I have a question for KEFAmerica. If one is using the port plugs, obviously it reduces the bass output of the speakers. But my question is, does it also increase the performance ability or efficiency of the driver in anyway, such as the same if one were to place a high pass filter in the circuit upstream?
jkhome is offline
Old 07-02-2014, 07:20 AM
KEFAmerica's Avatar
Hi JKhome,
The answer is no. The port plug simply changes how the speaker reacts within the room it is placed and has nothing to do with speaker efficiency or electrical performance.
Sincerely,
KEF America
Old 07-02-2014, 09:30 AM
jkhome's Avatar
Quoted: 93 Post(s)
Liked: 60
Hi JKhome,
Sincerely,
KEF America
OK, thanks. Nice to have the port plug option anyway.
jkhome is offline
Old 07-02-2014, 01:38 PM
Ximori's Avatar
Quoted: 174 Post(s)
Liked: 78
KEFAmerica - with Pioneer ahead of the ballgame, is there anything KEF is planning on the horizon for Dolby Atmos?
Ximori is offline
Old 07-02-2014, 01:49 PM - Thread Starter
wse
wse's Avatar
Liked: 785
wse is online now
Old 07-02-2014, 02:18 PM
Slickman's Avatar
Quoted: 133 Post(s)
Liked: 91
If the port is plugged can they be put right against a wall for surround duty?
Slickman is offline
Old 07-02-2014, 05:27 PM
jkhome's Avatar
Quoted: 93 Post(s)
Liked: 60
How does the plug affect the sound of the LS-50?
It reduces the bass output of the speaker. If the speaker is set close to a surface such as a wall or in a cabinet, the speaker can get more bass boom. The plugs help reduce this. If you have the owners manual, it shows the distances recommended for partial or full port plugging.
In my case, the rear ports of the speakers are 20" from the sidewall. But also I wanted to reduce the bass output so that the mid bass subs I use located right next to the KEFs can be ran higher. Works great.
jkhome is offline
Old 07-02-2014, 05:28 PM - Thread Starter
wse
wse's Avatar
Liked: 785
Hi,
Sincerely,
KEF America
How would the Pioneer Class D3 Amplification sound with the KEF LS50? Has any one tried and what did you think?
http://www.pioneerelectronics.com/ep...0Sheet_v13.pdf
wse is online now
Old 07-02-2014, 05:29 PM - Thread Starter
wse
wse's Avatar
Liked: 785
In my case, the rear ports of the speakers are 20" from the sidewall. Also I want to reduce the bass output so that the mid bass subs next to them can be ran higher. Works great.
They don't take in consideration the fact that you can use crossover? Why not just setting the crossover at 80HZ and no plugs problem solved
So they say:
< 7.87 inches from the back wall both plugs
< 19.685 inches from the back wall one plug
> 19.685 inches from the back wall no plugs
http://www.kef.com/uploads/files/en/...iew_250412.pdf
In addition I tried stands at 24" and 30" I like it better at 30"
wse is online now
Old 07-02-2014, 06:04 PM
jkhome's Avatar
Quoted: 93 Post(s)
Liked: 60
So they say:
Yes that's one way to do it, but in two channels systems, and in other apps, alot of folks don't run their mains through a crossover. I run my KEFs full range (via a two channel diy tube preamp), and then cross over the subs downstream.
I actually went the other way with the speaker height. Started out with the speakers on Isoacoustic platforms, sitting on 24" stands (which equaled around a 30" height). But settled with the speaker directly on the bottom stand, at a 24" height. Smoothed out the highs perfectly in my setup that way.
Speaker positioning is a big part of making these speakers sound great, so it just takes some experimenting to find out what works best for each individual system.
jkhome is offline
Old 07-03-2014, 12:10 AM
Liked: 631
LS50 owners,
Would like to know if anyone has paired their LS50 with Emotiva XPA-1L mono blocks? These mono blocks have a unique feature of operating as class A amp up to 35W (this is greater than the lower limit recommended by KEF's amp sizing blog) and switches to class AB beyond 35W up to 250W (which is beyond the upper 160W limit). One has to take care in prevent over driving the LS50+XPA-1L via the pre/pro.
