Klipsch HD Theater 600 vs HD Theater 1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-01-2012, 06:39 AM - Thread Starter
jjakubowsky's Avatar
I am seeing the Klipsch HD Theater 1000 cheaper than the HD Theater 600 (5.1 Speaker set) at amazon. I am not much of an audiophile like most of you. I can't tell which system is considered the better system. I am assuming the 1000 are better based on the number. But the 600 are newer. Anyone able to compare these directly? I use it 50/50 between music and HT.
Thanks. -Jeff Jak
jjakubowsky is offline
Reply Speakers
