Trying to buld new pc fi pleae help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-28-2012, 04:22 PM - Thread Starter
cyyoung749's Avatar
Hey guys i decided build pc fi for myself and i came here for help. This is my first time so i really have little knowledge i dont even know how this really works. After reasearching a little.I came with dac-amp-speaker combination with maximum of $1500.
I will be installing pc fi on my labtop because my desktop is mainly for gaming purposes. I really listen to all kinds music classic,pop,hip pop, almost everything.Right now im thinking jbl studio 530 speaker with teac ud h01 and amp which i couldnt decide. Do you guys think this is a good choice? If theres a better dac+amp+speaker combination under $1500 please help me to choose. Thank you guys!
cyyoung749 is offline
post #2 of 11 Old 10-28-2012, 07:38 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3000
Any reason why you want the expensive DAC? If this is for gaming purposes, do you have HDMI out from your video card? If so, you might want to go with a Denon, Onkyo, or Pioneer HT receiver in case you want to add surround speakers later on. Just send the digital audio from your computer to the receiver with HDMI.
Also, have you thought about adding a sub? Can really add to bass heavy music and games that have bass effects. Something like a HSU STF-2 could do very nicely in a smaller room. The HT receiver will also work better with a sub because of the bass management features.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 11 Old 10-28-2012, 08:17 PM - Thread Starter
cyyoung749's Avatar
Thank you for the reply. i will not be using pc fi for gaming uses. I will only uses for music puroses on my labtop. Is there decent dac+amp+speaker for that price?
post #4 of 11 Old 10-28-2012, 08:26 PM
cel4145's Avatar
Liked: 3000
Do you like lots of bass? Bookshelf speakers won't give you that alone. You'd need a sub, too.
Meanwhile, the best strategy is typically to put most of your budget toward speakers (and sub) over the electronics. That's where you get the best bang for your buck in audio quality.
cel4145 is offline
post #5 of 11 Old 10-28-2012, 08:50 PM - Thread Starter
cyyoung749's Avatar
i dont reall need alot of bass right now but i will get one in the future. You just mention that i will get the best bang for the buck but is there certatin combination goes along together?
Im thinking about jbl studio 530+ teac ud h01 dac + either shiit valhalla or shiit asgard amp. Do you think this is good combination? Thank you again
post #6 of 11 Old 10-28-2012, 08:55 PM
cel4145's Avatar
Liked: 3000
Those are headphone amps. Won't driver speakers.
Get an HK 3490 and then Ascend Acoustics Sierra-1 speakers. Much better speakers than the JBLs. The HK 3490 has optical input and a built in DAC. Add a sub later on.
cel4145 is offline
post #7 of 11 Old 10-28-2012, 09:02 PM - Thread Starter
cyyoung749's Avatar
Oh that looks pretty good. But dont i need amps too? Is hk 3490 working as amp and dac?
post #8 of 11 Old 10-28-2012, 10:00 PM
cel4145's Avatar
Liked: 3000
HK3490 is a 2 channel 120 watt stereo receiver with a built in DAC. If you like, you can always add a separate DAC later if you don't like the one in the 3490.
cel4145 is offline
post #9 of 11 Old 10-28-2012, 10:06 PM - Thread Starter
cyyoung749's Avatar
So connect hk3490 to my computer with usb and speaker? Dont i need amplifier?
post #10 of 11 Old 10-28-2012, 10:34 PM
cel4145's Avatar
Liked: 3000
Doesnt' have USB. You need optical or coxial digital connection coming from your computer.
cel4145 is offline
post #11 of 11 Old 11-02-2012, 09:36 AM
destroysall's Avatar
You could go with the KRK Rokit 5 + Rokit SUB10. For a DAC, I would recommend the Matrix Mini-I, which is a balanced DAC that can be used as a pre-amp for the KRKs. It also has a built-in headphone amplifier, which is a nice bonus.
destroysall is offline
Reply Speakers
