Paradigm Cinema 200 & 400 Wall Mounts??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-05-2012, 12:57 AM - Thread Starter
dizzyscure1's Avatar
I need some wall mounts for 2 Cinema 200's (rear channels) and 1 Cinema 400 (center channel) the included supports do not angle, only sit flush on the walls. The problem I have is that I don’t know how to find a mount that’s compatible with my speakers!??? I need a mounting system that is high quality and capable of swiveling so I can have all of the speakers aimed at the sweet spot (my ears LOL!) thanks for your help.
IMG_1774 (1024x768).jpg 374k .jpg file IMG_1773 (1024x768).jpg 362k .jpg file cinema200_onwall.jpg 18k .jpg file
dizzyscure1 is offline
post #2 of 3 Old 10-06-2012, 08:47 PM - Thread Starter
Any help?
post #3 of 3 Old 10-06-2012, 10:09 PM
NewHTbuyer's Avatar
Liked: 41
It looks like there are 2 threaded holes in the back of the speaker. Maybe call Paradigm and ask what size they are. Hopefully they will fit this:
http://www.omnimount.com/products/speaker_mounts/stainless_steel_series/20.0_w/
You may have to talk to both companies to see if their products are compatible. Or order one and try yourself, then return it if it does not fit.
Good luck.
NewHTbuyer is offline
Reply Speakers
