Adding external speakers to a samsung smart tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-09-2012, 03:13 PM - Thread Starter
megathunder's Avatar
Hello. i have a samsung smart tv ue55d6530wk and am hoping to add some external speakers, but i am not sure how to do it. Could someone please help?
megathunder is offline
post #2 of 3 Old 10-11-2012, 10:26 AM
dat56's Avatar
I'm not familiar with the particulars of your set, but I assume it has at least one pair of audio output jacks on the back, maybe even two pairs, one labeled "fixed" and one labeled "variable", perhaps. Some TV's accomplish the same thing with only one pair of outs. They instead allow you to select fixed or variable in the setup options. In either case, you're gonna have to connect one pair of these jacks to either an amplifier or to a set of powered speakers. The amplifier could be in the form of a receiver (amp/tuner/pre-amp), an integrated amp (amp/pre-amp), or a basic "power" amplifier. Most power amps will not have volume controls, so that option would only be practical if your TV has the variable audio output function. This would allow the TV to control the volume even when using the external amp to power separate speakers.
The simplest option is, assuming again your set has a variable output option, is just get an inexpensive amp and a pair of speakers, but in terms of value, you may find it preferrable to get a 2 or even 5.1 channel receiver instead. This would give you a remote for volume, in case your TV has only fixed level audio outputs, plus you would typically get an am/fm tuner and inputs for other a/v devices. And the 5.1 channel receiver can open up a whole new world of surround sound, in case you are so inclined.
dat56 is offline
post #3 of 3 Old 10-11-2012, 10:55 AM
Bill Fitzmaurice's Avatar
Liked: 4628
Your owners manual should specify the available output options. Few TVs can use external speakers without an AV receiver to power them.
Bill Fitzmaurice is online now
Reply Speakers
