how do you guys think about this combination? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-30-2012, 12:11 PM - Thread Starter
cyyoung749's Avatar
Im really a newbie to pcfi and i actually did alot of research but its really hard to find the right pcfi for the buck with little knowledge. My budget is about $2000 dollars and some one suggest me this devices.
kef x10 speakers with onkyo a-9070 Is this a good combination?
Before suggestion I came with DYNAUDIO MC15 with CAMBRIDGE DACMAGIC PLUS but the user said cambridge dacmagic plus will not perfom dynaudio mc 15 speakers to the maximum performance. He actually recommended other preamp/dac devices but it will go beyond my budget So guys which devies should i go for?
cyyoung749 is offline
post #2 of 2 Old 10-30-2012, 12:47 PM
Hamilcar Barca's Avatar
Why not? Is there something wrong with the DACMagic+?
Have you considered the ODAC? Its performance is comparable to the better DAC's on the market and it's much cheaper. Available from JDS Labs for US$150, there are also non-US distributors. You can spend a lot of money on a high-performance DAC but you don't have to.
Hamilcar Barca is offline
Reply Speakers
