Revel Concerta F12 vs Energy RC-70 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-04-2012, 08:17 PM - Thread Starter
Metaphysical's Avatar
How do these speakers compare? Will be using them for music and movies with a dedicated subwoofer
"I am a shark, the ground is my ocean, and most people can't even swim." - Rickson Gracie
Metaphysical is offline
post #2 of 3 Old 10-05-2012, 12:20 PM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
They will both sound great.
I would get the Revel since it has more pedigree being related to the $22,000 Revel Salon2 and $70,000 JBL Everest, plus all that research from Harman International's Floyd Toole and Sean Olive. biggrin.gif
The Revel will have a better resale value.
AcuDefTechGuy is offline
post #3 of 3 Old 10-05-2012, 02:57 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
Only a little familiar with that Revel model so take this with a grain of salt (as you should with all internet reviews):
The Revels are probably fairly neutral.
The Energys are "warm", ie, some mid- and upper-bass emphasis.
This of course will be at least in part room and placement dependent, but I would expect it to hold true as a generalization.
Which you prefer is, well, up to you. Both should be pretty good speakers, just with a somewhat different character.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
Reply Speakers
