KEF LS50 Owners - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 191Likes
post #1081 of 2399 Old 11-23-2014, 05:23 PM
steveting99's Avatar
Quoted: 1842 Post(s)
Liked: 641
Originally Posted by ricemanhk View Post
Thanks Steve. Ceiling height is about 9 feet.
Do you think the KEF T2 subwoofer (250W) is sufficient?
ricemanhk,
Total room volume is about 2,200 cu. ft. which works out to be on small to medium sized room. I'd go something a bit better than the KEF T2, as the 10" driver and limited frequency range isn't appealing. Look for a pair of 12" subs from the following ID companies.
  • Rythmik
  • SVS
  • PSA
  • HSU
  • Reaction Audio
Others might want to chime in on their favorite sub supplier recommendations.
Forgot to answer your question regarding speaker setup. If you're interested in Atmos the following speaker configuration for a 5.1.4 setup shows the angles.
The often posted Denon/Marantz Atmos diagram:
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
Last edited by steveting99; 11-23-2014 at 08:52 PM. Reason: additional text for and picture for clarity
steveting99 is offline
post #1082 of 2399 Old 11-27-2014, 03:48 AM
jkhome's Avatar
Quoted: 103 Post(s)
Liked: 66
Originally Posted by coli View Post
Going to have to agree with the manual's 45 degree toe-in, it helps to preserve the most bass dynamics at the listening position, which is the LS50's weakest spot.
I also find the speaker's high treble performance gains from this also, along with the soundstage and imaging.
In my room, where I have to sit fairly close to the rear wall (at a desk/bookcase combo ), aiming the speakers right at the chair caused some excessive high frequency reflections. So now I place a couple of 2' x 2' x 4" absorber panels, side by side on the desk when critically listening. Made probably one of the biggest improvements of all the room treatments placed in the room.
In the future this furniture will be out of there, so I can do something more permanent on that wall. Probably try some skyline diffusers.
Of all the discussions about room treatments, the rear wall gets the least amount of "press", but it is the wall that gets the largest amount of energy blasted at it.
jkhome is offline
post #1083 of 2399 Old 11-27-2014, 07:48 PM
Quoted: 28 Post(s)
Liked: 5
I'm considering the REL T5 sub to match with Marantz SR7009 and 3x LS50s for FL/C/FR and 2x KEF E301 for surrounds. I would use the system for about 60% music (2.0 or 2.1) and 40% movies.
Questions:
- my room is around 200 sq foot, would the T5 be sufficient? I don't need alot of thump (it's an apartment so don't want neighbors complaining either)
- I know REL subs can do LFE + high level input. With the AVR, do I still need to use the high level input or just let the AVR/audyssey manage the bass crossover through the LFE input only?
- If using high level input with the LS50, would there be any problems running the LS50 full range? I know the LS50s aren't very flat below 79Hz, and they can also get down to 4 ohms for lower frequencies so I originally wanted to pass all of the lower frequencies to the sub so there's more headroom in the AVR for the LS50s.
ricemanhk is offline
post #1084 of 2399 Old 11-27-2014, 11:16 PM
Liked: 641
Questions:
- If using high level input with the LS50, would there be any problems running the LS50 full range? I know the LS50s aren't very flat below 79khz, and they can also get down to 4 ohms for lower frequencies so I originally wanted to pass all of the lower frequencies to the sub so there's more headroom in the AVR for the LS50s.
Measurements for the REL T5 sub is here: http://www.soundandvision.com/conten...-labs-measures
Take away is roll off of -3dB at 43Hz. This isn't great and questionable for the T5 to reproduce the bass guitar's E1 note at 41Hz cleanly. Refer to frequency spectrum of musical instruments here: http://www.independentrecording.net/...in_display.htm
post #1085 of 2399 Old 12-01-2014, 05:32 AM
xhattan's Avatar
Quoted: 60 Post(s)
Thanks! There were some interesting use of Hockey Pucks and Cement Blocks on there! LOL
Anyone use these?
http://www.musiciansfriend.com/acces...ics-technology
Here is my setup in my office, but I want a decent stand to move into my main room.....
[/QUOTE]
What are you using under the LS50´s? Are they foam or cork?
xhattan is offline
post #1086 of 2399 Old 12-01-2014, 09:04 PM - Thread Starter
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 809
wse is offline
post #1087 of 2399 Old 12-01-2014, 09:09 PM - Thread Starter
wse
wse's Avatar
Liked: 809
Anyone use these?
