Room Setup / Speaker Recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-18-2012, 12:06 PM - Thread Starter
hellmuth's Avatar
Hi guys,
i'm moving to a new place in November and just decided on getting the Panasonic 55 ST as a TV. I'm now looking to get some decent sound as well. What i'm looking for is a 5.1 setup preferably. I am looking to spend 800$ on the system including: Speakers, Subwoofer, Receiver, Cables and Stands (if applicable).
The room is 16x16 feet with two openings, one towards the kitchen and one towards the hallway. I have attached a picture to visualize it as best as possible and included the designated area for the TV as well.
I appreciate your help!
hellmuth is offline
post #2 of 10 Old 10-18-2012, 12:39 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
ack_bk is offline
post #3 of 10 Old 10-18-2012, 12:52 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Originally Posted by ack_bk View Post
I think there is no better value right now that the freshly redesigned Andrew Jones Pioneer speakers:
+1 for Pioneer phase 2 speakers
Also some Best Buy stores will price match TigerDirect, at $200 a pair for the towers.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #4 of 10 Old 10-18-2012, 12:57 PM - Thread Starter
hellmuth's Avatar
Thanks guys. I'm wondering two things: Is there a reason why the Subwoofer is not from the Pioneer series? I saw that Pioneer also offers the Andrew Jones designed Subwoofer.
As to the surround speakers: for me it would be much easier to have stand/floorstand speakers in the back as well. Could i just purchase 4 of the Front speakers you suggested?
thanks!
hellmuth is offline
post #5 of 10 Old 10-18-2012, 01:03 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
thanks!
When it comes to speakers (especially your front left, right, and center) it is important to match brand/family/drivers (timbre matching). With subwoofers, this is not important. From what I have read the new Pioneer sub is pretty solid, but it is 8" and from the sound of it you have a prettty big room hence the larger subwoofer.
For the surrounds you can either add the floorstanding speakers, or buy the bookshelf speakers and add some inexpensive stands.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=speaker+stands
ack_bk is offline
post #6 of 10 Old 10-18-2012, 01:07 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
thanks!
There are better sub options, for overall sound quality. You can use towers
for surrounds - however, you may need to prop the towers up a little. You
want to be able to hear, above you seating position.
Who AM I
zieglj01 is offline
post #7 of 10 Old 10-18-2012, 01:09 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You may also want to consider saving up some money for a better subwoofer. Your options really improve in the $300 or so budget range.
So buy all your speakers then save up and look for some sub deals.
ack_bk is offline
post #8 of 10 Old 10-18-2012, 01:55 PM - Thread Starter
hellmuth's Avatar
Are there any other Receivers that are recommendable? The original Denon 1612 seems to be a hard thing to come by.
thanks!
hellmuth is offline
post #9 of 10 Old 10-18-2012, 03:47 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
thanks!
In stock at AC4L, and they are a good company.
The 1612 measures better, than a lot of budget receivers.
Who AM I
zieglj01 is offline
post #10 of 10 Old 02-02-2013, 12:36 PM
alamez's Avatar
Quoted: 36 Post(s)
I have a similar room set up only there are two openings to my left one to a living room and one to the kitchen. The room is the same size as above. I'm trying to figure out placement of the speakers. I'm planning on putting two towers I. The front (boston a360) which I got for 200 each. And the center channel. Now I gotta figure out the surrounds (boston doundware indoor/outdoor) I'm thinking putting them up on the wall by the ceiling (8ft)
alamez is offline
Reply Speakers
