Polk Audio Monitor 11 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-07-2012, 11:30 AM - Thread Starter
00bolt's Avatar
Does anyone know anything about these? Local guy has a set of these he claims are in a 9/10 condition and has gone on about how rare they are and how much better they sound vs. newer Polks and newer big box store speakers in general, and at a fraction of the cost..
im trying to piece together my very first real setup (only own a 12 year old Sony home theater in a box).. Iv been debating between some different setups (trying to stay on a budget) and came across these. Not really what i was originally looking for style wise, but the fact that they seem to have good reviews online and each speaker has a 12" woofer, i may be able to eliminate the need for a dedicated sub?
does anyone have these speakers or have had them or heard them? What are your thoughts? Im setting up a man cave / media room in my 20x20 garage with a projector and 120" screen. These would be my primary front speakers and then would have to add a matching center speaker (any ideas what would go good with this?) along with some rears and maybe a sub, maybe not?
00bolt is offline
post #2 of 3 Old 11-07-2012, 12:40 PM - Thread Starter
00bolt's Avatar
these are the speakers im referring to
http://www.polksda.com/monitor11.shtml
00bolt is offline
post #3 of 3 Old 11-10-2012, 01:05 AM
davidst's Avatar
You must be very new at this.
First make sure they are Monitor 11 and not RTA-11
Drivers: 1 - 1" SL2000 tweeter, 2 - 6.5" 6510 midranges, 1 - 10" fluid-coupled sub woofer
It's not a sub woofer it is a Passive Radiator and it is 10" not 12".
Passive means not powered it enhances (passes on) the low frequencies.
Yes it has good bass but not like a 300 watt 12" powered sub woofer.
They sound very good. Worth about $200 max in excellent condition
All of the drivers are still available from Polk Audio if needed.
6 Ohms Recommended Power: 10 - 200 watts per channel
6 Ohms speakers need a decent power source,100 REAL watts per channel receiver minimum.
Use Monitor 4's for the rear
http://www.ebay.com/itm/VINTAGE-POlK-AUDIO-MONITOR-4-MATCHED-PAIR-/130795548868?pt=Speakers_Subwoofers&hash=item1e7405b0c4
Use CS2 for front center
http://www.ebay.com/itm/POLK-Audio-175w-Black-Center-Channel-Speaker-CS2-/121014105364?pt=Speakers_Subwoofers&hash=item1c2d00b514
Polk Audio Forum
https://www.google.com/search?q=polk+monitor+11&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#hl=en&client=firefox-a&hs=kyR&tbo=d&rls=org.mozilla:en-US:official&q=+site:polkaudio.com+polk+monitor+11&sa=X&ei=0wmeUK7uCoOy2wWM_4CQAw&ved=0CKMBEK0CMA0&bav=on.2,or.r_gc.r_pw.r_qf.&fp=90608e72b45b1351&bpcl=38093640&biw=1339&bih=981
davidst is offline
Reply Speakers
