Wall Mount Brackets and Recommended speaker placement for Energy Take 5.1 Classic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2012, 02:28 PM - Thread Starter
AVRookee's Avatar
Hello
Can you pls. recommend any good (but inexpensive) speaker wall mount brackets for front/center and rear energy take 5.1 classic speakers?
Also are the front 2 speakers supposed to be at ear level (sitting down) and the center also should be below the tv (if tv is wall mounted)?
AVR
AVRookee is offline
post #2 of 2 Old 10-06-2012, 03:08 PM
smasher50's Avatar
Quoted: 376 Post(s)
Liked: 18463
fwiw, go to monoprice and look under speaker mounts there should be something for you there and yes your fronts should ideally be at ear level and also the center closest to ear level as possible or pointed down towards you.the rears just sligtly behind your seating about5-6ft above.pointed downward slightly towards you
i'm so laid back,i'm laid out
smasher50 is offline
Reply Speakers