Thanks![/QUOTE]
Primacoustic RX7 Recoil Stabilizers
wse is offline
post #1088 of 2399 Old 12-02-2014, 02:33 PM
xhattan's Avatar
Quoted: 60 Post(s)
Hello guys:
I currently own a 9.2 setup comprising all 9 KHT 3005SE satellites and 2 HTB2 subs. Connected to a Pioneer Elite SC-75 receiver with D3 class amps. I love it but I feel i´m ready for an upgrade and I reaaaaaally want this LS50´s for fronts. I used them equally for both movies and music.
Room is 15" x 13".
Questions:
1. Will my current 3005 satellites and center channel be a good pair to the LS50? They all have the Uni Q technology too.
2. I know the HTB2 is not that well regarded here, but considering the medium size of my room and that I would be using 2 of them, would they serve me well?
3. I will buy a Denon or Marantz receiver, with XT32 for room calibration, in the near future, and the Marantz MM 7055 (5 channel amp) to run solely the LS50, but in the meantime is the Elite a good match? It boats 140 wpc and has been driving the 3005 effortlessly.
xhattan is offline
post #1089 of 2399 Old 12-02-2014, 03:34 PM
drewTT's Avatar
Quoted: 823 Post(s)
Liked: 831
Surrounds should be fine but I would definitely do a third LS50 for the front stage.
LG OLED65E6 | ARC DSi200 | Dynaudio Special Forty | Oppo UDP-205 | Maingear Drift GTX 1080 HTPC | audioquest CV-8 - Carbon - Columbia | BDI Mirage 8227 | Synology DS916+ | Apple TV 4K
drewTT is offline
post #1090 of 2399 Old 12-02-2014, 07:58 PM
Liked: 641
Hello guys:
Room is 15" x 13".
Questions:
Hi xhattan,
1. If you run Audyssey, it will equalize each speaker to a target curve. As such when listening with Audyssey engaged, you might not hear much of a difference. In DIRECT/PURE DIRECT mode, there is no equalization applied and as such you may hear an audible difference. Having the same brand and range of speaker makes the audible differences smaller.
2. Each HTB2 sub has a 10" driver. Whether a pair is okay is very dependent on room volume. Your floor area is 195 sq. ft. What is the floor to ceiling dimensions? If it's around 8', then a pair of 10" drivers placed in the appropriate location should give you sufficient output. My only concern is the lower frequency range being 30Hz, KEF didn't specify if this is the -3dB point.
3. How far away from the speakers do you sit? This is commonly referred to as the Main Listening Position (MLP) and generally getting to reference level means reaching peak SPL of 105dB. Amplification power is dependent on speaker sensitivity and the 'throw' distance to the listener. If you can't achieve this, you'll have to move the speakers a bit closer, turn the volume down or limit the power output. The decision to go with external amplification should be based on the ability to achieve reference level.
post #1091 of 2399 Old 12-03-2014, 06:21 AM
xhattan's Avatar
Quoted: 60 Post(s)
Originally Posted by steveting99 View Post
Hi xhattan,
Thanks a lot Steve. Just some minors inquiries about your comments:
1. Does this means that Audyssey will upgrade the sound of my 3005 eggs or downgrade the sound of the LS50? The eggs are very good speakers and play at reference levels or above with no stress or distortion whatsoever, warm and very detailed sound. Blend perfectlly with the HTB2SE and the Elite AVR.
2. KEF´s webpage states that the 30Hz frequency is (+/-3db) for the HTB2SE sub. My ceiling is 8" high and one sub would be on the front and the other at the back of the room.
3. MLP is 9". As I said, movies and music at reference level (not very often, only when I´m alone) sound great, usually in Direct Mode or in a THX mode. So, are you saying that maybe I don´t need an amplifier and a top of the line Denon or Marantz can do the job on their own?
Again, thanks a lot pal.
xhattan is offline
post #1092 of 2399 Old 12-03-2014, 06:44 AM
xhattan's Avatar
Quoted: 60 Post(s)
Thumbs down
Thanks Drew!
Out of budget, but would consider if I don´t have to buy a new amp or receiver. Hell, I would go for the full 5 LS50 package and 6 of the 3005 eggs for wides and Atmos for full 7.2.4 setup!
Hummmm..... Maybe if I swap the Elite for the Denon X4100 and get the Marantz MM7055 for extra channels. Oh man, and get a divorce now that I´m at it!
xhattan is offline
post #1093 of 2399 Old 12-03-2014, 09:53 AM
drewTT's Avatar
Quoted: 823 Post(s)
Liked: 831
Thanks Drew!
