What part of an A/V system does one general upgrade first? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 10-07-2012, 06:13 PM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
I have a mediocre system in my small NYC apartment (500sf): Onkyo TX 304 receiver, Polk Audio rm-6750 HTIB (with sub), Apple TV and a Panny 1080i plasma.
I dont necessarily need a new Amp as I have plenty of power for my small space (and dont need 7.1 either) although it would be nice to pass-thru HDMI.
I have limited funds ($500 tops); what would you do first?
kwitel is offline
post #2 of 13 Old 10-07-2012, 06:18 PM
blackangst's Avatar
Quoted: 116 Post(s)
Liked: 102
Speakers first.
edit: just realized you had a HTIAB...speakers may not be a possibility...but if you can, that should be first.
My system: Yamaha RX-A3060, Emotiva XPA-2, Salk Song3, Salk Songcenter RT, Polk FXiA6, Rythmik FV15HP, Intel i7 HTPC running JRiver Media Center
blackangst is offline
post #3 of 13 Old 10-07-2012, 07:01 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Usually I would say speakers, but your AVR lacks HDMI and all of the latest decoding. I would get a new AVR. The Denon entry level AVRs would be a good addition.
http://usa.denon.com/us/product/pages/productdetail.aspx?pcatid=avsolutions(denonna)&catid=avreceivers(denonna)&catalog=denonna_us&pid=avr1513(denonna)
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 13 Old 10-07-2012, 07:19 PM
blackangst's Avatar
Quoted: 116 Post(s)
Liked: 102
Actually, after reading a 3rd time, I realized the HTIAB was the speakers not the receiver. That said, I think I agree with flying here. Your current speakers will still hook up to a new receiver, and you'll be able to enjoy all the latest encoding schemes. And get HDMI smile.gif
post #5 of 13 Old 10-07-2012, 07:23 PM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
Will I notice a change in the sound by having these new encoding schemes? (what am I missing now)
That said (and this likely becomes a receiver-thread) but through my research I found that the Onkyo-TX-NR609 seems to be the best mid-range receiver (id like to do some future proofing and go with a 7.2).
Would you guys agree with that?
kwitel is offline
post #6 of 13 Old 10-07-2012, 07:55 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The Onkyo is a good receiver, but I think the Denon operates speakers down to 4 ohm whereas the Onkyo doesn't. Not 100% sure though. You will get pass through, and TrueDolby HD which I think sounds better than Digital Dolby.
post #7 of 13 Old 10-07-2012, 08:20 PM
Anodyne's Avatar
The Onkyo NR609 only has Audyssey 2EQ whereas you can get an equally priced Denon with MultEQ XT which is far and away better than the 2EQ.
Since you're in a 500sqft apartment, I'd focus on upgrading the fronts and center and build up from there. That's what I did and I couldn't be happier. For $500, you can get a couple of Polk Monitor 60's and a Polk CS1 from NewEgg and still have money left over to get a decent sub. I picked up a 15 year old Klipsch KSW-100 sub off of Craigslist for $40 that would do wonders in a 500sqft apartment. You can do something similar and then upgrade the sub later if need be. The Onkyo you currently have will do just fine for your space. If you add a Blu-ray player in to the mix later, then you'd probably want to look at upgrading to a newer receiver with HDMI and the latest processing.
Anodyne is offline
post #8 of 13 Old 10-07-2012, 09:00 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
2 quality front speakers for stereo music and to use as HT mains (phantom center). Keep the HTIB ones in surround with the sub for HT use, but not for stereo listening. Then the receiver.
lespurgeon is offline
post #9 of 13 Old 10-07-2012, 09:34 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I agree with the last two posters. Start with the speakers. Either left/right or left/right and center.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #10 of 13 Old 10-07-2012, 09:35 PM - Thread Starter
kwitel's Avatar
Quoted: 39 Post(s)
I will look into that; thanks.
What is the exact model number on those Polks? Also, that center looks a bit too bulky for my tatse (I have limited space).
What do you mean by "phantom center"?
kwitel is offline
post #11 of 13 Old 10-08-2012, 05:49 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
A phantom center is when you don't actually have a center speaker and the AVR uses the front two mains and some audio processing to create an illusion of a center channel speaker by making the dialogue appear like it is coming from where a center channel would be. A lot of guys here actually prefer a phantom center over a real center channel.
post #12 of 13 Old 10-08-2012, 10:33 AM
nograveconcern is offline
post #13 of 13 Old 10-08-2012, 10:44 AM
Mike Garrett's Avatar
Quoted: 5652 Post(s)
Liked: 3616
Since you are in a NYC apartment, I would probably concentrate more on the video side, but to do that so that it can help all sources, you will need an AVR that has HDMI.
mjgarrett100@gmail.com
Mike Garrett is online now
Reply Speakers
