will this work - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-24-2012, 08:06 PM - Thread Starter
tongr's Avatar
I may have an extra speaker from setting up a 5.1 setup. Can I take the extra speaker and make a "mono" setup by hooking up both left channel outputs from an amp (such as a small T amp) to the speaker's left input and the same for the right channel? I hope this makes sense- let me know. Thanks.
tongr is offline
post #2 of 3 Old 10-24-2012, 09:15 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Nope. The speaker can only play one channel. And if you try to connect both the left and right positive to the speaker positive, and left and right negative to the speaker negative, you'll fry the t-amp.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 3 Old 10-25-2012, 05:38 PM - Thread Starter
tongr's Avatar
Not the answer I wanted but I appreciate your expertise.
tongr is offline
Reply Speakers