If your 3005 doesn't gel as a center with the LS50s you can always run a phantom center. I don't have a center and, honestly, do not miss it.
drewTT is offline
post #1094 of 2399 Old 12-03-2014, 05:57 PM
Liked: 641
1. No it won't up-grade the KEF 3005 eggs nor downgrade the KEF LS50. What room equalization (REQ) does is compensation for the room anomalies based on a target curve. This is done via test tones from the speaker and received at the microphone which is then processed via algorithms on the receiver and implemented in real time by the DSP chips. The correction applied to each speaker is like the inverse function of the actual received signals by the microphone in the form of minimum phase filters. For example - a 10dB peak at 250Hz is brought down to the target curve or a 10dB dip at 80Hz is brought up by 6dB to the target curve. This will then smooth the in-room response for each speaker so that each speaker is equalized to a target curve, thus they tend to sound similar.
2. Was looking at the owners manual for the HTB2SE sub, but good to know that 30Hz is the -3dB point. If you haven't done so already, a simple sub crawl test as outlined in the following youtube video by Axiom Audio will give options on where to put the sub in the room:
3. Using the following web app: http://myhometheater.homestead.com/splcalculator.html, with the LS50 speaker sensitivity of 85dB/W/m, MLP being 9' away and assuming the speakers are corner loaded to the wall (1.5' to 2') in a two-channel stereo setup configuration the power requirement on a per channel basis is 95W to reach a peak of 105dB at the MLP.
If you use the same speakers for the front sound stage consisting of LS50 (i.e. front left, center and front right), then on a per channel basis the power requirement is just 63W to reach a peak of 105dB at the MLP.
Going with all LS50 in a 5.0 surround sound setup, the power requirement on a per channel basis is just 38W to reach 105dB peak at the MLP.
These are easily achievable with most modern receivers (such as Denon/Marantz) and within the power limits of the LS50. So yes, you don't need external amp in this setup. The important factor is placement of the speakers in the room and the 'throw' distance between the speaker and the MLP. Changing these parameters will drastically change the amp power requirements. Note that KEF has stated that the LS50 has a maximum continuous power rating of just 100W and exceeding this may damage the driver.
Additional note, most people will find listening at reference level to be too loud and uncomfortable. Generally the Main Volume is set much lower than this (around -20dB) and this helps reduce the power demand of the amp by a factor of 100x less. I.e. less than 1W in 2-channel mode given the calculations above.
post #1095 of 2399 Old 12-05-2014, 02:12 AM
nirvy111's Avatar
Quoted: 119 Post(s)
Liked: 39
Are these speakers still highly regarded or is there better for the money these days? How do they compare to the Ascend Sierra 1 or 2's for example, which are bookshelf speakers I've also considered?
nirvy111 is offline
post #1096 of 2399 Old 12-07-2014, 02:50 PM
nakenergy's Avatar
I would also like to know the compare to SVS Ultra bookshelfs if anyone has listened to them. Are these seriously music speakers or could be used for movies too? My dealer just demoed the music piece as he had not home theater set up. How is the LS 50 as a center speaker? I believe you can keep this horizontally?
nakenergy is offline
post #1097 of 2399 Old 12-07-2014, 03:52 PM
AUDIOgiant's Avatar
Quoted: 365 Post(s)
Liked: 83
These are originally intended to be music speakers That's why they are marketed a monitors primarily and not HT speakers. With that said, several of us have purchased multiples for HT use and it works great. Personally I have them hooked up to a Marantz AVR and am very satisfied for both music/HT usage. Others probably have more sophisticated setups. Works great as a center speaker, my frontstage is seamless, and I've heard there is no issue placing these horizontally because of its single woofer uni-q design.
PSN: dagreeng
AUDIOgiant is offline
post #1098 of 2399 Old 12-07-2014, 08:48 PM
adidino's Avatar
Quoted: 367 Post(s)
Liked: 282
You really can't do much better than the LS50 at that price point. It's also possible to order a half pair and mount the LS50 horizontally. The UniQ driver is not sensitive to orientation.
sdg4vfx likes this.
adidino is offline
post #1099 of 2399 Old 12-08-2014, 09:42 PM
Garman's Avatar
Quoted: 1358 Post(s)
Liked: 611
Mr. SoftDome: My mistake as that is a quote but the picture came up different! LOL
To answer xhattan questions: Rubber on metal on foam, and they sound quite preform quite good on those bookshelf stands!
