Best Current Bookshelf Speakers and Sub Combo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 48 Old 10-04-2012, 07:31 PM - Thread Starter
yuriygeorge's Avatar
Which of these bookshelf speakers are best value and best quality for a mid-size condominium living room set up with concrete walls and underflooring? For front or rear right/left or both? Which ones to avoid like the plague?
Brand: Atlantic Technology
AT-2-S-GLF H-PAS Full-Range
$540
6072bosta23?$shelf%5Fthumb$
Brand: Boston Acoustics
A26 2-way 6.5"
$110
5446infip163bk?$shelf%5Fthumb$
P163aBK Primus 2-way 6.5"
Brand: Infinity System/Harmon Intl.
$85
400jamo86500?$shelf%5Fthumb$
Brand: Jamo US
86500 Concert C 60 2-Way Bssreflex Front
$85
6569jbl_l830chh?$shelf%5Fthumb$
L830CH-H Studio L 3-Way 6"
Brand: JBL US
$170 each
6569jbl_es30bk?$shelf%5Fthumb$
Brand: JBL US
ES30BK 3-Way 6"
$140 each
6569jbl_studio530bk?$shelf%5Fthumb$
Brand: JBL US
Studio 530BK W-Way, 5.25" Wall-Mountable Loudspeakers
$180 each
6569jbl_l810h?$shelf%5Fthumb$
Brand: JBL US
L810-H Studio L 3-way 5.25" Bookshelf/Wall Mount Satellite
$150 each
5399kliprb61ii?$shelf%5Fthumb$
Brand: Klipsch
RB-61 II Cerametallic Woofer Bookshelf 6.5"
$150 each
Brand: Klipsch
RB-81 II Cerametallic Woofer Bookshelf 8"
$240 each
7074pionspbs22lr?$shelf%5Fthumb$
Brand: Pioneer
SP-BS22-LR Andrew Jones Designed Loudspeakers
$95 each
6527polkrtia3cherry?$shelf%5Fthumb$
Brand: Polk
RTI A3
$140 each
6527polklsim703midnightmahogany?$shelf%5Fthumb$
Brand: Polk
LSI M703 Midnight Bookshelf
$450 each
Which subs would go well with such bookshelf speakers?
http://www.avsforum.com/t/1432911/best-value-12-subwoofer-from-this-list
yuriygeorge is offline
post #2 of 48 Old 10-04-2012, 11:35 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Although I haven't heard them, those 3 way budget bookshelf speakers from JBL scare me (not in a good way). I have only heard the Klipsch, Polk Rti, and Infinity speakers from that list, and I think they are all good speakers, but I would stay away from the lesser polk speakers, namely the Tsi and Monitor lines, but that is just my preference. Any decent sub will pair well with those speakers, and the best bang for the buck is internet direct brands, specifically Outlaw, Rythmik, Hsu Research, and SVS for the more affordable subwoofers.
shadyJ is offline
post #3 of 48 Old 10-05-2012, 09:36 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Are those Jamo C601 or C603?
The C601 has a 4" woofer whereas the C603 had a 6" woofer. Based on the spacing between the tweeter and the Jamo logo it looks like the C601 which is way too small for front speakers.
You've got way too many choices and a price range between $85 and $540. Not really a fair fight for some of the smaller speakers.
Afro GT
afrogt is offline
post #4 of 48 Old 10-05-2012, 07:44 PM
BobL's Avatar
Liked: 56
I haven't heard all of them but I'll take an educated guess and bet the Atlantic Technology AT-2 would be the best. It would definitely have deeper bass than the others. I agree it is an apples and oranges comparison with the range of prices.
BobL is offline
post #5 of 48 Old 10-05-2012, 07:50 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would seriously consider the Atlantic Tech speakers - they do nice work.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #6 of 48 Old 10-05-2012, 08:06 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
Klipsch RB-81's, no question.
Lumenlab "Community driven video lab".
blake18 is offline
post #7 of 48 Old 10-05-2012, 08:41 PM
jeffw69's Avatar
Another vote for the RB-81's.
jeffw69 is offline
post #8 of 48 Old 10-05-2012, 09:12 PM
gtpsuper24's Avatar
Liked: 99
My vote out of those would be the Atlantic Techs.
gtpsuper24 is offline
post #9 of 48 Old 10-05-2012, 10:10 PM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
You mention "For front or rear right/left or both?", which implies home theater usage. Have you given any thought to a center?
