Anthony Gallo Reference 3.5 speaker cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-09-2012, 10:39 AM - Thread Starter
promotiff's Avatar
Is the Anthony Gallo 3.5 speaker cable to be used only with the 3.5 without the SA?
I do not see a second OPT input for the second set of cable going to the Gallo SA.
promotiff is offline
post #2 of 4 Old 10-09-2012, 10:46 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
You're in the wrong place for exotic speaker cable. The vast majority here use regular old wire.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 4 Old 10-09-2012, 07:26 PM
OldMovieNut's Avatar
OPT 2 involves the tweeter. The OPT wire connects to the inside of the tweeter core to suppress build up of static charge (the tweeter is a high voltage low current device). I would save your money and go with plain old wire and connect the OPT wire to the positive terminal.
Cheers,
OldMovieNut
OldMovieNut is online now
post #4 of 4 Old 10-09-2012, 07:41 PM
barryecohen's Avatar
Quoted: 35 Post(s)
The SA does not use/need the OPT wire, as the OPT wire from the main amp takes care of the whole speaker.
You can still use the SA if you feel you want the additional bass augmentation.
So much media, so little time...
Oppo BDP-83 > Emotiva UMC-200 > Audio Alchemy OM-150 Dual Mono > Gallo Reference 3.5
_____________________________ > Audio Alchemy OM-150 > Gallo Strada
barryecohen is offline
Reply Speakers
