KEF LS50 Owners - Page 43 - AVS | Home Theater Discussions And Reviews
 26Likes
post #1261 of 1271 Old 02-18-2015, 01:47 PM
xhattan's Avatar
Quoted: 22 Post(s)
Hello:
Building a new HT and been looking at the LS50 for a while now.
HT would be composed of 3 LS50 for all fronts (L/R/C), 2 HTB2 subs and 3005SE satellites for wides, heights or Atmos (ceiling) and surrounds. MLP: 10 feet.
Sources: Denon X5200 or Pioneer SC-87 (haven´t decided yet) and Marantz 7055 amp, Oppo 103, Xbox One, Wii. Used equally for both movies and music.
Will the 3005 satellites pair well with the LS50s? Is the MLP appropiate for the LS50s or will they be forced too much?
Also, if I can´t get the third LS50, would I be better with no center and leaving the Right and Left handle it instead of an inferior speaker?
Finally, I don´t have space for stands so these would be sitting on top of Furniture, but at ear level. Would this diminish their quality?
xhattan is offline
post #1262 of 1271 Old 02-18-2015, 05:21 PM
adidino's Avatar
Quoted: 33 Post(s)
Liked: 56
You can order a single ls50 if needed.
As for height, 29 inch stands are recomended height. I would avoid putting them on furniture if possible. The speaker will resonate. You can attempt to isolate them but you are also dealing with defraction issues with a speaker sitting on a large surface.
adidino is offline
post #1263 of 1271 Old 02-18-2015, 07:51 PM
Quoted: 12 Post(s)
Liked: 0
Little message to fellow LS50 owners... It is a favorite speaker of mine, and I have owned speakers 10 times the price. On my recently upgraded system I am using the speakers shown in my sig, but one thing I know is I keep the LS50. The speakers I am listening to now live a less guaranteed life around here. They are fun,but also over 3 times the price and at best marginally better.
The LS50 is a classic. A total giant killer. But you have to like analytics. If not, Kef offers the more restrained style they're known for elsewhere.
System: SB Touch -optical-> Benchmark DAC2HGC -AnalysisPlus Oval Copper XLR-> NAD M22 Power Amp -AnalysisPlus Black Mesh Oval-> Totem Element Fire
Other Rooms: 2x SB Boom; 1x SB Radio; 1x SB Classic-> MusicalFidelity M1PWR -> Totem DreamCatcher
Computer audio: workstation -USB-> audioengine D1 -> Grado PS500e
pablolie is online now
post #1264 of 1271 Old 02-19-2015, 05:17 AM
steveting99's Avatar
Quoted: 539 Post(s)
Liked: 172
Originally Posted by xhattan View Post
Hello:
The LS50 speakers are rated at a maximum continuous power of 100W, with 85 dB/W/m sensitivity. They're meant to be for near field listening and your distance of 10' away from the LS50 is will be an issue to reach 105dB peak. If you can reduce the distance to 9.25' and have them placed close to the room boundaries, it'll reach that peak of 105dB. Consider crossing over from the LS50 to the subs at say 100Hz to gain some additional headroom.
Email KEF if the 3005 egg satellites will match with the LS50. I got a positive response back from KEF in matching the E301 with the LS50.
The Denon X5200 has sufficient power to drive the LS50 in peak power demand in stereo mode and also in multi-channel surround.
Have a look at other Internet Direct (ID) sub companies rather than KEF. You'll get a lot more sound quality for the money. The ID sub companies make better subs than KEF. A few to consider include:
Rythmik
SVS
HSU
PSA
Seaton Sound - the SubMersive ($$$)
JTR - Captivator ($$$)
If you can't get a 3rd LS50 for the center speaker, consider the R-series from KEF, which has center speaker that can be purchased separately. The R-series have a higher sensitivity speakers (R300) available and if you can't reduce your listening distance, this might be the better option.
xhattan likes this.
Maranatz SR-7009, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is online now
post #1265 of 1271 Old 02-19-2015, 03:10 PM
xhattan's Avatar
Quoted: 22 Post(s)
Rythmik
SVS
HSU
PSA
Thanks a lot pal. Very valuable information.
