Opinion on speakers for 5.1 surround system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-03-2012, 10:33 PM - Thread Starter
Superman9999's Avatar
Hello,
A home audio expert recommended the below speakers for installing 5.1 surround system in my home. Appreciate if you can check the specs and make recommendations if required. Can you please recommend a site like amazon or some store where I buy the speakers along with speaker brand?
Pro Series 8" 150-Watt 3-Way In-Wall Speaker (Front pair) -- 169.00
Pro Series Dual 5.25" 120-Watt Video-Shielded 2- Way LCR In-Wall Mounted Speaker -99.00
Pro Series 8" 120-Watt 2-Way In-Ceiling Speaker (Rear pair) -- 169.00
8" 150-Watt Compact Powered Subwoofer - Black Gloss Finish -299.00
Thanks in advance.
Superman9999 is offline
post #2 of 5 Old 11-03-2012, 10:52 PM
gregzoll's Avatar
Liked: 33
Am I missing something, or is there some manufacturer info you need to post, regarding your question.
gregzoll is offline
post #3 of 5 Old 11-04-2012, 03:34 PM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1567
Nope, you're not missing anything; "Pro Series" doesn't say who manufactures the speakers, so there's no way to answer his question.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #4 of 5 Old 11-04-2012, 03:44 PM - Thread Starter
Sorry folks. I should have posted the thread with complete information. Make and Model for Subwoofer is NXG and the model number is NX-PROSUB8. I am assuming that the speakers are from the same manufacturer as well. Could you please recommend good speakers or manufacturer for my requirements?
Thanks in advance.
post #5 of 5 Old 11-04-2012, 04:31 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Thanks in advance.
NXG is decent stuff at the price point you are looking at, but if you want better, you will need to increase your budget.
I would skip the NXG sub for sure and look into subs in the subwoofer forum.
ack_bk is offline
Reply Speakers
