What are the best satellite speakers I can get for $300 a pair ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-20-2012, 01:11 AM - Thread Starter
Anthony1's Avatar
Quoted: 588 Post(s)
Liked: 353
I need two small speakers. Like the size of say Monitor Audio R90's. Looking for the best possible sound quality for $150 each. I know that's not a lot of money, but I have to save for the sub to go with them, so I can't go crazy. What satellites should I consider ?
Anthony1 is offline
post #2 of 2 Old 10-20-2012, 07:13 AM
afrogt's Avatar
Quoted: 1062 Post(s)
Liked: 768
along with the MA R90's look at the:
Def Tech Promonitor 800, 4.75" W x 8.38" H x 5" D
http://www.amazon.com/Definitive-Technology-ProMonitor-Bookshelf-Speaker/dp/B000TD6QLK/ref=sr_1_1?ie=UTF8&qid=1350737343&sr=8-1&keywords=definitive+technology
Energy V-Mini, Dimensions: 4.72" W x 7.48" H x 5.51" D
http://www.vanns.com/shop/servlet/item/features/543514326/energy-v-mini-w-bracket?b_i=IP_barilliance
Energy CB-5, HxWxD, 8.7 x 5.7 x 7.9 inches
http://energy-speakers.com/bookshelf-speakers/?sku=CB-5
NHT Superzero 2.0, 9" Tall x 5" Wide x 5.5" Deep
http://www.nhthifi.com/Bookshelf-speaker-SuperZero-2-0?sc=12&category=3772
NHT Absolute Zero, Dimensions - 9.75"H 5.625"W x 7.25"D
http://www.nhthifi.com/Absolute-Zero-Black?sc=12&category=3772
Paradigm Cinema 90 V.3, Height, Width, Depth 7-3/4 in x 4-5/8 in x 5-3/4 in
http://www.amazon.com/Paradigm-Cinema-90-Bookshelf-Speakers/dp/B0080RLY0U/ref=sr_1_3?ie=UTF8&qid=1350738016&sr=8-3&keywords=paradigm+speakers
I've heard the Martin Logan MLT-2 are rebadged Cinema 90 speakers. Newegg quite often puts the 5.1 package on sale for $299. Sign up for the emails to be notified of a sale. Might be all you need since it includes a subwoofer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981013&name=Home-Audio-Speakers
If you can find any of these locally you should try to audtion yourself. You can listen to the Def Tech and CB-5 at Best Buy Magnolia stores. The others may be harder to find.
Afro GT
afrogt is offline
Reply Speakers
