Buying first surround sound system. $1000 budget. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 10-07-2012, 11:14 PM - Thread Starter
Sakome's Avatar
Hello, this is my 1st time buying any surround sound system and I wanted to ask your guys advice. Just now I bought Energy Classic 5.0 speakers http://www.newegg.com/Product/Product.aspx?Item=82-269-004&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=3#scrollFullInfo because it seemed like it was too good of a deal to pass up and it was for a limited time on the sale. These speakers seem to have a great reputation for its cost but I hope I didn't make a mistake choosing these. If I wanted to upgrade to 7.1 (which I plan to in the future) what would be the best 2 speakers to get with these?
Any suggestions on which subwoofer and Receiver to get? I was thinking of getting Klipsch RW-12 http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078 for the subwoofer and a Denon 2112 http://www.amazon.com/Denon-AVR2112CI-Integrated-Surround-Receiver/dp/B004Z0S7OM/ref=sr_1_2?ie=UTF8&qid=1349673048&sr=8-2&keywords=denon+2112ci for my Receiver.
Unfortunately I don't have the measurements for my room atm but I plan on moving to a smaller apartment living room size eventually. Also I am willing to go overbudget if its worth that much of a performance gain for a bit more. By a bit I only mean a few hundred dollars.
Sakome is offline
post #2 of 20 Old 10-08-2012, 08:04 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
The Energy Takes are very good small satellite speakers for the price for those that must have that small size. However, more full range bookshelf speakers will provide a better HT and music experience if you have room for the larger size. For example, Polk Monitor40 for the front L/R, CS2 center, and Monitor30 for the rear.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3 of 20 Old 10-08-2012, 08:54 AM
m_vanmeter's Avatar
what size is your room ?
micro or satellite sized speakers will function well in a small room like a den or bedroom, but will be totally overwhelmed in a larger living room or open layout home.
m_vanmeter is offline
post #4 of 20 Old 10-08-2012, 10:22 AM - Thread Starter
Sakome's Avatar
I just measured the room I am in now and its roughly 18x22 feet with a wooden floor. Eventually though, I plan on moving to a smaller apartment that would be smaller than that, probably a 1 bedroom apartment like 12x16 or around that for where I set up. I will use these speakers for music(VERY important to be accurate and clear), gaming and movies.
Is Polk Audio better than Energy for that price range? Newegg has sales on Polk all the time but not many other brands.
Sakome is offline
post #5 of 20 Old 10-08-2012, 11:18 AM
ffactoryxx's Avatar
Quoted: 258 Post(s)
Liked: 54
See if you can still get an of the Energy lines that are sold at Vanns.
ffactoryxx is offline
post #6 of 20 Old 10-08-2012, 11:51 AM
cel4145's Avatar
Liked: 2991
What happens is small satellites like the Energy Takes have no mid-bass. This means that the sub has to handle the mid-bass and the very low frequencies. It's typically better when the speaker handle some of that because
(a) Bass tends to become very localizable above 80hz. Since the Takes need a crossover of 120-150hz, this means you won't get the effect of the upper mid-bass coming from the individual speakers during HT usage. Bookshelves like the Polk can be crossed over easily at 80hz.
(b) It's hard to get an inexpensive sub that does the entire mid-bass range well and very low frequencies. For instance, the sub that comes with the Energy Takes in the 5.1 package does not go very deep in low frequencies. Enough for music, but there is plenty of low frequency content in movies that it won't produce. And it doesn't have much overall output, either. There are good budget HT sub choices that do much better with overall output and will produce more usable content down lower.
post #7 of 20 Old 10-08-2012, 12:03 PM
Smurfocolypse's Avatar
with a $1000 budget you could put together a very nice sounding system:
Agree with the above comments that Polks would outshine the Energy's because of the crossover
Polk Monitor 30's - pair for $100 (i've seen them go for $90) @ Newegg
Polk CS1 Center - $100 @ Newegg
For rear's you could get the same Monitor 30's - which puts you at $300 total for speakers.
I'm partial to BIC for subwoofers, and LOVE my v1220 which can be found for ~190 at a certain online river retailer
This leaves you with ~$500 left over for a receiver, wires, (or to upgrade the fronts or have money leftover!) - and a system that will rock the energy's.
Smurfocolypse is offline
post #8 of 20 Old 10-08-2012, 12:24 PM - Thread Starter
Sakome's Avatar
I was not aware of how mid-bass levels work with the Energy speakers, thanks! So even with a pre 300 dollar subwoofer, that alone cannot cover the bass needed for the Energy speakers? Guess I will have to go with Polk then unless there is something better. I know this question should go to the other forum but what kind of receiver and subwoofer should I get then?
Again if its worth me going above 1000 for the total budget I will if the quality is worth it.
Sakome is offline
post #9 of 20 Old 10-08-2012, 12:31 PM
cel4145's Avatar
Liked: 2991
Better to go with the Polk CS2 center. There have been complaints about the dialogue intelligibility of the CS1 on AVS; the CS2 is acknowledged to be much better.
And I'd go with the Polk Monitor40s, too, for the front sound stage benefit. Then spend a little less on the receiver. A $200-$300 entry-level receiver can work very well for this budget.
post #10 of 20 Old 10-08-2012, 12:47 PM
Good point - I have the cs2 myself (might want to wait on it, because it will go for cheaper than the $150 it is right now on Newegg). Couldn't fit the 40s in my setup at the moment, but couldn't agree more that they'd be a great choice for the $ if space isn't an issue.
