Quick question on mounting 4 Energy CB-5 surround speakers... - AVS Forum | Home Theater Discussions And Reviews
Old 10-19-2012, 01:38 PM - Thread Starter
ktrio730's Avatar
I can't really find any info on what kind of mounts I would need for these speakers.
I would prefer not to have to drill into the speaker, but if that is the only way to mount them, I guess I have no choice.
Does anyone know what type of mount I should look for?
ktrio730 is offline
Old 10-19-2012, 01:39 PM - Thread Starter
ktrio730's Avatar
Also, anyone know of a good stand for these as well where I wouldn't have to drill?
I want to mount 2 and put the other two on adjustable stands.
ktrio730 is offline
Old 10-20-2012, 12:35 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
CB-5's have a 1/4-inch - 20 thread insert on the back. the newegg label is in the way.
http://voxxintlcorp.com/docs/common/CB-5/CB-5_CUT_SH.pdf
Omnimount makes a wall mount with that insert. They are sold individually.
http://www.nhthifi.com/Omnimount-10-0-W-C-Mount
Speaker stands are easy to find since the CB-5 just sits on a flat top plate. You don't have drill at all. Just use velcro squares or blu tack putty to hold the speaker on the stand. I've been using bookshelf speakers on stands for 25 years.
Afro GT
afrogt is online now
Old 10-20-2012, 12:53 AM
