KEF LS50 Owners - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 174Likes
Old 06-29-2016, 05:21 PM
Quoted: 14 Post(s)
Liked: 3
Originally Posted by ahmad_ie View Post
May be it is due to the amp? See "SAM" as explained in http://www.theabsolutesound.com/arti...system/?page=2
Also, check out this page: http://en.devialet.com/speakers/kef/kef-ls50
pdxaudio is offline
Old 07-06-2016, 10:52 AM
Liked: 2
I am a very late comer to this thread. I bought the grey LS50 over the Christmas break when KEF was promoting them with the M400 headphones. Afterwards, I had to save up for the source and ended up with a Naim SuperUniti and a CD5i (both used). I am very happy with them so far and they are now sitting slightly further away from the walls than they were in the picture. I am just waiting for the AV shelf to arrive now and I think I will enjoy the system for a long time before I make further upgrades.
Cheers.
Jon
Name:	DSC_1761 - Copy.JPG
Bill_B4 and KenM10759 like this.
startroops is offline
Old 07-06-2016, 07:11 PM
jima4a's Avatar
Quoted: 276 Post(s)
Liked: 147
Cheers.
Jon
Congrats! It is an amazing speaker - mini Reference as they have been called.
jima4a is offline
Old 07-08-2016, 11:56 AM
simonseys's Avatar
Wall mount the LS50?
Hi!
First let me state I'm wearing flame retardant clothing because I have a feeling people will say I'm crazy for considering wall mounting these or just plain crazy for asking. But here goes anyways.
I'm looking to put together a 2.1 channel system with the LS50's as the left and right channels. In our current living room system we have Scandyna Micropods mounted to the wall using the optional Scandyna mounts on either side of our TV, and a Scandyna Basstation. It really sounds fantastic and we love it. We've been using this sytem for about 8 years with no complaints. It easily fills our open concept main floor with beautiful sound.
In our new house we'd like to do the same, have a 2.1 channel system for the living room but I'd really like to switch over to these KEFs instead since I've nearly fallen in love with them. The problem is we'd really prefer having the left and right channel mounted on the walls like we have now.
So I know the LS50's have no provisions built into them by KEF for wall mounting. I've been looking around for some universal mounts which might work. I'm wondering if one knows of a way this might be achieved or knows of a universal wall mount that may work. Additionally, is this a good idea? Bad idea? Acoustically bad perhaps? I'd be curious to hear the thoughts of others.
simonseys is offline
Old 07-08-2016, 12:06 PM
KenM10759's Avatar
Quoted: 1385 Post(s)
Liked: 739
The rear port on the LS50 is there for a reason and shouldn't be blocked by being up against a wall. It *will* have negative effect on the sound. I'll let others be more specific, though I know it affects the bass output more than anything else.
KEF R500, R200C, R100, SVS SB2000 sub, NAD T758 receiver, Pro-Ject RPM1 TT w/ Sumiko Pearl, Bluesound Vault2, Sony BDP-S480 BlueRay player, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer.
KenM10759 is online now
Old 07-08-2016, 12:32 PM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 297
Originally Posted by simonseys View Post
Hi!
My surround LS50's are wall mounted. B-Tech side clamping mounts work well.
With the close proximity to the wall you will want to use the port bungs.
My processor sets the crossover at 100hz. My front LS50's are at 79hz without
the bungs.
tr4a is offline
Old 07-08-2016, 12:36 PM
simonseys's Avatar
Hi,
This is a great point. I read this in the manual and somewhere else as well but given the mounts I've been looking at it seemed like it would be within range. I guess should have clarified they would be pushed right up against the wall since its not even possible with the posts sticking of the back.
I was thinking of a universal mount something like what sin this photo:
https://images-na.ssl-images-amazon....jL._SX355_.jpg
With this type the speaker sits in a tray and by moving it forward in the tray it you could get the 500mm or 200mm (without and with plug respectively) clearance recommend in the manual.
Simon
Old 07-08-2016, 12:41 PM
simonseys's Avatar
the bungs.
Thank you so much for replying and posting this awesome photo! Looks so similar to what I'd like to do and it's in white too which I was considering.
Would you mind me asking how high you have these mounted? That's another item I left out of my first post, was that we'd probably mount these higher up. Certainly closer to the ceiling than the flloor. Is there any adverse affect to doing so?
Cheers!
Old 07-08-2016, 12:56 PM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 297
Cheers!
Mine are 80" from the floor to the bottom of the
speaker. A slight tilt angles toward the MLP.
The only adverse affect if they were mounted up
next to the ceiling they might corner load.
tr4a is offline
Old 07-08-2016, 01:36 PM
simonseys's Avatar
So if these are placed in the corner of a room with the the port bung the manual shows them needing no less than 200mm to the wall behind them and no less than 500mm to the wall adjacent to them. Any idea how much clearance they might need between the ceiling above them? Should I assume 500mm or would it be more?
l'm not familiar with the term corner load, but I think I understand what you're getting at. The sound from the speaker bouncing off the close adjacent surfaces affecting the audio quality?
