TV speakers in open room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-04-2012, 06:57 PM - Thread Starter
bananapeal's Avatar
Hello,
We are building a home theater space and I thought I'd update our tv speakers (a few, up to $400, might get lost in the thousands of av/home improvement in the theater). Currently tv goes out to a 5 disc changer that we bought in 1998 for $200.
The wonderful panasonic ak-27.
Here are the specs:
These speakers do produce some bass. They have two woofers and a tweeter. More than typical bookshelf speakers.
I'm not an audiophile and critical listening will happen in the theater space anyways. These are just for watching news or basic channel flipping while sitting on couch. Background music for cooking etc.
Will I notice a difference by changing speakers to something like:
Mirage OMD-5
Amplifier Power Output 10-175 Watts (unclipped)
System Type OMNIPOLAR™ Bookshelf / Satellite Speaker
Max. Load Weight (lbs) 8 lb / 3.63 kg
Frequency Response 60 Hz - 20 kHz (+/- 3dB)
Impedance 6 Ohms Nominal / 4 Ohms Minimum
Accessories Wall Bracket and Polishing Cloth
Tweeter 1" Pure Titanium Hybrid Dome
Overall Dimensions HxWxD,in: 9.18 x 6.45 x 7.22,cm: 23.3 x 16.4 x 18.3
woofer 5.5" Poly Titanium Deposit Hybrid
Product Finish High Gloss Black; High Gloss Rosewood
Crossover Point 2.3 kHz
Aperion 5B
Weight 12.0 lbs
Frequency Response (+/- 3dB) 80Hz to 20,000Hz -- (+/- 6dB) 68Hz to 20,000Hz
Impedance 8 ohms
Sensitivity 87dB
Recommended Power 25-200 Watts
Tweeter 1" Audiophile-grade Silk-Dome Tweeter
Woofer 5.25" Woven-Fiberglass Mid-Woofer
Driver Configuration 2-Way
Enclosure Type 18mm MDF, Ported
Dimensions 12" H x 6.75" W x 8" D
Product Family Intimus
The Specs look the same to me. I want to drive these with: AudioSource AMP-100 : http://www.newegg.com/Product/Product.aspx?Item=N82E16882180022&name=Receivers
The harmonic distortion goes from 1% now on the amp to 0.1% with the audoSource. Other than this, there doesn't seem much difference. I could also keep the speakers and just ditch the ridiculous cd changer/tape-deck stack for the sleek amp.
What do you think? Go all the way for some nice bookshelves or stick to what I've got?
bananapeal is offline
post #2 of 6 Old 11-04-2012, 11:00 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
OK,
Just to confirm you are talking stereo only and not multi-channel sound. The AMP 100 would be more than enough to drive whatever you want, but your existing should be able to drive better speakers as well.
Personally, I would look for something with 6.5 inch rather than 5. There are loads of options: The NHT 2, Definitive Technology StudioMonitor 55 or the older 450 if you can find them, KEF Q300, JBL Studio 530 (I have not heard these,) and a boat-load of other options.
lespurgeon is offline
post #3 of 6 Old 11-04-2012, 11:42 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 971
this is his old setup, a Panasonic Mini system AK-27
I'm pretty confident the Audiosource amp and a pair of bookshelf speakers will sound better than your old system. You'll no longer have a 5 disc changer though.
I would also go with larger speakers than the ones with 5.25" driver. Perhaps a pair of Infinity P163 speakers?
http://www.amazon.com/Infinity-Primus-Two-way-Bookshelf-Satellite/dp/B0045NCB32/ref=pd_cp_e_0
Possibly even the HTD Level Three bookshelf speakers
http://www.htd.com/Products/level-three-speakers/Level-THREE-Bookshelf-Speakers
KEF iQ30
http://www.kefdirect.com/iq30-bookshelf-loudspeaker.html
Definitive Technology SM 450 or 350? They have a 8" or 10" bass radiator
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325060
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059
Boston Acoustics CS26
http://www.accessories4less.com/index.php?page=item&id=BOSCS26IIB&gclid=CM2w4_-ot7MCFYp_Qgod6xsA0A#
Or maybe a pair of Polk Monitor 45's with dual 5.25" woofers
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290269
Afro GT
afrogt is offline
post #4 of 6 Old 11-04-2012, 11:48 PM
afrogt's Avatar
Liked: 971
afrogt is offline
post #5 of 6 Old 11-05-2012, 08:35 AM - Thread Starter
bananapeal's Avatar
Wow that sherwood is certainly more feature rich. Yes it is for stereo only.
Fwiw, in the loop is a really cheap htpc that is mostly used for dvr. The sound goes from the cheap pc analog out to the panny stack for amping.
So I would have turned the amp to like 80% and set it and forget it. then use the pc remote for volume control. But I currently do use the stack for volume control especially since some tv channels have messed up volume that is simply too low.
And I like idea of turning fm on randomly.
The speaker issues are more complicated though. Seemingly too many choices. I spent last night reading all the nice things people had to say about the andrew jones pioneer speakers and I think I'll pick some up just because now they are $84/pair. If they are too weak for TV use, I can put them in the bedroom.
I am having trouble finding "pro" reviews of the 6.25" bookshelf speakers. I live in a geographically challenged area of eastern CT so it isn't easy to audition speakers. For instance, I'm leaning towards aperion for the home theater room due to their 30 day trial. HTD lets you trial also but i read a review saying its strings instruments in classical wasn't too good.
gosh. I mean I don't even know how much to trust reviews. it's all very overwhelming. I kinda wanna get those pioneers in my hands just to see what "good" speakers sound like compared to the panasonics.
post #6 of 6 Old 11-05-2012, 11:00 AM
zieglj01's Avatar
Quoted: 1675 Post(s)
Liked: 1569
The HTD will pancake your Panasonic system, also do not go by all the older HTD reviews - their current
system is the third rework of the horn tweeter. I prefer HTD over the phase 1, Pioneer speakers.
The phase 2 Pioneer speakers, are more competive with the HTD speakers.
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
Reply Speakers