When the amp is operating in pure class A mode, there is no switching at the zero point and hence no harmonic distortion (the odd order such as 3rd, 5th, 7th, 9th, etc.) that can cause listening fatigue. The downside to class A operation is that the transistors are operating all the time, hence the amp gets hot and is not very efficient.
So for low to medium level listening, I'm thinking this would be a nice combo; KEF LS50 + Emotiva XPA-1L. Currently Emotiva has the XPA-1L on sale to make way for the 2nd generation units.
Old 07-03-2014, 03:24 AM
Bill_B4's Avatar
Quoted: 14 Post(s)
Originally Posted by steveting99 View Post
LS50 owners,
The meters on my amp rarely ever read higher than 1W of output so I'd think those Emotivas would be fine, as long as you're not in a huge room or trying to pretend the KEFs are a PA system.
Bill
Bill_B4 is offline
Old 07-09-2014, 06:10 PM
Bill_B4's Avatar
Quoted: 14 Post(s)
So the NHT pedestals in my post above are the P5. Those are slightly shorter, narrower, and shallower and do not come with the outrigger feet that the P6 I ordered does. I just got them tonight so these are only initial impressions:
  • They're heavy - 3/4" MDF wrapped in some sort of veneer and weighing in at over 20 lbs.
  • They don't match exactly but they're damn close. They're the same shade of gray as the front baffle of the LS50 but they've got a metallic, car-like finish.
  • They're stable - MUCH more stable than the stands they're replacing.
  • With spikes on carpet and a bit of Blu-Tak in between them and the speakers they put the tweeters at 34" which is about an inch lower than my previous stands. I don't notice much of a difference in sound but the LS50s are fairly even off-axis so I'm not surprised.
They must have been NOS because they shipped from NHT's Benicia, CA address but that wasn't the user-name on eBay.
Bill
ID:	154897   Click image for larger version
ID:	154905   Click image for larger version
Bill_B4 is offline
Old 07-14-2014, 05:40 AM
pocoloco's Avatar
Looks great. but doesn't a big stand like this introduce diffraction effects, undermining the LS50s curved baffle?
pocoloco is offline
Old 07-14-2014, 10:24 AM
Bill_B4's Avatar
Quoted: 14 Post(s)
I had a few hours yesterday to finally do some extended listening and I'm not hearing any effect from the stands, good or bad, so that makes me a happy camper.
The slight difference in height hasn't been an issue and during deep bass passages I don't hear or feel them resonating.
Bill
Bill_B4 is offline
Old 07-14-2014, 10:59 AM
Ximori's Avatar
Quoted: 174 Post(s)
Liked: 78
The stands I would like to get for my LS50s are these but I can't seem to find them locally.
http://www.darkhorse.ca/Q-ACOUSTICS-...air_p_321.html
Ximori is offline
Old 07-16-2014, 01:12 PM
Ximori's Avatar
Quoted: 174 Post(s)
Liked: 78
I think these LS50s will make great Atmos speakers. It has such great sense of depth, especially in near-field applications, that they make the room disappear and just immerse you into that 3d soundfield. I even like it more for this, than their soundstage quality.
Anyhow, I'm really hoping that they come out with something that can be mounted on the ceiling as well.
Ximori is offline
Old 07-16-2014, 06:08 PM
Liked: 631
^I've talked to KEF and asked if the E301 satellites can be timber (voiced) matched with the LS50. The answer came back positive.
Haven't asked about the combination of LS50 + T301 wall mounted units.
I'm thinking either the E301 or T301 can be combined with the LS50 as the ceiling Atmos speakers for the new object based audio that's coming out in September of this year.
Depending on how fast the Atmos hype train moves along, it's going to be interesting times ahead for all of us.
SMHarman likes this.
Kef Ls50 2 Way Speaker System
