setting up home theater speaker system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-12-2012, 01:26 PM - Thread Starter
viewram1's Avatar
I can't listen and compare these systems so I like some advice. I have a budget of $600 for a 5.1 system. I am considering the following:
1) polk audio monitor 30s x 4, polk audio CS1 and polk audio PSW10
2) polk blackstone TL1600
3) martin logan MT2
4) energy take classic 5.1
5) other suggestions around this price range??
Since they are all about the same price and I will be using mostly for movies and some music, which one is best? I already have a denon avr2112ci. Also, can the 100 watt 7 channel reciever be used for the PSW10, a subwoofer that has a 50 watt high current amplifier? My living room is 21 x 16 x 9.
viewram1 is offline
post #2 of 10 Old 10-13-2012, 07:53 PM
JimWilson's Avatar
Quoted: 1296 Post(s)
Liked: 1616
3000+ cubic feet will completely overwhelm all of those systems, so you should probably consider alternatives.
Personally I would start with a 3.1 system and then add side surrounds when you can afford them. Although a bit outside your budget a pair of Pioneer SP-FS12 towers with an SP-C22 and a Klipsch RW-12d will be a far better choice. Somewhere down the road you can add a pair of SP-BS22 speakers and you'll have the full 5.1 system
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3 of 10 Old 10-13-2012, 08:10 PM
wse
wse's Avatar
Quoted: 2041 Post(s)
Liked: 748
I agree concentrate on the front first then add as.$ become available wink.gif
Pioneer Andrew Jones or HSU
wse is offline
post #4 of 10 Old 10-13-2012, 08:36 PM
zieglj01's Avatar
Quoted: 958 Post(s)
Liked: 855
x3 on the Pioneer speakers
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 10 Old 12-08-2012, 11:03 AM - Thread Starter
viewram1's Avatar
I ended up getting the EMPtek 55 towers, 56 center and two bookshelf speakers to use with my denon avr2112ci. they will be delivered soon. Now I need to get a subwoofer. My two choices are the BIC PL200 and the HSU VTF-1 MK2 for about $200 more. My room is 19 x 16 x 8 with a 5.5 x 6.5 opening and hardwood floors. I want to use 70/30 for movies and music. I don't plan to play too loud. Do you think the BIC will be good enough? It would be nice to save a couple of hundred bucks!!
viewram1 is offline
post #6 of 10 Old 12-08-2012, 03:11 PM
JimWilson's Avatar
Liked: 1616
Why are those the only two choices? For the same $500 you'll spend on the VTF-1 there may be other good options available.
post #7 of 10 Old 12-08-2012, 03:17 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
The Klipsch RW12d is again on sale at Newegg.com for $299 (with promotion code). These won't last a lot longer and at the sale price, a very good value.
lovinthehd is offline
post #8 of 10 Old 12-08-2012, 05:27 PM - Thread Starter
viewram1's Avatar
Those were two choices based on research from this forum and others.
viewram1 is offline
post #9 of 10 Old 12-08-2012, 06:05 PM - Thread Starter
viewram1's Avatar
I will check out the Klipsch RW12d. Thanks for the suggestion.
viewram1 is offline
post #10 of 10 Old 12-08-2012, 06:17 PM
lovinthehd's Avatar
Liked: 4776
Try this http://www.avsforum.com/t/1390563/klipsch-rw-12d-omnimic-frequency-response-graphs
Reply Speakers
