7.1 Surround Speaker Placement - AVS Forum | Home Theater Discussions And Reviews
Old 10-23-2012, 02:39 PM - Thread Starter
ffactoryxx's Avatar
Quoted: 258 Post(s)
Liked: 54
Ok guys so i am going to be either cutting drywall this weekend or painting. As you can see from my photo's and my Awesome Microsoft Paint sketch, that is my current room and how its setup for 7.1. The front Towers will be replaced by tEnergy LCR's and the Sub on the left by the SVS.
My biggest thing are pictures are 1 - 2 - 4
( Photo 1 and 4) My Di-Pole VS - Surrounds will go where the plates are noted. Are they too high compared to the seating?
If so my buddy and I will move them down.
(Photo 2 and 5) You can currently see where my rear surrounds will be placed (Energy RC-10's). I currently have my JBLS mounted about 8-9 ft up in the corners and pointing Diagonal downward towards chairs.
If I have enough slack left in speakers should I move them to position A or B?
I assume I would have the DiPoles firing towards the back wall, would it even be worth the hassle to move the corner speakers?
ffactoryxx is offline
