KEF LS50 Owners - Page 35 - AVS Forum
 13Likes
post #1021 of 1035 Old 10-13-2014, 01:07 PM
AUDIOgiant's Avatar
Quoted: 57 Post(s)
Originally Posted by wse View Post
Yes those R50 are very pricey, they look like they could fit on top of the LS50?
I tried installing them on the top, and was not happy with the result! I think on or in ceiling is a better solution Oh well
Did you just put them on top or did you try angling them up towards the ceiling?
AUDIOgiant is online now
post #1022 of 1035 Old 10-13-2014, 01:43 PM - Thread Starter
wse
wse's Avatar
Quoted: 540 Post(s)
Liked: 363
I just put them on top, I can't really angle them too worried they would fall!
wse is offline
post #1023 of 1035 Old 10-17-2014, 04:42 PM
tractng's Avatar
Quoted: 17 Post(s)
Liked: 25
Originally Posted by coli View Post
Don't do it. The LS50 is too good for most subwoofers.
The attached picture is the only setup where the subwoofer managed to integrate perfectly into the LS50.
Is that a parasound amp in the background? A21?
tractng is online now
post #1024 of 1035 Old 10-17-2014, 04:49 PM
tractng's Avatar
Quoted: 17 Post(s)
Liked: 25
So can I use the Kef E301(still in the box) and place on top of my LS50 for more Atmos speakers?
I already have 2 ceiling speakers.
post #1025 of 1035 Old 10-17-2014, 05:34 PM
drewTT's Avatar
Quoted: 38 Post(s)
Liked: 91
That's awesome. lmao
drewTT is online now
post #1026 of 1035 Old 10-17-2014, 07:04 PM
steveting99's Avatar
Quoted: 260 Post(s)
Liked: 107
Hi tractng,
Which Atmos configuration are you going for?
  • 5.1.2
  • 5.1.4
  • 7.1.2
  • 7.1.4
  • 9.1.2
If you haven't done so already, download the Dolby Atmos Home Theater installation guide here: http://www.dolby.com/us/en/guide/dol...tup/index.html
Maranatz NR1504, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
Last edited by steveting99; 10-17-2014 at 07:05 PM. Reason: additional text added for clarity
steveting99 is offline
post #1027 of 1035 Old 10-19-2014, 12:16 AM
tractng's Avatar
Quoted: 17 Post(s)
Liked: 25
Originally Posted by steveting99 View Post
Hi tractng,
  • 5.1.2
  • 5.1.4
  • 7.1.2
  • 7.1.4
  • 9.1.2
5.1.2 (2 on ceiling)
post #1028 of 1035 Old Yesterday, 01:23 AM
Liked: 0
Guys can you please tell me if the LS50's can be driven by a Burson Conductor LS S9018 ?
I'm from Headfi and new to speakers I have the Burson Conductor driving my Sennhiser HD 650 Headphones, and don't want to spend more on a receiver unless absolutely required.
I will be using the LS50's with my computer to listen to my FLAC music collection, mostly vocal.
Thank you very much.
I can't post a link to the Burson Audio Conductor LS S9018 because I'm new here.
slair76116 is offline
post #1029 of 1035 Old Yesterday, 03:01 AM
Quoted: 260 Post(s)
Liked: 107
Hi slair76116,
Welcome to AVS!
The Burson Audio Conductor LS S9018 is a DAC for driving headphones. I can't see any analogue outputs that would allow it to drive a separate amp and the LS50 speakers.
There is also no bass management function that would allow integration with a sub. The LS50 design in the white paper has the frequency roll off starting from 100Hz and the -3dB rating is around 80Hz. The driver will start to distort below this.
Afraid you'll need at least a receiver to drive the LS50 as the low cost option.
post #1030 of 1035 Old Yesterday, 07:11 AM
mlknez's Avatar
Quoted: 20 Post(s)
Hi slair76116,
Welcome to AVS!
Why a receiver? Why not an integrated amp or simple, low cost amp like the Emotiva Mini-x a-100?
mlknez is offline
post #1031 of 1035 Old Yesterday, 07:32 AM
Liked: 0
Hi Guys,
The Burson Conductor SL S9018 has 4 speaker outputs at the back. 2 Preamped for normal speakers without a volume control and 2 normal RCA connectors for powered speakers.
Maybe you guys mistook my Burson Conductor to the Burson Solo ?
Sorry but I still Can't post any pick or links since I just joined AVS.
post #1032 of 1035 Old Yesterday, 07:54 AM
Liked: 0
Hi Guys,
Please disregard above, It's my mistake
So all I would need is a good amplifier ?
If so what would be a good amplifier to match with the LS50 to listen to my FLAC Audio tracks on the PC. No budget constraints. Something that will not hold the LS50's back and would allow it's full potential ?
post #1033 of 1035 Old Yesterday, 10:35 AM
drewTT's Avatar
Quoted: 38 Post(s)
Liked: 91
Parasound Halo. KEF themselves demo'd the LS50s with Parasound A21. I use the A23 due to nearfield setup.
post #1034 of 1035 Old Yesterday, 05:55 PM
Quoted: 260 Post(s)
Liked: 107
The LS50 is a mini-monitor that cannot re-produce the full range frequencies from 20Hz to 20kHz. Independent tests show distortion levels increasing below 100Hz. Thus a sub which can take over from the LS50 below the crossover level is a reasonable way to reproduce the full signals.
To enable a crossover at a certain frequency, there must be bass management. All modern receivers have bass management, but not all integrated amps do.
Generally there are more features available on a receiver than an integrated amp - at a lower cost. One can always switch the receiver to DIRECT/PURE DIRECT mode to compare without bass management.
If the source is a PC, there are a number of ways of sending the digital signals to the receiver for decoding - choose one that's the most convenient.
post #1035 of 1035 Old Today, 05:47 AM
jkhome's Avatar
Quoted: 34 Post(s)
Another inexpensive option that may work for you is a Crown DriveCore 1500 class d amp, has a built in (but defeatable) high pass filter. I'm trying one out on my LS50s right now.
jkhome is offline
Reply Speakers
Kef Ls50 2 Way Speaker System
User Tag List
