Mixing HTD Level II with their Flat Panel Speaker center - AVS Forum | Home Theater Discussions And Reviews
Old 10-14-2012, 12:14 PM - Thread Starter
firedoghfd's Avatar
Due to space issues I need a smaller center speaker then the Level II center. Any issues with using the HTD Level II for the right and left but use the Flat Panel Speaker for the center?
http://www.htd.com/Products/flat-panel-speakers/flat-panel-speaker
http://www.htd.com/Products/level-two-speakers
this will be paired with a BIC America F12 Sub.
If you think this would be a bad pair then any other small center speakers for around the same price you would recommend?
firedoghfd is offline
Old 10-14-2012, 01:53 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It will be fine
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Old 10-14-2012, 02:54 PM
Luis Gabriel Gerena's Avatar
Quoted: 94 Post(s)
Liked: 63
Well using any center speaker that is not matched to your mains can be very distracting depending on how picky you are. Also, the center speaker is too important to leave it to a lesser speaker so if you mostly sweet in the sweet spot, you might be better of just going with a phantom center speaker.
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