Simon
Old 07-08-2016, 01:45 PM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 297
Simon
Simon
Here is a picture of the left speaker.
Ceiling slopes up from the speaker.
Steve
tr4a is offline
Old 07-20-2016, 07:56 AM
marksas's Avatar
Quoted: 136 Post(s)
Liked: 55
Considering the LS50's as my next purchase, they would be replacing a pair of B&W 684 S2, obviously i would need to stand mount these and was wondering what people are using for stands. I would need something pretty sturdy as they are in the very close to the walking path into our living room, so i'm worried about bumpage. Is there any way to attach them to stands? I like how the Sonus Faber Venere 1.5 & 2.0 have a couple of mounting screws to use with their proprietary stands and are considering the them as well as an alternative to the LS50.
marksas is offline
Old 07-20-2016, 08:10 AM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 297
Blu-tack works very well.
Mine have been in place for over 3 years.
My stands are 26" tall.
I would experiment with temporary stands
to determine final height.
Steve
Garman likes this.
tr4a is offline
Old 07-20-2016, 08:28 AM
marksas's Avatar
Quoted: 136 Post(s)
Liked: 55
Steve
Do you use a sheet of blu-tack or a few small pieces?
Really interesting setup you have! how are those stands mounted to the media cabinet? I'm actually in the market for a new media cabinet and may go with something wider if i go with bookshelf/monitors rather than towers. How does the LS50 work as a center channel for you? Besides the obvious seamless LCR integration, how is the dialogue for TV/movies? Also, how do you use them for music, 2.0 or with a sub in 2.1 and which sub? Sorry for all the questions!! Just trying to make an informed decision, there's no place locally for me to listen to these in the North Shore Boston area.
Mark
vooges likes this.
marksas is offline
Old 07-20-2016, 08:52 AM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 297
Mark
I built the cabinet based on a Salamander.
In the middle of the build someone was selling
Salamander doors really cheap. I ended up using
the prebuilt doors.
I bolted the extrusions through the cabinet and
fabricated a 1/4" steel top plate. Strips of Blu-tack
hold the speakers in place. In fact I was going to try
moving the speakers a few inches forward but they
would not budge. One day I will separate them.
A LS50 works very well as a center.
Last year I replaced my Kef E301 surrounds with
a pair of LS50's. Having all 5 speakers the same
is amazing.
I have 2 subs in the room to balance out the bass.
Steve
tr4a is offline
Old 07-20-2016, 09:11 AM
marksas's Avatar
Quoted: 136 Post(s)
Liked: 55
Wow that's cool, great idea. I suppose if i had a side enough cabinet i could always buy something like the isoacoustic stands but not crazy about how they look. If i go the Kef route i thought about using a less expensive Q series center as i have not seen the ability to buy just (1) LS50 by itself. Also i'm currently using older Mirage OMD-5 speakers as my surrounds, they're ok and do the trick but not great.
marksas is offline
Old 07-20-2016, 09:23 AM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 297
Mark
The Q series is a nice speaker.
I would not use it as a center with the LS50's.
Kef Direct does sell singles.
I know some use the R200 as a center.
I compared the R series and found the
LS50's better.
Steve
tr4a is offline
Old 07-20-2016, 09:47 AM
marksas's Avatar
Quoted: 136 Post(s)
Liked: 55
Mark
LS50's better.
Steve
Good to know, thanks Steve!
marksas is offline
Old 07-20-2016, 11:45 AM
AtlantaAllen's Avatar
Quoted: 79 Post(s)
Liked: 42
A lot of the reviews talk about how great
these speakers are for the right room seeming to mean not too large.
My room is 16x24. Is that too large for these?
I sit about 12 feet from the front of my 802s now with them about 3 feet off the back wall now.
AtlantaAllen is offline
Old 07-20-2016, 12:35 PM
10k
10k's Avatar
Quoted: 1781 Post(s)
Liked: 1978
Mark
LS50's better.
Steve
i use ls50 as my left/right in my home theatre setup. I found the r200c in center much better than the ls50.
The r200c is basically an r500 on its side with half the cabinet chopped off. IMO it's a better speaker for center channel, considering that the ls50 starts to lose steam at around 80hz.
10k is online now
Old 07-20-2016, 04:22 PM
turnbowm's Avatar
Quoted: 50 Post(s)
Liked: 59
Originally Posted by 10k View Post
...The r200c is basically an r500 on its side with half the cabinet chopped off. IMO it's a better speaker for center channel, considering that the ls50 starts to lose steam at around 80hz.