As for receivers and subwoofers, you can easily find very nice function receivers for ~300 (pioneer/onkyo are great choices), and there are a few really nice subwoofers in the $200 range (BIC v1220 is my choice, but BIC f12, and there's a polk sw505, i think? can also be had for similar money)
post #11 of 20 Old 10-08-2012, 12:54 PM
cel4145's Avatar
Liked: 2991
Yep. Those three are some of the best choices for entry level HT subwoofers. And a $300 Onkyo, Pioneer, Denon or Yamaha would work fine smile.gif
post #12 of 20 Old 10-08-2012, 01:08 PM - Thread Starter
Sakome's Avatar
This has been very helpful thanks! Should I get 2 Polk Monitor 40's pairs or go for 1 Polk 40 and 1 Polk 30 for the surround speakers? Also if I wanted to upgrade to 7.1 would it be better to get floor stand speakers or to just get more polk monitor series? If they will have a better sale on the CS2 guess I could wait but its really tempting to get it now.
Sakome is offline
post #13 of 20 Old 10-08-2012, 01:30 PM
cel4145's Avatar
Liked: 2991
For the rears, the Monitor 40s vs the 30s will have less impact on the sound than having the 40s vs 30s in the front sound stage.
When you are ready to upgrade to 7.1, you could get the Polk Monitor 60s or 70s. For that matter, unless you are in hurry to have full surround sound, you might start with the M60s or M70s in the front with the CS2, and then wait until you can afford the rear speakers. The M60s are $129 ea at the moment. If you listen to music much, you would definitely appreciate the sound of the M60s over the M40s. And if you move to a small apartment, might be hard to setup 7.1 system in the room.
post #14 of 20 Old 10-08-2012, 07:26 PM - Thread Starter
Sakome's Avatar
Is the Monitor 70 series that much better than the 60? They also seem to be bigger too. I am a little concerned about the space they take up.
Sakome is offline
post #15 of 20 Old 10-08-2012, 07:35 PM
cel4145's Avatar
Liked: 2991
If you plan on doing a lot of music listening, then the M70s would be worth it. If mainly just HT, you might not notice a lot of difference.
post #16 of 20 Old 10-09-2012, 03:14 PM
Kini62's Avatar
Quoted: 1423 Post(s)
Liked: 1312
5 NHT SuperZero 2.0 and an Outlaw, HSU or Epik sub.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #17 of 20 Old 10-10-2012, 01:26 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Yes!
When in doubt get the 70's. I have both and have tried both for mains for movies and music. For music, no contest the 70s provide a more enveloping sound stage over my 60's. For movies, the difference is less noticeable when there is a capable sub present,. With out a sub with certain films I did notice the 70s being a tad fuller over the 60's.
i also recommend you start with the mains fist and then focus on the surrounds as your budget allows, that is how I did it. Over about 8 months I built up my polk monitor set a little at a time. I started with the 70's. Added 60's for surrounds, then added the CS2. Later added 30's for heights. Then for the hell of it I got a set of 40's and a cs1 to use in my bedroom
I have moved and my new room is bigger so my set up has changed some. Currently I am running 70's as mains with the 60s as wides and 40s as surrounds. The 30's along with the CS1 are now in the bedroom.
Some thoughts regarding the cs1 and cs2 centers....I wouldn't recommend running the cs1 with the 70's or 60's. However the cs1 blends nicely for me with both the 30s and 40's. I too have heard of people having dialog intelligibility issues with the cs1, but i cannot say that I have experienced that with the cs1 paired with either the 30s or 40s. Granted the cs2 is superior, but the cs1 does work very well with the monitor bookshelf models
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #18 of 20 Old 10-10-2012, 08:28 AM
NewToHT's Avatar
For $1000 I would out most of it towards speakers.....like $700 - 750. I think the Polk 70's and the CS2 is a solid soundstage. The BIC is a solid sub. I would also just get cheepo surrounds for now as they will have the smallest overall impact. I think the the Denon AVE-1713 for $299 at A4L right now is VERY hard to beat. That would be a solid starter HT and something to build on when needed. A common mistake is people spending way too much on amplification and not speakers. I get a kick out of people who buy an expensive receiver or separate amps.....to drive $200 speakers....it's pointless. Your mains and your sub is what the money needs to go to....
NewToHT is offline
post #19 of 20 Old 10-10-2012, 01:38 PM - Thread Starter
Sakome's Avatar
I will have to keep an eye out for a good sale on those Monitor 70s and CS2 speakers. Wouldn't it be better for the receiver to step up to the Denon 2112 (or 2113) series for the benefit of Audyssey Mult XT? I will have to ask the other forums about subwoofer and receiver but at least now I know which speakers to get.
Sakome is offline
post #20 of 20 Old 10-10-2012, 01:50 PM
nlpearman's Avatar
You can get MultEQ XT with the 1712 - the highest level 5-channel model. There's no XT on the 1912 (lowest 7-channel model), but XT returns to the line-up with the 2112.
The 1712 is a good, bang for the buck receiver.
Upgraditis Anonymous
nlpearman is offline
Reply Speakers
