In-wall/On-wall Recommendation - AVS Forum | Home Theater Discussions And Reviews
Old 11-02-2012, 09:32 AM - Thread Starter
Sickman's Avatar
Looking for recommendations for in-wall or on-wall speakers.
Ideally I'd keep it under $3K for LCR & surround. I'll deal with sub separately.
I'll mount them/install them around a 60" or 65" plasma.
50-50 music/movies. Music matters, but I don't do 5.1 music, so priority is on LCR.
If it's in-wall, I think I'm only interested if they have an enclosure.
My priority is the best sound I can get for the price, but looks matter too (or I'd go floorstanding).
My previous set-up was B&W CM series from about 8 years ago and a DefTech sub. They were great for music, but I always felt the B&W center was a little sub-par for movies.
Thanks in advance.
Oh, almost forgot -- room is about 19x17 and open into the kitchen.
Sickman is offline
Old 11-02-2012, 11:14 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
B&W makes enclosed speakers along with Triad, Episode, Definitive Technology, Totem, Niles, etc.
In your budget I do recommend the Defeinitive Technology UIW RLS series for your front three mains. I am using these speakers curently and am quite happy with them. Triad, to me, sounded the best of all the in-wall speakers I demoed, but they will most likely be over your budget by a lot smile.gif
Here is a link to the Definitive Technology speakers I am using:
http://www.definitivetech.com/products/uiw-rls-ii
To save a little, you can go with this model that has slightly smaller drivers:
http://www.definitivetech.com/products/uiw-rls-iii
You should be able to buy them new for around $1200 shipped or less and that would leave money for surrounds and a good subwoofer.
I would also look into Episode speakers. They use folded ribbon tweeters, which I tend to like a lot for music. Here is a link to their site:
http://www.episodespeakers.com/
You most likely will need to find a local dealer/installer to buy them.
ack_bk is offline
Old 11-30-2012, 07:33 PM
ScAndal's Avatar
Liked: 27
ack_bk,
Small world, I'm just down the road from you. I'm wondering where you picked up your UIW-RLS IIs? I see some good deals on ebay.
Also, do you know anywhere in town to audition some different in-wall speakers?
ScAndal
ScAndal is offline
Old 12-01-2012, 08:14 AM
Hookedonc4's Avatar
Quoted: 26 Post(s)
We use James loudspeaker. Check out the QX series.
http://www.jamesloudspeaker.com/index.cfm?page=by_series&id=32&sr=1
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