The KEF FR specifications of 79Hz-28kHz +/-3dB can be somewhat misleading, since they are based on anechoic conditions with no port output. With port output included, the Sound & Vision measured FR was 46Hz-20kHz +/-3.2dB. Measurements performed by Stereophile in their LS50 review also showed an output essentially flat down to 50Hz.
http://www.soundandvision.com/conten...BiLe3Htm5Bc.97
10k likes this.
turnbowm is offline
Old 07-20-2016, 07:19 PM
Quoted: 14 Post(s)
Liked: 3
You are using B&W 802 and you are considering LS50?
For me, the room is too large if I am listening 12 ft away. My current room is a little smaller and I am about 7 ft away. I can't listen to it without 2 subs even at this distance.
pdxaudio is offline
Old 07-21-2016, 03:45 AM
Quoted: 79 Post(s)
Liked: 42
I'm using 802s, but I've found with some monitors you just get a different voicing which is a nice change depending on the music.
I'm also using 2 subs. I can't sit any closer.
I was considering the LS 50s as a change, not necessarily to replace. Thanks for the reply.
Old 07-21-2016, 08:17 AM
Quoted: 14 Post(s)
Liked: 3
If you have a local dealer who offers in home demo, give it a try. It might work for certain type of music. Vocal at lower sound level should work.
pdxaudio is offline
Old 07-22-2016, 08:59 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 248
Has anyone put a screw in an LS50? I have three and am going to wall mount them but want to mount the center horizontally and put a couple of screws through the bottom of the mount into the LS50. Is there mdf on the other side of the gloss black exterior? I realize resale value will be screwed but I care more about making sure it stays on the mount than resale.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
Old 07-22-2016, 09:04 PM
tr4a's Avatar
Quoted: 50 Post(s)
Liked: 297
Strips of Blu-tack and it won't move.
I want to move mine out about 3" and
they will not budge. I am going to have
to use a thin putty knife and work at it
for a while.
Steve
tr4a is offline
Old 07-22-2016, 09:24 PM
Quoted: 146 Post(s)
Liked: 248
I already have blue tack and it isn't secure enough. If I weren't worried about toddlers and just had gravity to deal with, I'd stay with the blue tack but that ain't the world I live in.
Old 07-23-2016, 01:28 AM
dbphd's Avatar
Quoted: 455 Post(s)
Liked: 166
In my experience KEF is very good about responding to emails. Dipin monitors it and has provided helpful advice.
dbphd is online now
Old 07-23-2016, 09:16 AM
Quoted: 14 Post(s)
Liked: 3
Please describe more how toddlers could post a danger to the center speaker?
Could they touch it? If so, I am more worry about the tweeter and the mid woofers. : )
Or, they could not touch the speaker but could touch the stand?
May be a picture to show your setup?
pdxaudio is offline
Old 07-23-2016, 08:05 PM
Quoted: 146 Post(s)
Liked: 248
I'm guessing you don't have kids? They climb everything.
The picture with the kids is from 16 months ago and you can see the speakers that were in there and the TV. I have an installer coming out Tuesday to open the walls, run some cable and add some 2x4's between the studs so the mounts for the L&R are mounting to wood and not just drywall. The L&R will be midway between the doorways and the TV and about 7' high. I'm using these mounts for the L&R ( https://smile.amazon.com/B-Tech-BT77...er+wall+mounts ). I will use blue tack on those for the time being as I think they will be mostly out of reach. At least for a bit...
The center is another issue though and will be mounted below the screen because there is an AC return above the TV. The TV btw is a Panny ZT65 plasma. The B-Tech mounts don't extend wide enough to clamp on an LS50 when horizontal so I knocked the brackets off using a grinder and may weld them back on a little farther down on the slide to get the needed 1/2" of extra room. I've also purchased a pair of these mounts ( https://smile.amazon.com/Halter-Adju...er+wall+mounts ) which should be able to accommodate an LS50 on its side. I will test that out Monday and if it works and looks as solid as the B-Tech, I'll use that.
The issue is that the side clamps still don't get a ton of grip on the LS50's due to the rounded corners and my 2 1/2 year olds can now climb onto the entertainment center if they wish. I do not want to have them pull the speaker off the mount and come crashing down on another child. The speakers that were in there are now moving to other duties and I am replacing the mids on all three speakers and one woofer because they have been damaged by said 2 1/2 year olds who climbed over the fence and wreaked havoc. The woofer alone on the towers is more than the cost of an LS50. If they manage to damage the LS50, so be it. I'll just buy another. I want this to be as hard as possible to remove and so want to sink some screws into the speaker so it is fixed more securely to the mount. Thus the question, is there something solid a screw can bite into on the other side of that glossy exterior.
This is a family room and not a room for critical listening so SQ concerns aren't paramount here. Neither is resale, I just want to be ultra safe.
ID:	1562345   Click image for larger version
Kef Ls50 2 Way Speaker System
