Need Help in polishing my speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2012, 02:28 PM - Thread Starter
I L K E R's Avatar
Hi guy's
My paradigm signature S6's has a piano black finish. Over time they developed little scratches from dusting. I do use a soft cloth to wipe them but still you can't avoid the hair line scratches.
So my question is... Has anyone here wax+polish their speakers? If so what is the best way to go about this? Do I need a car wax or is there special wax for this stuff? Also do you wax by hand or use a power tool? Any info would be great on how to do this without recking my speakers.
Cheers,
I L K E R is offline
post #2 of 2 Old 10-07-2012, 04:30 PM
SAVholic's Avatar
I use this with my Yamaha NS-555 that are also piano black and they look brand new, It did remove the fine scratches from dusting in my center (NS-C444) just a small spray in a microfiber cloth and wipe until dry, but I can't tell if it will work for you. This stuff is cheap so you may give it a try.
"My English is not very good looking" - Celia Cruz
SAVholic is offline
Reply Speakers