Actually I meant Budget limitation when I said that maybe I couldn´t get the third LS50 for center. Checked the R series and they are actually more expensive. Read in another thread that center speaker should be avoided when it is of inferior quality than your fronts. I have the 3005 center but even though it has served me well (the whole set has, this speakers are the best HTIB ever IMO, the Pro Cinemas, Logans and Klipsch don´t stand a chance against these) I feel the LS50 will overpower it, hence my inquiry as to let the fronts handle center too.
Thanks again.
xhattan is offline
post #1266 of 1271 Old 02-20-2015, 12:45 PM
burnsniper's Avatar
How much do you guys toe in?
KEF's diagrams in the manual suggest upto a ~45 deg toe in. I am getting a pretty good sound stage with no toe in and no port plugs, however my speakers are only about 5' apart tweeter to tweeter. Any wider and I will be pushing the cabinet up pretty close to walls (already only around ~12" between the sidewalls and speaker box and ~15" between the back wall and speaker box). The speakers are in sort of a cubby (area was the original coal fired kitchen of my 100+ year old house), however the woofers and 1/3 of the speakers stick out beyond the cubby and have no walls nearby. I am getting a great bass response from these speakers with this setup.
Note that this is my first time with speakers in this room (fairly new-to-us house) and any suggestions/comparisons would be welcome.
burnsniper is offline
post #1267 of 1271 Old 02-21-2015, 01:12 PM - Thread Starter
wse
wse's Avatar
Quoted: 672 Post(s)
Liked: 404
Hello: Building a new HT and been looking at the LS50 for a while now. HT would be composed of 3 LS50 for all fronts (L/R/C), 2 HTB2 subs and 3005SE satellites for wides, heights or Atmos (ceiling) and surrounds. MLP: 10 feet. Sources: Denon X5200 or Pioneer SC-87 (haven´t decided yet) and Marantz 7055 amp, Oppo 103, Xbox One, Wii. Used equally for both movies and music. Will the 3005 satellites pair well with the LS50s? Is the MLP appropiate for the LS50s or will they be forced too much? Also, if I can´t get the third LS50, would I be better with no center and leaving the Right and Left handle it instead of an inferior speaker? Finally, I don´t have space for stands so these would be sitting on top of Furniture, but at ear level. Would this diminish their quality? Thanks!
I would go all the way and put LS50s all the way around! You will love it it, the sound will provide you with amaizing sound! For atmos you could use these KEF Ci200RR - THX Ultra
wse is online now
post #1268 of 1271 Old 02-22-2015, 12:00 AM
Ponzio's Avatar
from the FWIW department, I've matched my LS50's with a KEF R200c and the tonal match is spot on.
Ponzio is offline
post #1269 of 1271 Old Today, 04:22 PM
Liked: 0
LS50 with Rouge Sphinx
I have had my LS50 for 1 year. Love them. Have been running with a Yamaha A-S500. Have been happy. But as always trying to go further. So now have a Rogue Sphinx. Sounds great...but the volume tired all the way and maxes out. Will not reach volume level that Yamaha could go if I tried. Rogue is 100w ; Yamaha is 85w. Any thoughts on this? Am I expecting something I should not? Not trying to hurt myself. Just have something in reserve for that special blast. I'm music only.
rudieddy is offline
post #1270 of 1271 Old Today, 09:59 PM - Thread Starter
wse
wse's Avatar
Quoted: 672 Post(s)
Liked: 404
Originally Posted by nirvy111 View Post
I'm powering 7 ls50's with a denon x4000 and it plays extremely clean and as loud as I like in my 18' x 14' x 8' room, I doubt I'm playing it at reference levels but it's more than loud enough for me. My main listening position is 16' from the front speakers. I'm using a subwoofer with the ls50's crossed at 80hz, they will play to 80hz no problem.
Cool I am powering 7 LS50 with the Marantz SR7009 and it sound great ! My room is 11 x 12 x 9 much smaller. I sit only 6 feet from the front channels. I crossed them over at 80HZ as well using two small subs.
wse is online now
post #1271 of 1271 Old Today, 10:00 PM - Thread Starter
wse
wse's Avatar
Quoted: 672 Post(s)
Liked: 404
35 degree for front channels
wse is online now
Reply Speakers
Kef Ls50 2 Way Speaker System