Garman is offline
post #1100 of 2399 Old 12-09-2014, 11:47 AM
eshaun's Avatar
Liked: 0
I'm curious for those who have tried it, have you been satisfied with using a pair of LS50's as rears for movies and multichannel audio, or regretted that decision? Given the recent sale price of LS50 vs R100 seemed like a no brainer to me.
eshaun is offline
post #1101 of 2399 Old 12-09-2014, 04:30 PM
rec93's Avatar
Amp help
Hi,
I just bought a LS50 pair and the Yamaha A-S500 integrated amp.
Do you think I have something to worry about this combo? I ask because this LS50 are considered high end speakers, unlike the Yamaha amp.
Specs-wise I don't see a problem, do you see it that way?
I'll appreciate any comments. I sold a Parasound 2100 + Parasound 2125 set and now I'm wondering if that was a mistake. I'm talking about sound quality, not spl. This will be my 2.0 bedroom system.
Rodolfo
rec93 is offline
post #1102 of 2399 Old 12-10-2014, 02:21 AM
winwinc81's Avatar
Quoted: 124 Post(s)
Hi LS50 users.....
am currently using KEF R700 as mains, R600c center and R300 as surrounds. using 2 x TC Sounds 5400 ultra as subs and behringer 6k DSP as bass management.
wanted to put front height and rear height speakers to use future Auro 3D setup (and possibly atmos).. i am deciding to use what speakers.... should i use LS50, E301, R100 or R300? or can the T series match what i am having?
can more experience people here give me some advise??
winwinc81 is offline
post #1103 of 2399 Old 12-10-2014, 05:59 AM
galvs's Avatar
Originally Posted by rec93 View Post
Hi,
Rodolfo
Yamaha A-S500 is as good as any other amp with similar specs, just cheaper
My LSs are beautifully powered by an old HK3485.
galvs is offline
post #1104 of 2399 Old 12-10-2014, 06:56 AM
mlknez's Avatar
Quoted: 222 Post(s)
Liked: 60
Hi,
Rodolfo
That amp will work just fine for you. It has more than enough power and the frequency bandwidth is great as are the distortion numbers. The real test will be your content quality and the quality of DAC if you will use digital content.
mlknez is offline
post #1105 of 2399 Old 12-10-2014, 08:01 AM
rec93's Avatar
Thanks Galvs,
That HK3485 is very well regarded by many.
I hope the Yamaha is as good as that one.
rec93 is offline
post #1106 of 2399 Old 12-10-2014, 02:51 PM
rec93's Avatar
Hi Mlknez,
Sources:
Flac files stored in NAS to Squeezebox touch through a Wyred4sound DAC-2.
Cheap Sony blu-ray player through same DAC.
I'm not so convinced about the need of this DAC now, but I can't sell it in my country, then it's available.
rec93 is offline
post #1107 of 2399 Old 12-10-2014, 03:52 PM
AUDIOgiant's Avatar
Quoted: 365 Post(s)
Liked: 83
I enjoy mine very much, but I have had space issues with these as rears. These aren't tiny speakers.
PSN: dagreeng
post #1108 of 2399 Old 12-11-2014, 04:19 AM
jkhome's Avatar
Quoted: 103 Post(s)
Liked: 66
Hi,
Rodolfo
A couple of folks on the Audio Karma LS50 thread state they are very happy with their Yamaha AS2000 amps on the KEFs.
jkhome is offline
post #1109 of 2399 Old 12-13-2014, 02:11 PM
tb151's Avatar
Liked: 0
I'm very proud to join this club and post here. I picked up a pair of these today and am just floored. They are currently set up in my living room while I finish my basement, so by no means are they being well powered (Denon X2000). But.....WOW. Tears in Heaven by Clapton stopped me in my tracks. I'm looking forward to building out a more robust system and getting them powered, but until then I'm going to enjoy break in!
Also, kind of funny, the guy at the audio store carried them out to my car and said that it just felt right to load such British heritage into my Range Rover.
Shameless pic after unboxing
tb151 is offline
post #1110 of 2399 Old 12-14-2014, 03:37 PM
AUDIOgiant's Avatar
Quoted: 365 Post(s)
Liked: 83
Congrats an welcome to the club! I felt the same when i got mine set up for the first time. Are the ones they sell still branded 50th anniversary?
PSN: dagreeng
Reply Speakers
Kef Ls50 2 Way Speaker System
