Speaker choice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-30-2012, 02:50 PM - Thread Starter
csnbharathi's Avatar
I just purchased an onkyo 818 receiver.
I have a 5.1 speaker system that came with my Sony home theatre. I am planning to use this for a week or two.
Looking at a good speakers for within 400$, can stretch to 500$ if required. I can start with a 5.1 and move to 7.1/2 later.
Polk Audio RM705 5.1 Home Theater System (Set of Six, Black) $249.99 from amazon interests me.
Any suggestions would be great
I have a 350-400 sq.ft room (Might be moving to a bigger house in the near future)
csnbharathi is offline
post #2 of 10 Old 10-30-2012, 03:38 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Are you really going to spend all that money on a great receiver and then spend $250 on little satellite speakers? That seems backwards.
Can you have bigger speakers than that?
Afro GT
afrogt is offline
post #3 of 10 Old 10-30-2012, 03:57 PM
MJBraz's Avatar
If all you can spend is 500 bucks right now. I'd recommend spending it on a good pair of bookshelf speakers and matching center channel. Add a good $400 subwoofer next and and then add decent surround channel speakers after that. Better to put together quality in stages than settle for less all at once.
MJBraz is offline
post #4 of 10 Old 10-30-2012, 04:31 PM - Thread Starter
Yes! I can go big on the speakers, but this was my starting point. I like the idea of adding speakers (As mentioned by MJ). Am open to suggestions.
post #5 of 10 Old 10-30-2012, 04:35 PM
ccotenj's Avatar
Liked: 101
to be bluntly honest, return the avr... spend more on speakers... even if you only start with 2...
you would be far better served spending 1k on speakers and 400 on an avr than the other way around...
- chris
ccotenj is offline
post #6 of 10 Old 10-30-2012, 04:48 PM
Mike Garrett's Avatar
Quoted: 5556 Post(s)
Liked: 3541
Good advice. Keep in mind, speakers are generally considered long term items in your HT system, unless you are me smile.gif
mjgarrett100@gmail.com
Mike Garrett is offline
post #7 of 10 Old 10-30-2012, 06:58 PM - Thread Starter
I do not mind spending a bit on speakers. I would like to know the best possible options even if it goes beyond my current budget, that would really help me in planning for the right stuff or at least look for the right combo. I am pretty much stuck (in my head) with the 818 :-)
post #8 of 10 Old 10-30-2012, 06:59 PM
ccotenj's Avatar
Liked: 101
- chris
ccotenj is offline
post #9 of 10 Old 10-31-2012, 03:37 PM - Thread Starter
I was checking out the SVS audio systems, any insight on it.
Any info on the good speakers to go with 818 would be really helpful
post #10 of 10 Old 10-31-2012, 06:36 PM
nastynice's Avatar
^^well, I can say this, people LOVE their subs. I dont know too much about them personally tho
nastynice is offline
Reply Speakers