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #10 of 48 Old 10-07-2012, 08:23 PM - Thread Starter
I apologize that these choices are so disparate. To explain my situation, I'm looking to set up speakers in a Chicago condo with the following layout:
I'd like to be as economical as possible, but I do require high-end quality of sound. I'm not interested so much into "home theatre." My primary goal is to throw parties about once a month and blow guests away with deep, smooth bass and awesome sound. In time, I would imagine occasional special guests deejaying music through these speakers. My secondary/optional requirement is to have speakers suitable for producing/composing music, if and only if they can simultaneously meet primary goal's objectives.
I'm not very knowledgeable about this, so I appreciate any help I can get.
I.e.,, Atlantic Technology is most expensive, and some of you are recommending them; would you say their 'quality of sound' is much better than the Klipsch RB-81s? RB81-s are twice as cheap, but is the quality difference that large?
BobL, you mentioned the Atlantic would have better bass than the others, but would this be necessary if I'm already getting a sub?
Afrogt, they appear to be the 4" Woofer kind, so I assume I should stay away from this Jamo product.
JimWilson, I have given thought to center speakers. However, as mentioned above, I'm not particularly concerned with home theatre. Would you still recommend center speakers? Also, should I not bother getting rear speakers, or would they help aid in the 'quality of sound' experience?
Finally, I can only pick from these set of subwoofers:
Subwoofer thread:
Any of these you can recommend to achieve my goals that would work well with the bookshelf speakers?
post #11 of 48 Old 10-07-2012, 08:56 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Better base is always better (as long as nothing else is compromised) . I'd add NHT, KEF, and Cambridge Audio as other options. I had some great JBLs years ago, when they were still made in Denmark.
lespurgeon is offline
post #12 of 48 Old 10-08-2012, 08:18 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Why can you only pick from those?
And if you want "deep, smooth bass" for parties, you might also consider dual subs which can create a more even bass response throughout the room.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #13 of 48 Old 10-08-2012, 08:57 AM - Thread Starter
Well, I don't necessarily HAVE to pick these speakers. But, I pay good membership fees at this club so I could get discounts on these products. Unfortunately, these are the only brands they carry. If the general consensus is that this list of subs and/or this list of bookshelves suck, and I need to get something else, then I'm open to that as well.
Dual Subs? Interesting idea. I've never heard of dual subs? You mean to buy 2 separate subs and spread them out in the room? Or to buy one product that comes with the 2 subs together in the enclosure? Can you give me an example? Sorry for the dumb questions, I'm really new to this. Also would you recommend getting 2 12" subs? Or since I'd be getting 2 subs now instead of 1, can I get 2 10"s or maybe 2 8"s?
post #14 of 48 Old 10-08-2012, 08:58 AM - Thread Starter
double post, sry
post #15 of 48 Old 10-08-2012, 01:25 PM
JimWilson's Avatar
Liked: 1560
These are mutually exclusive needs I'm afraid. Unless you find a killer sale on something "economical" and "high quality" are an oxymoron.
These are also mutually exclusive I'm afraid. Speakers you would use for house parties and DJing are generally selected on their ability to play very loud, but fidelity is not the ultimate goal. Speakers designed for composing and producing are the exact opposite; they need to produce the utmost in clarity and neutrality, and generally aren't able to play at a drowned-out-the-crowd volume level.
It might be a good idea to decide what your most pressing needs are, and then list them in order of priority. Not matter what you'll have to compromise on one or more of them, but at least this way the critical one(s) will get the most attention.
post #16 of 48 Old 10-08-2012, 01:56 PM - Thread Starter
I would throw parties once a month in a high-rise condo of about 1200 square foot. The Floors/Ceilings are made of concrete, so I have a little bit more room for loudness than some condos, but I'm not looking for them to be super loud at all. Just loud enough for a mid-sized party. (I'm only gonna do this about once a month over the weekend, so it shouldn't upset the neighbors too much). The quality, and crispness of sound is very important to me, but not necessarily for the purpose of composing/producing. My guess that it's possible to achieve this for a party-type setting, while not needing to blast the speakers much, right? My number 1 priority is for the parties. Let's ignore the other secondary priority for composing/producing for now since it seems to only distract from the primary goal.
It seems like the Klipsch-RB81 BookShelves may work well for the set up, no? So, I'm thinking so far to could get 2 of those and, cel4145 recommended getting 2 subs, which I'm still looking into.
