Reference 3.5 speaker cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-09-2012, 06:16 PM - Thread Starter
promotiff's Avatar
Is the Anthony Gallo 3.5 speaker cable to be used only with the 3.5 without the SA? I do not see a second OPT input for the second set of cable going to the Gallo SA.
promotiff is offline
post #2 of 9 Old 10-09-2012, 08:54 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
I somewhat doubt the Gallos have unique connectors, but maybe you should look at this http://www.roger-russell.com/wire/wire.htm#connect
lovinthehd is offline
post #3 of 9 Old 10-09-2012, 09:23 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
In pics it looks to me like regular old binding posts. Fancy cables aren't going to make any difference.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 9 Old 10-10-2012, 06:22 AM
Bill Fitzmaurice's Avatar
Liked: 5684
Read page 5 of your owner's manual.
Bill Fitzmaurice is offline
post #5 of 9 Old 10-10-2012, 07:44 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
post #6 of 9 Old 10-11-2012, 08:50 PM - Thread Starter
promotiff's Avatar
I am using a set of AGA speaker wire at the "speaker in"connectors and the Opt level 2 banana input.
 If a second set of AGA speaker wire is used to connect between the "Sub In " connectors and my Reference Sa Amplifier, the Opt banana plug at the end of  that extra set of wire would be useless?
post #7 of 9 Old 10-11-2012, 08:52 PM - Thread Starter
promotiff's Avatar
post #8 of 9 Old 10-12-2012, 12:53 PM
barryecohen's Avatar
Quoted: 35 Post(s)
Basically... Yes.
So much media, so little time...
Oppo BDP-83 > Emotiva UMC-200 > Audio Alchemy OM-150 Dual Mono > Gallo Reference 3.5
_____________________________ > Audio Alchemy OM-150 > Gallo Strada
barryecohen is offline
post #9 of 9 Old 10-12-2012, 12:55 PM
Quoted: 35 Post(s)
Also, you could have just asked this question in your other thread...
http://www.avsforum.com/t/1433176/anthony-gallo-reference-3-5-speaker-cable
Reply Speakers