So, 2 bookshelves, 2 subs. Do I still need center or rear speakers? Or my understanding those are primarily used for home theatre set up, or no?
post #17 of 48 Old 10-08-2012, 02:08 PM
cel4145's Avatar
Liked: 2985
The Klipsch RB81s have a very high sensitivity. They will get louder for the same amount of power from a receiver in comparison to other speakers on your list.
However, some people find the Klipsch horns fatiguing to listen to. You should probably try to demo some Klipsch in your area (even if a different model) to make certain they are a good fit for you.
cel4145 is offline
post #18 of 48 Old 10-08-2012, 02:16 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Klipsch were measured to have 91db sensitivity - however, they will
still play loud.
Who AM I
zieglj01 is offline
post #19 of 48 Old 10-08-2012, 02:21 PM
cel4145's Avatar
Liked: 2985
still play loud.
So their 97db claim is bonkers, huh?
Yet another audio company playing with their specs (lol)
cel4145 is offline
post #20 of 48 Old 10-08-2012, 02:24 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
On a side note, look at these measurements of the Atlantic Tech.
With some power behind them - you get some serious sound. >>
http://www.soundandvisionmag.com/article/test-report-atlantic-technology-2-bookshelf-speaker?page=0,2
Who AM I
zieglj01 is offline
post #21 of 48 Old 10-08-2012, 02:28 PM
cel4145's Avatar
Liked: 2985
They don't even need a sub if you all you want is mid-bass. eek.gifbiggrin.gif
cel4145 is offline
post #22 of 48 Old 10-08-2012, 02:34 PM
wse
wse's Avatar
Quoted: 1976 Post(s)
Liked: 739
If you want quality and good sound at good value get LS50 from KEF they are very very good
wse is offline
post #23 of 48 Old 10-08-2012, 02:35 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Wow. They must be using very high quality woofers to achieve this with a 5.25 woofer. Color me impressed. I guess their "Revolutionary patent-pending H-PAS technology delivers extended, dynamic bass exclusive Low Resonance Tweeter (LRT™) for wide dispersion" really works smile.gif
I have always been an Atlantic Technology fan.
ack_bk is offline
post #24 of 48 Old 10-08-2012, 02:37 PM - Thread Starter
I'm definitely getting a subwoofer (or 2). Since I'm already getting these subs, is there a need from such bass response from these bookshelf speakers? (Atlantic Tech 2)
post #25 of 48 Old 10-08-2012, 02:41 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I want to hear that speaker - I also like their speakers for music.
Who AM I
zieglj01 is offline
post #26 of 48 Old 10-08-2012, 04:45 PM
JimWilson's Avatar
Liked: 1560
Since your primary goal is essentially two channel music then you can probably skip the center.
As the others have mentioned, getting speakers with a high sensitivity -- at least 90dB -- is probably a wise idea. That will present an easier load on your receiver when they're played at a higher volume for an extended period of time. However, you might want to consider towers instead; if you want to really drive a set of speakers in a party environment towers would be my preferred options. Something like the Premier Acoustic PA-6F or the popular Infinity 363 might do. A dark horse option worth a look is the Crystal Acoustics T1-BLA. I have the bookshelf version of this speaker to do a review on -- the B1-BLA -- and have found them to be a surprisingly nice set of speakers.
If you want to stick with bookshelf speakers then another one to consider is the HSU HB-1. High sensitivity and horn tweeter, like the Klipsch, but I don't recall anyone ever saying they get harsh like I've heard about the Klipsch.
yuriygeorge likes this.
post #27 of 48 Old 10-08-2012, 04:55 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
No - you do not really need them, and since you are looking to party >
then buy something else. I would not buy cheap/boomy subs for those
Atlantic Tech speakers. If one spends most of their time with music >>
then I would seriously consider them - if budget permitted.
Who AM I
zieglj01 is offline
post #28 of 48 Old 10-08-2012, 07:13 PM - Thread Starter
Well, I was thinking about getting this sub: http://www.soundandvisionmag.com/article/review-sunfire-dynamic-series-sds-12-subwoofer?utm_campaign=website&utm_source=sendgrid.com&utm_medium=email
I don't think it's cheap, but I get your point.
post #29 of 48 Old 10-08-2012, 07:18 PM - Thread Starter
I was actually considering towers at first. But, I also want to get a sub. Would it be too much bass if I got 2 towers AND a sub?
post #30 of 48 Old 10-08-2012, 08:28 PM
cel4145's Avatar
Liked: 2985
Not a problem. You'll use the AVR's bass management to set the crossover for the speakers and sub wherever you want. It will integrate them together.
cel4145 is offline
Reply Speakers
